Getting ready to order OME 3" kit
Discussion in 'Suspension' started by DblstuftTaco, Apr 5, 2010.
  1. Apr 5, 2010 at 1:25 PM
    DblstuftTaco
    DblstuftTaco [OP] Well-Known Member
    Joe
    Ohio
    02 TRD SR5
    OME 3" Kit New frame
    I have a 02 dbl cab 4x4, I am getting ready to order the OME 3" kit from Toytec. My question is on the front coils. I have a factory bumper, but am going to put on a bull bar from Westin. Should I go with the 881 coils or the 883 coils (additional 100lb front weight) ?? I realize the bull bar wont weigh 100lbs but didnt know if it would be better with the stiffer coil over time. ANy help would be appreciated
  2. Apr 5, 2010 at 1:39 PM
    DblstuftTaco
    Joe
    Ohio
    02 TRD SR5
    Also whats the difference in n85 (normal valving) and n94 soft valving
  3. Apr 5, 2010 at 5:56 PM
    DblstuftTaco
    Joe
    Ohio
    02 TRD SR5
  4. Aug 31, 2010 at 6:15 PM
    malander
    malander That's some tight butthole
    max
    Missouri
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    im going to run 883's on my double cab iirc someone put these up front and got 2.5+ inches of lift. if your going to put a bumper on up front you may want to go 882 but idk its kind of on the borderline
