Getting Ready to Install Longer U-Bolts on the Rear End...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by okie7481, Oct 2, 2009.
  1. Oct 2, 2009 at 8:31 AM
    okie7481
    okie7481 [OP] Okie Boy
    I have a 2006 Tacoma....A while back, I put a 3" suspension lift on it and in doing so, it caused the stock U-Bolts to be too short (not enought extra thread space on the ends of the bolts)....I had some custom U-Bolts made that are longer.....When I put those on, do I need to remove the rear wheels, or anything else for that matter???
    Thanks!
  2. Oct 2, 2009 at 9:16 AM
    Beefed Taco
    Beefed Taco Taco Vending Machine
    Brian
    My Metal Shop
    99 Taco
    streetacos.com parts!
    If you're spring over, you won't need to do anything but undo the old ones & install the new ones. However, rather than struggle under the truck, I'd do it right and use jack stands under the axle & remove the tires/wheels to make life easy. Definitely don't use lock washers with the new u-bolts and torque them to at least 70 ft. lbs. and paint the threads so they'll come apart easy next time. Torque your wheels too when done. How much did you pay for these custom u-bolts and I assume they are 1/2"..?
  3. Oct 2, 2009 at 9:18 AM
    okie7481
    Thanks a lot man, I appreciate your advise!!!!
  4. Oct 2, 2009 at 9:18 AM
    Rollinn
    Rollinn Well-Known Member
    Vegas
    06 Prerunner sport
    Icon 2.5 c/o,TC uca, bhlm mod, nav, etc etc
    x2
    as long as your not replacing a block or add a leaf etc, that all you have to do.. :D
