getting ready to lift my truck...
Discussion in 'Suspension' started by rvcahawaii808, Nov 18, 2009.
  1. Nov 18, 2009 at 3:59 AM
    rvcahawaii808
    rvcahawaii808 [OP] Well-Known Member
    cameron
    beaverton
    04 limited T4R 4x4
    going to take this in steps only because i can only buy so many parts at once. been reading alot of these threads just got a few of my own questions that im still confused on.
    1. should i start with the front 5100s since that will at least level my truck, and at what setting would that be?
    2. for the 3" lift that everyone seems to have (which i think looks great) what setting do you put your 5100s at, and what kind of lift do you do for the rear? (i dont have tsb done)
    3. i think the rear 5100s are just for better ride quality? so do i need them or could i just put on an AAL once i get the money?
    4. at what height do i need to get new UCAs?
    is there anyone near corvallis? or around oregon that could help me install it once i get everything together?
    thanks
  2. Nov 18, 2009 at 4:10 AM
    AzogSS
    AzogSS Well-Known Member
    Andy
    Soda City, SC
    2008 Tacoma / 2011 FJC
    Subscribed
  3. Nov 18, 2009 at 4:22 AM
    gupster88
    gupster88 Well-Known Member
    Brett
    Almost Heaven, WV
    2021 Cement Grey Off Road
    Stock
    1. since you have the regular 3 leaf non tsb pack set them at .85" and you should be good
    2. the 5100's will only give you a max of 2.5" of lift. i'd get a 1.5" aal in the rear to level at the truck at that height.
    3. yes you are correct, rear 5100's do not lift the rear, just provide for better ride quality. they are not NEEDED but i would recommend them if you put an aal on the rear.
    4. usually they say anything over or at 3" you should get aftermarket uca's. some get them with bilstein's at 2.5" but its a hit and miss. i personally would recommend them but wait and see if you can get the truck aligned to specs first without them.
    sorry, but im on the east coast
  4. Nov 18, 2009 at 4:28 AM
    rvcahawaii808
    cameron
    beaverton
    04 limited T4R 4x4
    thanks man, so i could just put on the front 5100s now at .85, then once i get to it i could do aal, then rear 5100s. with that 1.5" aal you set the 5100s at 2.5"?
    forgot to ask earlier but i can run the 5100s with my stock coils?
  5. Nov 18, 2009 at 4:31 AM
    gupster88
    Brett
    Almost Heaven, WV
    Stock
    yes you can do that for now, then lift it up more later. thats the best thing about the 5100's, their adjustability!
    it is actually recommended you run your 5100's with stock coils especially if you plan on lifting the truck with the 5100's. if you get, for example, ome 884/885/886 coils you should set the 5100's at 0" and lift it that way. if not you are going to have a way harsh ride.
  6. Nov 18, 2009 at 4:39 AM
    rvcahawaii808
    cameron
    beaverton
    04 limited T4R 4x4
    when i do go ahead and do the 3" lift do i need to get new coils or could i simply jack up the 5100s to 2.5" and put on the AALs.
    sorry if my questions seem repetitive just wanna make sure im buying the right things. im probably gonna order the front 5100s now from downsouth
  7. Nov 18, 2009 at 6:06 AM
    gupster88
    Brett
    Almost Heaven, WV
    Stock
    if you want a full 3" you need to do a different kit. but if you want a 2.5" lift then jack the 5100's up to 2.5" and add the 1.5" aal for a level look. if you want a little bit of rake get a 2" aal.
    good move on gettin the 5100's from downsouth. if you order the set of 4, you can get them shipped to you for around $282 if you use the discount code BIL0509 when you checkout. make sure you register or whatever to get that code to work.
