Getting ready to install...
Discussion in 'Suspension' started by drtydru, Apr 24, 2012.
  1. Apr 24, 2012 at 1:46 PM
    drtydru
    drtydru [OP] Well-Known Member
    Dru
    Oakland
    08 4x4
    Bucket seats, Variable speed wiper switch, 09 led Tail Lights, Satoshied front grill, DDM HIDs, Fog light install, Mud flaps removed, 1.5'AAL, Billie 1552, Toyotec front coilovers w/Billies, B.A.M.F welded sliders w/kickout,
    So I am getting ready to install a bunch of lift components and Im looking for advice and input on what Im about to do. I have an 08 regular cab 4x4 6 lug. Its bone stock right now except for the 17" stock wheels that replaced my standard 16"
    So here is what I have to install up front:
    Bilstein 5100s with Eibach/toytec coils set at 0 w/toytec 1/4" spacer.
    And in the rear:
    Bilstein 5125 (f4-be5-6248-h5) with 10.17" travel and eye-to-stem adapter
    I will be getting a leaf pack with a toytec 2" AAL from a friend
    All pro u bolt flip kit
    I know I will need to modify the bump stops.
    I want to make sure that I have everything I need to make this all work. I will be installing sliders and LCA skids so that will add a little more overall weight to the truck.
    Thanks
  2. Apr 25, 2012 at 3:49 PM
    drtydru
    Dru
    Oakland
    08 4x4
    Anyone, no one, everyone...
  3. Apr 25, 2012 at 5:12 PM
    sooner
    sooner Well-Known Member
    TX
    2011-4X4-LONGBED
    6-inch pro-comp lift-,n-fab 6 step nerfbars,extang touneau cover,go rhino grille guard,aftermarket fogs,3.5 driving lights,7-inch off road lights.pro comp skid plate,train horns,reese tow hitch,escort 9500ix,blend mount wireless radar mount.avs bug deflector and window vents,5%window tint.28-led back up lamps,sock monkey 3rd brake light decal,magna flow exhaust.klein train horns.nitro,nitro 4.56 gears,pro-comp traction bars,volant super scoop air intake.
    don't know about those lifts,have a 6-inch pro-comp.lol
  4. Apr 25, 2012 at 9:49 PM
    drtydru
    Dru
    Oakland
    08 4x4
    No worries man. Its not a lift package, per-say, its a hodgepodge of random lift components bought over the course of a year that I pray will all add up to a decent lift that fits my needs. Im just hoping it will all bolt up and wont give me problems lol
  5. Apr 26, 2012 at 1:42 AM
    Manwithoutaplan
    ID
    when taking off the stock shock get like vise grips or a very small wrench from having the shock just spin in circles.
  6. Apr 26, 2012 at 1:44 AM
    Manwithoutaplan
    ID
    also when trying to put in the new shock loosen the aligment tabs but dont take them out. see if you can take the shock out with out unbolting the lca.
  7. Apr 26, 2012 at 1:47 AM
    Manwithoutaplan
    ID
    Front
    top shocks bolts are 14mm
    bot shock bolt is 17mm
    lca connecting to the spindle is 19mm
    Aligement tabs are 19mm
    rear shock 17mm
    top nut on the shock 14mm
    ubolt are 19mm
    for the back make sure you have couple of c clamps
  8. Apr 26, 2012 at 1:54 AM
    krimson
    krimson Nothin
    TRD Off Road
    OME 3" lift with 885 coils. OME Shocks with TSB 1.5 AAL. 285/75/16 KM2s. XD Hoss 16" wheels. DDM Tuning 6000K HIDs, H10 6000K Fogs. BHLM. Debaged. 20% tint on front windows.
    If you have a ball joint remover laying around use it... It will be a lot easier taking the strut out and put the new one in with having the Tie Rod disconnected.
  9. Apr 26, 2012 at 2:09 AM
    Manwithoutaplan
    ID
    that is true but you might end of damage the tie rod boot, if you have ball joint remover.
  10. Apr 26, 2012 at 2:16 AM
    krimson
    krimson Nothin
    TRD Off Road
    Never had a problem damaging the boot with one. I used one on my truck and had no difficulties with it...
  11. Apr 26, 2012 at 2:31 AM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    I remove the tie rod and was real easy after a couple good wacks on the knuckle that holds it. Double check those shocks because my 9.25" 5125's are just short enough with bump extensions. If the 10's are too long ill be selling mine soon.....hit me up!
  12. Apr 26, 2012 at 3:31 AM
    Rajas
    Rajas Member
    For the front I would recommend disconnecting the UCA and removing the sway bar. Worked well for me and there was alot of space to get the coil over out and new setup back in.
  13. Apr 27, 2012 at 9:36 AM
    drtydru
    Dru
    Oakland
    08 4x4
    Thanks guys. All the info should help it go a little smoother.
    As far as the components go, what have people done to raise up the bump stops? An is there a point that you can raise them too much?
  14. Apr 28, 2012 at 2:32 AM
    Manwithoutaplan
    ID
    why do you need to raise the bump stop??? YOu could always get the bumps from wheelers.
  15. Apr 28, 2012 at 10:00 AM
    drtydru
    Dru
    Oakland
    08 4x4
    As far as I know if the shocks are too long they will bottom out before hitting the bump stops, and potentially explode. But seriously the shocks can be damaged if they bottom out too hard I think.
  16. Apr 28, 2012 at 10:04 AM
    acdronin
    acdronin Well-Known Member
    The AAL will probably prevent the truck from ever hitting the stock bumps anyways, think wheeler's has bigger bumpstops
