getting ready to do change oils.
Discussion in '1st Gen. Tacomas (1995-2004)' started by fouillard13, Dec 26, 2012.
  1. Dec 26, 2012 at 2:46 PM
    fouillard13
    fouillard13 [OP] Well-Known Member
    Riley
    Canadia
    1998 tacoma 4x4
    I am changing my front diff,transfer case and tranny oil in my 98 Tacoma 4x4.
    I was wondering if i got everything I need and if there is any pointers that will help along the way.
    I got 2 bottles of redline mt90 for tranny. Tranny requires 2.2L so I will be short about 300 ml. I was going to add a little lucas stablizer to meet requirements. Is that ok?
    For the transfer case I got one bottle of pennzoil 75w-90 full synthetic GL4
    and for the front diff i got 1 bottle of Quaker state 75w-90 GL-5 full synthetic oil. It requires 1.15l of oil so I will be short about 150 ml of oil. I was going to top p the rest with some lucas stableizer.
    I am doing this tonight. I already did my rear. I would also like to grease my drive shaft zerks. Any tips? Just grease until it comes out?
    Thanks
  2. Dec 26, 2012 at 4:23 PM
    fouillard13
    Riley
    Canadia
    1998 tacoma 4x4
    Just got back from changing transfer case oil. I am leaking from the front of transfer case were the drive shaft goes in. Easy fix? I also noticed the transfer case i leaking at top? common problems?
  3. Dec 26, 2012 at 7:20 PM
    fouillard13
    Riley
    Canadia
    1998 tacoma 4x4
    I need to do this by the looks of it Leaking good to.
  4. Dec 27, 2012 at 1:12 AM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    I don't have any experience with the leaks you describe (and the advice is a little late if you're done), but using the right crush washers makes the job easier.
  5. Dec 27, 2012 at 10:48 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    Crush washers? It's a transfer case not a differential rebuild, there are no crush washers. Just the seal and the nut.. Pretty straight forward, or you could try adding some kind of Lucas sealant and pray the seal rubber swells up
  6. Dec 27, 2012 at 11:36 PM
    Norton
    The crush washers are used when changing the oil in the transmission, transfer case, and differentials, which is what the OP asked about in his first post. (It's also spelled-out at the link I provided.)
