Getting rid of Tacoma Lean? Whats the best way?
Discussion in 'Suspension' started by luk8272, Dec 5, 2009.
  1. Dec 5, 2009 at 5:11 PM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    My lean is getting unbareable. When parked it looks horrible. Even a Toyota Tech noticed it yesterday. I was considering getting some 5100's and having 1 side higher than the other, is that fezable? I know it would be slightly stiffer on the drivers side front but would it matter that much I live in a state with some of the worst roads. If you have a better solution let me know. I know Chris4x4 was going to make some spacers, should I go that route?
    General info
    *There is a 1/4" difference from Drivers side to Passengers.
    *I want to change the TRD shocks anyways.
    *It is a daily driver
    *I enjoy wheeling my truck when its possible. Scratches and dents to prove it.
    *It has a 3" lift already with TCA UCA's and blocks in the rear, Due to spring TSB
  2. Dec 5, 2009 at 5:15 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    What kind of lift do you have right now?
  3. Dec 5, 2009 at 5:19 PM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Southern Louisiana
    3"from Toytec, Blocks in rear because I got the TSB done and the lift installed before Toytec offered the AAL for trucks with the TSB. Front is 884 coils all shocks are TRD. I know those are the wrong Coils but its what I was sent and had not noticed until it was way too late, my mistake. However the truck sits well front to back but is off left to right.
  4. Dec 5, 2009 at 5:23 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I would get the 5100's as they are MUCH better than the OEM shocks. ALso, consider a 1/4" spacer from Toytec, to counter the driver side lean. :)
  5. Dec 5, 2009 at 5:30 PM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Southern Louisiana
    So you would go with the spacer to compensate. I was going to raise one shock higher than the other.
  6. Dec 5, 2009 at 5:32 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The only setting other than stock, is the .85". That might be too much. A 1/4" top spacer wont add anything to the spring rate on the driver side, yet should fix any lean you may have.
  7. Dec 5, 2009 at 5:33 PM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Southern Louisiana
    you da man!
  8. Dec 5, 2009 at 5:34 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  9. Dec 5, 2009 at 5:37 PM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Southern Louisiana
    They came out with all the cool shit after I got my TSB and lift done. ie: set of aal for use with tsb and the ultimate lift kit. Thanks for the input. The front coils are OME and 884 were supposed to be 885's. Toytec said they would be fine with the TRD shocks, and thus far have been great no complaints here just hate the lean. Ask the Jeep guys and the buggies in Hot Springs.
  10. Dec 5, 2009 at 7:02 PM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Southern Louisiana
    Damn those little spacers are expensive. $60 bucks for the kit, 2, 1/4 spacers with hardware.
  11. Dec 5, 2009 at 7:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :eek:
  12. Dec 5, 2009 at 7:09 PM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Southern Louisiana
  13. Dec 5, 2009 at 7:12 PM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Southern Louisiana
    I just noticed the 60 dollar item is a different part# and claims 3/4 of lift, with hardware.While the 1/4" spacer claims 1/2"for $20 with no hardware. That may better benefit those with 1"+ of lean where as I am only seeing a .25" lean.
  14. Dec 5, 2009 at 7:13 PM
    FlawedXJ
    FlawedXJ mall crawlin', web wheelin', concrete cowboy
    Paul
    NorAla
    13 F150 FX4, 99 jeep xj, 04 msm miata
    I actually have a jeep now. Imagine that.
    Ignore this post. I quoted and thought it said OME not OEM
  15. Dec 5, 2009 at 7:14 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  16. Dec 7, 2009 at 10:59 AM
    spearhead
    spearhead Taco Supremist
    Winston Salem NC
    09 4DR Mag Grey 4WD Sport
    TRD CAI Eibach Springs 5100s all around Front set to .85 Toytec AAL
    But the 5100 shocks do not have enuff top stud to add a spacer and attach too, do they? Maybe I'm confused....
  17. Dec 11, 2009 at 8:10 PM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Southern Louisiana
    ^ I don't have an answer for you so this is a bump to aid in finding the answer.
  18. Dec 11, 2009 at 8:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    If its a 1/4" spacer, you should have enough stud threads to attach the spacer. Anything over 1/4", and you need longer studs.
  19. Dec 11, 2009 at 11:34 PM
    drjohnson36
    drjohnson36 Well-Known Member
    09 Pre-Runner SR5 DC
    I have the 1/4" spacers with my lift.
    They do come with longer studs. You'll need a spring compressor in order to change the studs out.
