Getting ready to pull trigger on 285's
Discussion in '3rd Gen. Tacomas (2016-2023)' started by aleriance, Aug 8, 2018.
  1. Aug 8, 2018 at 6:50 PM
    aleriance
    aleriance [OP] Well-Known Member
    Jorge
    Naples, FL
    2017 TRD Off-Road 4x4
    CMC 285/70/17
    Found a set of 285/70/17 KO2's in the new C load rating for less than $800.
    Hoping to wrap these in a set of Pro Comp 5034 wheels which are 17x8.5 with 0 offset.
    (I'm not a fan of the look of 16's with a 33" tire and these are very affordable)
    I'm prepared to have an alignment done after mounting, as well as trimming fender or even CMC if it comes to it. Other than those things, is there anything else I should be prepared to do?
    My truck is running stock OR suspension and wheels/tires. I do not plan on lifting anytime soon. As far as avoiding rubbing as much as possible, am I good with the 0 offset wheel specs? Or should I look into more/less offset? back spacking?
    Thanks.
  2. Aug 8, 2018 at 8:04 PM
    eldedo
    eldedo voted most likely eaten by a bear
    Mojave Desert
    '16 DCSBOR 4X4
    2888/5100/Dakars 285's/Camburgs
    dont mind cmc or trimming, lol.
    don't plan on lifting.....rofl
    read the links in my signature, fully. Then go read a few build threads, any of them running 285's.
    then come back with some real questions. I'm not being an a-hole, just saying do some more reading before asking silly questions.
    kgarrett11, jeff b, drewhaus and 2 others like this.
  3. Aug 8, 2018 at 8:09 PM
    aleriance
    Jorge
    Naples, FL
    CMC 285/70/17
    Many have ran this size with no lift. Rubbing corrected with some fender work, CMC worst case scenario to my understanding. I don't think anyone here is in the business of making this stuff up?
  4. Aug 8, 2018 at 8:12 PM
    Radarninja
    Radarninja Safety 3rd
    Northern California
    06 taco
    Chromed out radiator cap
    I have +3.5 long travel, McNeil +6 fenders, cmc, ray10s, 285/75/16 and I rub like a fucking boss!
    kbp810, jeff b, krayon808 and 4 others like this.
  5. Aug 8, 2018 at 8:15 PM
    eldedo
    Mojave Desert
    '16 DCSBOR 4X4
    haven't seen one sans running glass fenders or cutting fenders, unless you want to do that then 285's will work. I however have hear of running 255's with stock suspension with trimming and other minor adjustments.
  6. Aug 8, 2018 at 8:16 PM
    Allstar780
    Allstar780 Well-Known Member
    Colin
    Alberta, Canada
    15 TRD Trail Teams Sport
    3" Lift, 32" Goodyear Duratrac, XD Series Hoss Rims
    Won't rub if you don't offroad... Or turn sharply into or out of angled approaches and driveways, or in reverse...
    If the suspension never flexes you'll never have rub that will be an issue... That's assuming you don't have mud flaps and are willing to trim some plastic and maybe bend a pinch weld.
    cleats50 likes this.
  7. Aug 8, 2018 at 8:22 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    That’s bullshit. Almost everyone has rubbing even with lift.
    The few that don’t are lying or never turn their wheels
    You will need +4 caster or close to it and your stock UCA won’t allow that. Though with no lift I’m not sure if it will have that much of an impact.
  8. Aug 8, 2018 at 8:23 PM
    aleriance
    Jorge
    Naples, FL
    CMC 285/70/17
    Out of real curiosity, why is it that being in reverse is an issue? I hear that quite a bit.
    The good ol "I only rub at full lock, full compression, dropping down the side of a cliff, balancing a coin on my nose... in REVERSE" LOL
  9. Aug 8, 2018 at 8:25 PM
    Allstar780
    Colin
    Alberta, Canada
    Just has to do with the vehicle leaning forward in reverse like how it leans backwards when accelerating forwards
  10. Aug 8, 2018 at 8:25 PM
    aleriance
    Jorge
    Naples, FL
    CMC 285/70/17
    sorgon82 likes this.
  11. Aug 8, 2018 at 8:26 PM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    Stock suspension, 33" tires, no rubbing. Man, wouldn't that be the life. I know I'll rub even with 888 coils providing me 2+" of lift...so I'm holding off for a bit until I can get new UCAs.
  12. Aug 8, 2018 at 8:29 PM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    They are lying or don't turn like Joe said
    I tried fitting with 1.5"lift and was hitting firewall at full lock same wheel spec you have.
    I had to go to 2.5"lift cmc beat pinch weld flat and trim plastic I still rub in reverse on the front bumper/fender liner.
    And I have 3.6 caster
    JoeCOVA likes this.
  13. Aug 8, 2018 at 8:29 PM
    JoeCOVA
    Joe
    Colorado Springs
  14. Aug 8, 2018 at 8:30 PM
    rpoint16
    rpoint16 Well-Known Member
    Tempe, AZ
    2022 TRD Off-Road, Super White.
    Bone Stock
    Post pictures when your done!!
  15. Aug 8, 2018 at 8:33 PM
    Joe23
    He's on here and ended up posting that it didn't work later hahaha
    JoeCOVA[QUOTED] likes this.
  16. Aug 8, 2018 at 8:34 PM
    JoeCOVA
    Joe
    Colorado Springs
    Haha good catch. Now that’s funny.
  17. Aug 8, 2018 at 8:35 PM
    Joe23
    Getting lucky and not needing CMC is one thing but no lift is not happening based on the issues I had.
    But there's no consistency with these trucks so who knows
    JoeCOVA likes this.
  18. Aug 8, 2018 at 8:36 PM
    Joe23
    Ya he said it still rubbed a lot off road
  19. Aug 8, 2018 at 8:36 PM
    Technique
    Alex
    Utah
    Yeah, OP can attempt it, but just know you'll more than likely have to get some sort of lift in there. They may 'fit' as in you can drive with them on...but you go over any sort of bump or take a turn quick..good luck.
    Joe23 likes this.
  20. Aug 8, 2018 at 8:36 PM
    aleriance
    Jorge
    Naples, FL
    CMC 285/70/17
    How do we feel about a 275/70/17?
