Getting stuck in Australia is not fun...
Discussion in '1st Gen. Tacomas (1995-2004)' started by Adam Baum, Apr 6, 2012.
  1. Apr 6, 2012 at 8:34 AM
    Adam Baum
    Adam Baum [OP] Well-Known Member
    PCS
    01 PreRunner SR5 debadged
    With that said...what should I look for in a winch? Never owned one and getting stuck in the middle of no where sucked. Good thing I had plenty of water and sun block :p
  2. Apr 6, 2012 at 8:39 AM
    Adam Baum
    PCS
    Oh...and how do I save weight on a winch? I have read a little about swapping out cables, but does that really save much? The post office will only ship packages less than 70lbs :(
  3. Apr 6, 2012 at 8:41 AM
    maxamillion2345
    maxamillion2345 Leaves the bay but brings all its problems
    Max
    Nevada
    80 series LC
    Tons and 40s
    synthetic cable will save loads of weight
  4. Apr 6, 2012 at 8:46 AM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    If you are going to rely on your winch, get a good brand, preferably an American made winch like Ramsey, Warn, and Super Winch.
    A lot of people like Smitty built, but they are made in China, FWIW... (its worth more to me than others)
    Synthetic cable will save you anywhere from 10-20 lbs. which is around 20% of the weight of the winch
  5. Apr 6, 2012 at 8:47 AM
    4x4Runner
    4x4Runner Now with more Oi Vey! Moderator
    Drunken Sailor
    Somewhere between Maine and Florida
    2017 4Runner Smashed Ass Edition
    KDSS
    100 feet of 3/8" Amsteel is about 3 1/2 pounds minus the hook. I know, I weighed it when I got it. A Warn M8000 with steel cable is 74lbs and same winch with synthetic is 55lbs. 19 pounds difference.
  6. Apr 6, 2012 at 3:15 PM
    Adam Baum
    PCS
    Any suggestions on who I should buy the winch with synthetic cable from? 3 of us need it out here at a minimum. I'm going out again today and hopefully will have plenty of pics.
  7. Apr 6, 2012 at 3:21 PM
    4x4Runner
    Drunken Sailor
    KDSS
    Just go and get a Warn M8000-s. The -s means it comes with synthetic already. Amazon, 4Wheelparts,
  8. Apr 6, 2012 at 3:31 PM
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    I got mine from warnoutlet.com they had the best price.
  9. Apr 6, 2012 at 3:37 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    For the 1st gen. rigs...
    I'd also recommend the Warn M8K w synth.
    It's about 44 - 46 lbs. mounted.
    I'd also recommend picking up a good snatch block
  10. Apr 6, 2012 at 3:59 PM
    Adam Baum
    PCS
    Can the same winch be used in the rear? I have seen pictures but wasn't sure how it would mount on the front with an ARB bumper.
    I don't have a tow hitch either but any suggestions on one would be great. I assume they are all the same hitch size? When I get back I will need to tow a UHaul cross-country.
  11. Apr 6, 2012 at 4:03 PM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB MGM
    Afe CAI (removed back to stock intake), TSB 4 leaf pack with Firestone Air Bags and Daystar cradels, 3rd OEM HU, Wranger All Terrain Adventure with Kevlar 265/75/16, Cali raised LED pods, Wheeler Off Road Front Bump Stops.
    The only way to use one winch at two different mounting locations is through the use of a winch hitch mount, but that means you'll first have to have a hitch receive in your front bumper and a rear tow hitch.
