Getting the most from the I4
Discussion in '3rd Gen. Tacomas (2016-2023)' started by NewMexiMan, Jun 27, 2020.
  1. Jun 27, 2020 at 9:09 PM
    NewMexiMan
    NewMexiMan [OP] Well-Known Member
    2016 SR 5 Speed
    Hi, I recently acquired a 2016 MT I4 4x4. I'm not interested in the I4 vs. V6 debate, I just want to get the best from the truck I have now. From the first few days of driving I feel that the I4 prefers higher RPMs. I'm not used to driving a truck with a four cylinder engine--I grew up driving a early 2000s 4Runner. It's clear I'll have to maintain higher RPMs if I want to haul any kind of moderately heavy cargo on even a minor slope. I want to know, how does the I4 hold up to being consistently taxed, both in the short term and in the long run? It feels like I'm going to put a lot of demand on the engine moving gear around hilly northern California. But it also feels like the engine wants to be worked and is made to operate consistently within the right RPM range, I'm guessing between 3500 and 4000. What's your experience? What happens when I'm running 4500 RPM up a mountain pass for 45 minutes? Thanks for your thoughts.
    AKGSD, Amanelot and t0nyvalenzuela like this.
  2. Jun 27, 2020 at 9:15 PM
    slow TURD I4
    slow TURD I4 Well-Known Member
    SD
    2018 DCSB 2.7
    The 2.7 is overbuilt so it can definitely handle some work. From what everyone says the 2.7 loves high rpm. My truck feels good at 3k going up an incline so I’d assume 3-4K is where the power really show on These motors. Some guys pull 4K rpm for a while And claim they have very high mileage with no issues.
    AKGSD and t0nyvalenzuela like this.
  3. Jun 27, 2020 at 11:00 PM
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    The 2.7 is tried and true. You’ll be good for a long time with it
  4. Jun 28, 2020 at 5:42 AM
    JNG
    JNG Shitposter extraordinaire
    2019 Silver TRD OR DCSB 4x4 AT P&T
    2.7 is a well built and durable engine. All is good. Don't worry about it. Maintain your truck as suggested by Toyota in the owners manuals and enjoy your truck for a long time. Welcome to TW.
    CusterFan and Chew like this.
  5. Jun 28, 2020 at 6:02 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    While the 2.7 4 is considered a great motor...imo what was toyota's thinking using this motor in a taco this heavy now. It should have been a turbo. The v6 3.5 is bad enough.
  6. Jun 28, 2020 at 6:06 AM
    Running Board Man
    Running Board Man Well-Known Member
    If you were used to an early 2000s 4 runner youre used to this my 4 runner likes high rpm
  7. Jun 28, 2020 at 6:59 AM
    P-Dawg
    P-Dawg Factory 2 Seater
    Pete
    Chicago
    2020 SR AC MGM Utility Pckg.
    The 2.7 is probably the last motor you have to worry about revving up and running hard, they are overbuilt and under tuned. Besides, the V-6 also has to be revved up to make power as well so no need to worry.
    AKGSD, specter208 and t0nyvalenzuela like this.
  8. Jun 28, 2020 at 8:50 AM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    Like you said, the inline four cylinder engine has a sweet spot in terms of the transmission. I’m at 22k miles with mine and it does not have the best acceleration but once I reach 2-3 gear and 40 mph, it drives great.
  9. Jun 28, 2020 at 8:54 AM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    I've seen 3RZ 4 cyl's easily make 1500hp
    Running Board Man likes this.
  10. Jun 28, 2020 at 9:20 AM
    jmauvais
    NorCal
    ...stuff
    :confused::confused::confused:
    davidstacoma likes this.
  11. Jun 28, 2020 at 9:29 AM
    IEsurfer
    IEsurfer Well-Known Member
    Socal
    I had 2k lbs on my bed before...just because you can do it doesn't mean it should be done. The 4 banger is a great motor but once you lift and put bigger tires you really are asking a lot from it especially since the 2nd and 3rd gens are a lot heavier than the 1st.
  12. Jun 28, 2020 at 10:54 AM
    NewMexiMan
    2016 SR 5 Speed
    Thanks, everyone. Really appreciate your thoughts. I've seen some threads on here about how to get more power from the I4, but what about reducing the weight of the truck? What changed between the 2015 and 2016 models that made them so much heavier? Is there anything that can be easily lost from the truck to make it less tubby?
  13. Jun 28, 2020 at 11:03 AM
    Fleischwagen
    Fleischwagen 2.7 > 3.5
    North Jersey
    2017 SR 5MT 4X4
    5.29's, ARB locker, 6112/5100, Deaver AAL, LCE Header, aFe dry-flo filter, Hurst/Core shifter, CBI T3 Front, Warn Winch, CB/UHF Radio equipment, Backrack, KC fogs and spots
    Just about the only thing that is going to make any sort of noticeable difference for the 2.7 is going to be the header from LCE. It shifted the powerband down slightly making it way more livable for me at least. Cruises on highways with minor grades much easier, especially if you're moving pretty quickly in 5th, if you're near the speed limit, 4th feels like more than enough.
    davidstacoma, AKGSD and LocoLocal like this.
