Getting through firewall??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by lilldill, Nov 28, 2015.
  1. Nov 28, 2015 at 7:21 AM
    lilldill
    lilldill [OP] Well-Known Member
    Dylan
    Myrtle Beach
    2016 White TRD Sport
    Trying to wire my PA system to my CB and need to get through the firewall. anyone done this already and what's the easiest way to do it
  2. Nov 28, 2015 at 7:48 AM
    Coolerman
    Coolerman Well-Known Member
    Dan
    Rochester, NY
    2005 4x4 SR5 AC / 2007 4x4 FJC / 2021 Tesla Y
    Pro/2015 Coil-overs n shocks, Icon progressive AAL, Firestone Ride-Rite Air Bags and cradles, ECGS clamshell bushing, Extang Solid Fold Tonneau cover, 2014 Navigation radio and backup camera, Wet Okole seat covers, rcbs204 lighted 4x4 switch, Weathertech digifit floor mats and in channel window vents, Scanguage II, Hayden 678 Trans cooler, Western Suburbanite plow, Pop and Lock PL8521
    There is a small rubber plug that can be removed to gain access. It is up behind the glove box. IMG_0131_55b2bfc6c127d0472c35fd9e5c0a4af66e6fa20d.jpg
  3. Nov 28, 2015 at 12:27 PM
    lilldill
    Dylan
    Myrtle Beach
    thank you, can't find it but will keep looking lol
  4. Nov 28, 2015 at 12:39 PM
    lilldill
    Dylan
    Myrtle Beach
    found the plug, pushed the wire through, can't find the wire. lol
  5. Nov 28, 2015 at 12:46 PM
    Fitz235
    Fitz235 Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
    You might want to run that wire through the grommet. It'll protect the wire from chafing, and keep water out of the cab.
  6. Nov 28, 2015 at 12:50 PM
    lilldill
    Dylan
    Myrtle Beach
    how would I do that?? very new to trucks and wiring lol
  7. Nov 28, 2015 at 12:50 PM
    lilldill
    Dylan
    Myrtle Beach
    cooler man, do I need to make a hole through the gray carpet material to push the wire through??
  8. Nov 28, 2015 at 12:57 PM
    Fitz235
    Rob
    New Hampshire
    You could make a tiny cut (ideally smaller than the wire going through it) and in the case of that particular grommet, push it through. I normally would use a thing called a "fish tape" (at least a piece of one). The end of those are sharp enough to poke through rubber. Tape the wire to the other end, and pull through.
    You could probably just push the wire through the one your looking at though. You want the hole to be smaller than the wire to keep the seal. Obviously the rubber will stretch enough around the wire to let it pass through. if it's too tight, put some silicone (a tiny amount) on the wire before it gets pulled through. This will lube the wire, and further seal it.
    ZachPrerunner likes this.
  9. Nov 28, 2015 at 7:04 PM
    Coolerman
    Dan
    Rochester, NY
    Yes
  10. Nov 28, 2015 at 8:17 PM
    Strazz
    Strazz Active Member
    Anthony
    Tampa, FL
    2025 DCSB TRD OR
    I use a metal hanger to get through the grommets and then seal it with liquid electrical tape. I ran power for a ham radio through the driver's side grommet and the wires for a power tailgate lock through the passenger's side. The hanger makes it easy, but it helps to tape at least six inches of wire so it doesn't slip.
  11. Nov 29, 2015 at 12:56 PM
    lilldill
    Dylan
    Myrtle Beach
    thank you all, got it working ended up going through the plug under hood.
    Fitz235 likes this.
