Getting my rear TSB done today. Anything I should know.
Discussion in 'Suspension' started by tacomakid89, Apr 15, 2010.
  1. Apr 15, 2010 at 8:39 AM
    tacomakid89
    tacomakid89 [OP] Awesome Member
    William
    Austin, Texas
    2010 Black, 4x4, TRD Sport Tacoma
    Hard Wired GPS, Scan Guage II, URD Short Throw Shifter, AFE Pro Dry S Air Filter, LED Mag Lite on seat side,Tailgate Theft Prevention Mod, Removed Front License Plate, Tint Cover Over Rear License Plate, Removed Secondary Air Filter, 13" Shorty Antenna, 5% Tint Rear, 20% Tint Front, Bed Extender, TRD Cat Back Exhaust, Fog Light On Anytime Mod, Dual Halo Projection Headlights, Disabled Seatbelt Chime, King coilovers with remote resi in front, Kings with remote resi in rear, Deaver J66 leaf packs, TC UCAs up front.
    Hey there well i'm getting my rear TSB done today at Virginia Beach Checkered Flag Toyota and I was wondering if there is anything that I should know before I get it done. I know that I should keep the old parts if I can. Anything else guys. Thanks.
  2. Apr 15, 2010 at 8:52 AM
    DBZ 2010
    DBZ 2010 Well-Known Member
    Kahului, Maui
    2010 Wht Dbl Cab TRD Off Road PreRunner
    Gaylord TL Series Tonneau, 3 TSB's (Trans Re-flash, Rear Leaf Springs, Intermediate Steering Shaft), 5100 Bilsteins x 4 set at 1.75, Silver TRD FJ 16 inch Wheels, Wet Okoles
    After the springs are installed your headlights will point lower. You should think about some 5100 billies to level off the front.
  3. Apr 15, 2010 at 8:58 AM
    tacomakid89
    William
    Austin, Texas
    Ya thanks for reminding me about the headlights. Ill have to do those once it gets dark tonight. Ya im def thinking about getting some from DownSouth MotorSports for a good price. I was thinkin about putting them at 2". What do you think.
  4. Apr 15, 2010 at 9:05 AM
    DBZ 2010
    Kahului, Maui
    I got mine set at the 1.75, I've heard others go to the 2+ but some say that you might have an alignment problem and that the UCA's might have to be changed out. You might look at some of the other posts on TW.
  5. Apr 15, 2010 at 9:14 AM
    tacomakid89
    William
    Austin, Texas
    That looks good like that. Did you have to do anything after you put the shocks on?
  6. Apr 15, 2010 at 9:26 AM
    DBZ 2010
    Kahului, Maui
    Just the re-alignment on the front end because of the struts removal. Also, some say that the new springs will give you a stiffer ride but I didn't notice it. But most members seem to agree that the spring replacement is worth it. By the way when you get your tsb done check the spring pack, because some TW members reported that their dealers made a mistake and re-installed the old 3 leaf pack back on.
  7. Apr 15, 2010 at 9:28 AM
    sethr21785
    sethr21785 Well-Known Member
    Seth
    Lake Jackson TX
    00 Tundra
    you will need an alignment
  8. Apr 15, 2010 at 9:33 AM
    tacomakid89
    William
    Austin, Texas
    Alright. Ill be sure to get it re aligned after I put them in. Ya i've also heard of that happending. Ill be sure to inspect it all after I get it done.
  9. Apr 15, 2010 at 9:46 AM
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    Hopefully they get done it right on my dealer too, I'm getting it done at crown toyota at ontario.
  10. Apr 15, 2010 at 9:47 AM
    jester156
    jester156 Well-Known Member
    Cumberland, RI
    2021 GMC Sierra AT4. 3.0l Duramax
    like other said, inspect the part number.
    I had a problem with the shop not doing my alignment, as the TSB states. My original work order referenced the correct TSB number, but the actual worksheet had a different TSB, i believe for the squeaky spring, and didn't include the alignment. so I had to go back and get my free alignment.... which I needed b/c i had added 5100s a day prior to the TSB swap.
  11. Apr 15, 2010 at 9:50 AM
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
  12. Apr 15, 2010 at 9:57 AM
    tacomakid89
    William
    Austin, Texas
    Oh well thanks. but I was talking about after I put on hte 5100's.
  13. Apr 15, 2010 at 10:00 AM
    rob1
    rob1 Well-Known Member
    Robert
    South Texas
    Indigo Blue DblCab 4X4 Long Bed TRD Sport SR5
    Tail gate mod, locking gas cap, locking spare tire, rear spring tsb,Weathertech Digital fit's
    x2...my thoughts exactly....inspect everything be sure to drive off with 4 leaf springs, my dealer installed the three "new" and improved :rolleyes: leafs, and they tryed to convence me, but I knew better thanks to everyone here!!:D;)
  14. Apr 15, 2010 at 10:09 AM
    spaghettiedy
    spaghettiedy Well-Known Member
    Pittsburgh
    09 DC LB Sport in Black 4x4
    Gray Weathertechs, LG Wet Okoles, Tacome OEM Bedmat
    I'm getting mine done at the end of the month, and didn't really know this was the norm. Getting the old springs that is. So people that have had this done typically get their old springs back. :confused:
  15. Apr 15, 2010 at 10:18 AM
    tacomakid89
    William
    Austin, Texas
    Not all the time. Sometimes the dealer will say that they have to return it to the factory for some reason. But sometimes you'll be able to hang on to them.
  16. Apr 15, 2010 at 12:16 PM
    Cortland
    Cortland Well-Known Member
    Cortland
    California
    Clifford aka Big Red
    Camburg 4" Spindles, 5100's All Around, All-Pro 1.5" Leaf Pack, All-Pro U-Bolt Flip Kit, Avid Sliders, AFE Pro Dry Filter, Wicked Flow 18" Muffler
    Im jealous! I bought my truck used and it is out of warranty and doesn't have the rear TSB done :frusty:
  17. Apr 15, 2010 at 12:20 PM
    tacomakid89
    William
    Austin, Texas
    sorry to hear that man. just get the aal then. wont be free though. lol
  18. Apr 15, 2010 at 12:26 PM
    Cortland
    Cortland
    California
    That's why I'm pissed haha, I want a free lift. That and I hear the TSB only nets like 0.5" - 1.0" after settling and thats all I want....well at least for right now.
  19. Apr 15, 2010 at 12:45 PM
    tacomakid89
    William
    Austin, Texas
    well once i get this done then just trade me trucks. not. lol
  20. Apr 15, 2010 at 12:48 PM
    Cortland
    Cortland
    California
    I will not own another black car for a while, couldn't keep my last one clean here in AZ...so I guess I'll let you keep yours. :D