  14. Jun 28, 2020 at 11:11 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    High strength steel, safety equipment so I doubt you are going to be able to lose enough weight to make any noticeable difference.
    AKGSD and CusterFan like this.
  15. Jun 28, 2020 at 11:11 AM
    Amanelot
    Amanelot Member
    Texas
    2016 MGM TRD Sport DCSB
    Stop worrying and just drive it. Itll be fine for a long long time
    CusterFan likes this.
  16. Jun 28, 2020 at 11:24 AM
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Let that engine rev up and let the trans do its thing. Do your oil changes on time with good oil and you are fine.
  17. Jun 28, 2020 at 11:31 AM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    driving any vehicle in the best torque range wont hurt it
    ' peak torque ' occurs when the Best Efficient filling o the cylinder
    followed by the Best ignition
    the most robust efficient ' Bang ' occurs at ' Torque Peak ' in an engine
    if it aint runnin right at Torque Peak ............. Park it !!!!
    most vehicles /engines have a broad torque plane
    whereby the engine pulls / performs at its best
    that would be between 2200rpm & 3200 for the i4
    any higher & torque trails off
    many think & buy in HP is king
    actually HP is Not an indicator how efficient an engine is
    good luck
    AKGSD likes this.
  18. Jun 28, 2020 at 1:51 PM
    Running Board Man
    Not really the frame, body, suspention, axle and such are the same so the weight difference is in the interior and sheet metal
    3rd gens have open c channels in the middle so maybe its a tad lighter
  19. Jun 28, 2020 at 2:23 PM
    ROAD DOG
    FEW
    weighed my stock 19 certified scale
    2300 front/ 1700 rear
    driver included
    Unfortunately much of the negatives about i4 performance or lack thereof
    essentially is a direct result of Toyota toeing the line on EPA mandates
    power is easy
    the RAV has a similar engine 50 more HP
    its not that an increase cant be had
    there are hurtles & Restrictions
    USA doesnt have the Diesel............... i truly want
    more Torque
    Better fuel mileage
    borderline emissions...................
    damn good truck
    many will continue to lament
    yet little will change.................. California just mandated battery power
    o well..............
  20. Jun 28, 2020 at 2:58 PM
    STi and Taco
    STi and Taco Not a Super Hero
    Steven
    Georgia
    '16 Tacoma SR 4x4 Access Cab Black, 2012 Subaru STi Hatchback Black, 1995 Acura Legend L Gold (RIP), 2020 Corolla Hatchback
    Diode Dynamics LED Inerior Lighting https://www.diodedynamics.com/by-vehicle.html?no_cache=1&find=2016-toyota-tacoma-115242 Hella Supertone Horns Some Joe Schmuckitelli Keyless Entry Intermittent Wiper Mod - Thanks to @moe2o4 Cruise Control Mod - Thanks to @moe2o4, again Anytime Back-up and Front Mount Camera Mod - Courtesy of @Logistics91 (amazing customer service helping me get it just the way I wanted it set up) Drawtite Class IV trailer hitch with 7/4 pin connector and P3 Tekonsha Brake Controller RokBlokz Mud Flaps Access Cab Rear Seat Storage Mod - Thanks to @Cagedodger for the original idea. Just modified it to fit my needs. https://www.tacomaworld.com/threads/access-cab-storage-organization.453774/page-4#post-17877877 Method 701 Black Wheels 265-70r17 Nitto Ridge Grapplers Fumoto Drain Valve Weather Tech Floor Liners and Side Window Deflecors Tuxedo TruXport Bed Cover Access Cover Motion LED Light Strip. Mounted 2 in the bed. Air Dam Delete Demello Off-Road Overlander Aluminum Winch Bumper with Baja Hoop and Squadron Sport LED Spots Warn M8000 Winch Silex center console organizer and tray Full Bed and Under Hood LED Lighting A/C Condensation Drain Relocation Rostra Front Heated Seats aFe Power 51-82722 Magnum FORCE Stage-2 Si Pro DRY S Cold Air Intake System (Part #51-82722) Prolightz clear LED fog lights w/ lamin-x overlay Red line Hood struts Diode Dynamics Hi/Low beam HID conversion kit MesoJDM 4 switch cubby panel, 7 switch Center panel and Center console Coin Holder @mesojdm Carhart Gray Front Seat Covers Curtis Class IV receiver B&W Tri-ball hitch King 2.5 Front Coilover/Rear Shock 25001-119/25001-121 Coming Soon: Differential Breather Relocation Mod New tires, can't decide
    Max HP is ~5100rpms, Max Torque is ~3700rpms. Just let it rip and quit worrying about it. It's as bullet proof of a motor as you are going to get. The motor's design basically hasn't changed since it was introduced in 1994. Still solid. Most people who think the 4cyl sucks don't know how to drive a 4cyl auto despite the lack of need for a rocket science degree to figure it out.
    Rev it to the max and never look back.
    davidstacoma, JNG and Amanelot like this.
