Getting Some Subs, need Help!
Discussion in 'Audio & Video' started by TacomaDrew, Feb 3, 2013.
  1. Feb 3, 2013 at 6:25 PM
    TacomaDrew
    TacomaDrew [OP] Member
    Andrew
    So Cal
    12 PreRunner XD Monster Wheels
    De-badged tailgate, 14" Antenna, Black Logo, Lifted 2.5", etc.
    So I have a 2012 tacoma with just the basic stock headunit, not the entune headunit. I want to get some subs but I know nothing about audio. If I want some subs, do I need to get a new headunit, subs, AND an amp? Or just an Amp and Subs? Also, what are some good choices that aren't too expensive. Thanks a bunch!
  2. Feb 3, 2013 at 7:22 PM
    bsb120
    bsb120 Well-Known Member
    Bradley
    Easley, South Carolina
    2016 DCLB TRD SPORT
    i went the cheap way and its not bad i got a 12" sub and box and 400 watt amp at walmart all for around 200. but you will also have to buy a wiring kit. i have installed subs in a couple of different cars, but all with aftermarket hu.
  3. Feb 3, 2013 at 7:55 PM
    eric3187
    eric3187 Well-Known Member
    you can hook up the subs/amp with factory headunit, just need to splice into the speaker wire to get the signal to the amp.
  4. Feb 3, 2013 at 8:01 PM
    Millertime187
    Millertime187 I'll be your huckleberry!
    David
    Clay City, KY
    1995 Taco
    Just a few little things. It's my DD
    You will prob have to buy a box that turn your speaker wires into RCA jacks for you amp. But you can install a system with factory head unit but won't be the best sounding.
  5. Feb 16, 2013 at 11:19 PM
    t.hornstra
    t.hornstra Well-Known Member
    Ted
    NorCal
    White with 4 wheels
    Little this. Little that 4x4 Swap’d PreRunner
    You need what's called a Line Output Converter.
    It splices into any speaker wires then converts it to RCA. These RCA's then go into your amp. It takes the speaker level input and bumps it up enough for the Amp to read and boost. From the Amp to the Sub, its just like any other system.
    You'll need an amplifier wiring kit, amp, speaker wire, sub and a box. Then your good to go!
    http://www.sears.com/shc/s/p_10153_...P&srccode=cii_17588969&cpncode=32-231189340-2
    Hope this helps.
  6. Feb 17, 2013 at 12:07 AM
    Mr. Biscuits
    Mr. Biscuits gentleman and a scholar
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    - OME 881s, Dakars + D43XL - Custom front tube bumper - 33x10.5R15 BFG KO2s - Deckplate mod + Airaid intake tube + AFE reusable air filter - Aero Turbine 2525 exhaust, chopped before leaf spring - Toyota Horns emblem by Diaz Fabrication - BOSS CarPlay head unit, 500W amp + 12" Pioneer in ported box - camper shell
    I'd probably check out crutchfield.com they have a lot of info and products. and EXCELLENT customer service. I've ordered a lot of stuff from them simply because I like the way they do business
  7. Feb 17, 2013 at 12:20 AM
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    Please dont buy a "line output converter" because you will be wasting all your money. LOC's are very extremely cheap and do the job, but you get what you pay for! There are better ways of getting the signal to the amp.
    I am an MECP certified install tech and have done thousands of systems. I also live in socal and do many installs for the local guys. Click link in my sig for more details. Feel free to PM me and we can discuss some options you have. The most important thing I need to know if I can help you pick the system that is best for you is your total MAX budget. PM me with that info on what your willing to spend, and we can figure out what your options are.
  8. Feb 17, 2013 at 1:06 PM
    Mr. Biscuits
    Brennen
    Eugene, OR
    2000 3.4L Prerunner
    Agreed you're gonna kick yourself for not doing it right the first time. When you upgrade a stereo system it's better to replace it all. Factory headunits have crappy output frequencies to the speakers and stock speakers are crappy at picking up all the ranges that a new head unit would emit. Plus you want a sub but without a preamp output you have to ghetto rig it with shit like line output converters. At the very least get a new head unit along with the subs.
