Getting tires to clear sticky mud?
Discussion in 'Off-Roading & Trails' started by tacouk, Aug 1, 2017.
  1. Aug 1, 2017 at 6:39 PM
    tacouk
    tacouk [OP] Well-Known Member
    David
    Truckee, CA
    Ram 1500 Rebel, (sold) 2017 DCLB TRD Sport 4x4
    Last weekend I made a trip up to Bodie, and got caught in a storm on the Bodie Masonic dirt road. Parts of this were gravel, so no problem, but some parts seemed to be more like a sticky clay.
    This was fine to drive dry, but once it got wet, it was sticking to my tires in a layer about 1.5 inches thick! I had to crawl along a flat stretch in 4-lo road because the rear end was slipping around so much.
    At the time I attributed this to my stock Toyo tires - I have a TRD Sport, so they aren't all-terrain. Thinking about it some more, I wonder if my driving technique (novice) made things worse.
    What's the best way to drive this kind of sticky mud on a relatively flat and smooth dirt road?
    ChadsPride likes this.
  2. Aug 2, 2017 at 7:13 AM
    Cold_Toad
    Cold_Toad Well-Known Member
    You'd need a tire that can clear the mud from between the treads more easily. But with that said the treads won't clear in sticky mud if you are crawling along, you need a bit of wheel spin to help throw the mud out of the treads. Not sure if it's actually the proper way to do it but I've always done small bursts of throttle to spin the wheels and clean out the tires but stay a manageable speed for the terrain, if it's flat smooth road speed can be your friend.
    ChadsPride and tacouk[OP] like this.
  3. Aug 2, 2017 at 3:15 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    I guess it kind of depends on what you mean by "sticky" mud. I've seen mud that is essentially like thick glue, and sticks to *everything*, super cool high tech mud tires be damned.
    I've also had to get out and take a shovel or stick and clear the mud away because it was filling up the wheel wells.
    Not really sure there is a "best" method for dealing with mud, except just getting *really* dirty...
  4. Aug 2, 2017 at 5:40 PM
    tetten
    tetten Cynical Twat Waffle
    Andy
    Socal
    Some types of clay (maybe all, but my wet clay driving experiences are limited to southern Utah, I had MT tires both times in wet clay) will stick no matter your tire tread. As far as I know the only way to clear it is to spin the tires once you get out of the clay. As you experienced, when the clay sticks to the tire they turn into donuts and you start to fish tail. A lot if clay roads to Utah/Arizona have a sign that says "impassable when wet"
    Pro tip: wet clay shelf roads are suicidal :thumbsup:
  5. Aug 2, 2017 at 6:31 PM
    mynewtoy
    mynewtoy I like men
    greg
    Mississippi
    09 double cab 4x4
    Detriot locker rear ARB air locker front 4.56 gears OME 3" lift, SPC uca's , moto metal 951 wheels 315/75/r16 Treadwright guard dogs, homemade front plate bumper with smittybilt 9.5k winch, homemade skids, homemade Bed bars, Mobtown offroad high clearance rear bumper with tire carrier, Homemade rock sliders , U-bolt flip, Wheeler's super bumps, BORA 1" wheel spacers , Black headlight mod , black tail lights, Satoshi Grill , autoPage C3 RS-665 alarm with remote start, flowmaster 40 series exhaust, cruise control,bed/ground effect lights, wet okole seat covers, tinted,windows, weather tech floor mats, AVS vent shades, debadged, hidden cobra 19 cb, 7" offroad lights behind grill, rear diff breather relocate, abs kill switch
    Best pro tip ever.
    Like others have said. Spinning the tires is the only way to clear mud out of the tread.
    When I drive in clay like that I just keep a steady momentum. if I start to slip or slow down up a hill I give it some gas. if that don't work give it more gas.
    Pro tip. When in doubt power out
  6. Aug 2, 2017 at 7:58 PM
    tacouk
    David
    Truckee, CA
    Thanks everyone! I think spinning the wheels to clear everything would definitely have helped. I pussied out once I fishtailed and slowed right down :(
  7. Aug 3, 2017 at 9:31 AM
    jbrandt
    Justin
    Here's my Pro Tip:
    "When in doubt, throttle out."
    Maybe avoid that on the shelf roads, though.
    tacouk[OP] and ChadsPride like this.
  8. Aug 3, 2017 at 12:57 PM
    tacouk
    David
    Truckee, CA
    It wasn't a "shelf" road, but if I had slid off then I would have needed pulling out by a wrecker. I would have taken a picture if I hadn't been so busy trying not to soil myself :bananadead:
  9. Aug 3, 2017 at 4:50 PM
    BKinzey
    BKinzey Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    You're not kidding.
    I just took a trip through Southern Utah. I was headed for Natural Bridges National Monument and stopped for the night off a gravel road on the road out to Bear Ears. Nice gravel road. Rained that night and I remembered the sign. Next morning, no problem. I side tripped and followed the road out to Bear Ears. Just after passing between the Bear Ears the gravel ended. :eek::eek::eek: o_O It was like trying to chase the Zamboni around the ice rink. Tires loaded up with mud and I slid from one side of the road to the other.
    I don't think I got 1/4 mile before I turned around. I wanted so much to get a pic but I needed to get out of there first so I didn't stop. "Impassable When Wet" was right. :bowdown:
    tacouk[OP] likes this.
