Getting Rear end TSB done..Question about Billstein 5100's
Discussion in '2nd Gen. Tacomas (2005-2015)' started by justPLANElane, Aug 24, 2012.
  1. Aug 24, 2012 at 6:17 PM
    justPLANElane
    justPLANElane [OP] Active Member
    Lane
    Dallas
    Trd off road dcsb
    I know this has been beat to death on this forum some where. I have been looking and can't seem to find the answers for my particular set up.
    I am getting the rear end TSB done to my truck in a few weeks. Was thinking of going ahead with some adjustable Billstein 5100's for the front to level the truck out. Then take advantage of the free alignment after the TSB is complete.
    My question is:
    Should I only get the front end Adjustable 5100's ? or go with all 4. I have a stock(at the moment) 2010 2wd DC TRD Sport. I know the TRD models already have Billstein shocks. I assume the ones that come with the TRD package aren't adjustable.
    What setting on the adjustable 5100s will level the front with the back after the TSB is done?
    Should i get all four?
    Or should I only get the 2 fronts done?
    Will it hurt anything to not get all four?
    Should i stick with the factory springs in the front or get some new ones? Advantages/disadvantages of the new/old springs?
    Sorry for all the questions....Thanks for any and all input/ info.
  2. Aug 24, 2012 at 6:27 PM
    TacoDawgfan
    TacoDawgfan Hunker Down You Hairy Dawg!
    Georgia
    2011 Silver 4x4 TRD Sport w/JBL
    5100's at 1.75, Rear leaf TSB, Moto Metal 951 16x8, BFG TKO2 265/75/16, AFe Stage 2 CAI w/pro dry filter, Kenwood DDX374BT installed with Idatalink Maestro kit, Access Loredo tonneau cover, N-Fab steps, Tinted windows, EGR in channel vent visors, UGA drink coasters in the front cup holders, and a Graco car seat in the back seat
    I've had the exact same thought as far as the alignment goes. But some have said they only align the rear. :confused: Also I think the 1.75 setting should be good but my understanding is it will be nose high with loads. I'm trying to decide the same thing though. Of course I have got to get the tsb done or approved first.
  3. Aug 24, 2012 at 9:33 PM
    Larry
    Larry CARL
    CARL
    get all four
    set the fronts to .85...this will provide the stance your truck had from the fctory pre TSB.
    the TSB raises the rear about an inch after setteling in
    the 5100's @ .85 raises the front about an inch.
    a little rake will be present w/ an unloaded bed or w/o trailer tonge weight. like the factory rake.
    it won't hurt to just have the fronts to make up for the tsb leafs. but the rears are inexpensive and can be installed in an hour w/o even removing the rear tires.
  4. Aug 25, 2012 at 6:10 PM
    Ostrichsak
    Ostrichsak Don't taze me bro!
    Jer
    Northern Colorado, USA
    Supercharged '10 Tacoma 4x4 TRD
    TRD Supercharger + too much stuff to list. Click sig pic
    I have the rear TSB and did all four 5100's and couldn't be happier. I'm not a serious off roader so for me I wanted to increase the height slightly, level it out and not sacrifice any road feel and off road ability. I feel like I accomplished this and sure I could have done better and spent more but for what I spent I'm quite happy with my results.
    For the record I have my fronts set to 1.75" and it's perfect visually even though the front is slightly lower than the rear if you measure them out.
  5. Aug 25, 2012 at 6:23 PM
    justPLANElane
    Lane
    Dallas
    Trd off road dcsb
    Thanks fellas, so what it sounds like is having the front set at 1.75 will pretty much level it and .85 will provide the same rake that the factory truck had but just a bit higher.
    Ostrichsak...did you get new springs for the front? or did you stay with the factory springs??
    i'm kind of going for the same set up as you man. What about when you have rear loaded up? do you notice that the front end sits a little higher??
    I don't do a lot of offroading either, i just like the look of the off road tires and on a slightly higher than stock truck. I'm not really trying to go climb a mountain or anything with my 2wd. Just want it to look cool.
  6. Aug 25, 2012 at 6:46 PM
    Ostrichsak
    Jer
    Stock springs. It sits lower when loaded but so did the stock setup. So does every truck. I still don't get why people would bother setting their truck up for how it 'looks' loaded unless it's loaded 24/7. Who cares? I pull a trailer and haul heavy stuff a lot but who cares? It's a truck. They squat when you use them like trucks regardless of if you set your front struts at 1.75" or 0.85". That 0.9" won't make a lick of difference unless you 'haul' tens of pounds around. I want my truck to look good as possible when not in 'work mode' and don't want to sacrifice this for a slightly better look when I'm hauling stuff.
    That's my take.
  7. Aug 25, 2012 at 7:08 PM
    TacoDawgfan
    Georgia
    Is yours a sport or off road? And you're saying it still rides about the same? I don't want to sacrifice the ride and have read mixed opinions about this. Of course I know the rear will be stiffer. (tsb or aal) And the sport and off road have different coils right?
  8. Aug 25, 2012 at 7:13 PM
    Ostrichsak
    Jer
    Off Road. It feels ever so slightly stiffer but I prefer the way it feels. More truck-like now and seems to handle better.
  9. Aug 25, 2012 at 7:40 PM
    TacoDawgfan
    Georgia
    So do you know the difference in the sport coils? My wife already complains about how rough the truck rides, if I make it worse......................:crapstorm:. :D
    But anyway, I thought I've read that the sport coils are actually stiffer? If that is the case then maybe I wouldn't feel any change? I know there is a thread on here where the op has a SR5 with Billies and hates how much rougher it rides. I'm just trying to get an idea of what to expect if I get the 5100's. Starting to think maybe I need to stay with the 3 leaf and level at .85.
  10. Aug 25, 2012 at 7:42 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    Offroad coils are progressive, sport coils are linear. So the offroad coils will ride stiffer when preloaded.
  11. Aug 26, 2012 at 12:04 PM
    justPLANElane
    Lane
    Dallas
    Trd off road dcsb
    So will I get a smoother ride by leaving the factory springs on with the 5100s or putting new springs on?
    If I should get new ones which ones should I get?
    Keep in mind that I only want to raise the front end enough to level it with the rear after the tsb is done. By doing that I shouldn't have to put new uca's on correct?
