getting to the outside from the inside
Discussion in '1st Gen. Tacomas (1995-2004)' started by whatatoy, Aug 14, 2011.
  1. Aug 14, 2011 at 8:17 PM
    whatatoy
    whatatoy [OP] Galt/Rearden 2012
    SO CAL
    I like it
    This truck is a work truck - not a lot of fancy mod's here, but it's getting the job done!
    I haven't found the answer to my question... Can I fix the dent under my extracab window from the inside:
    I'm not going to be looking for showroom perfect - but if I could get it to look like door dings, I'd be happier than a pig in mud. And, I don't care too much about the paint because I'm going to be re-painting the truck in the next month hopefully.
  2. Aug 14, 2011 at 8:30 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    alternate spraying the dent with keyboard cleaner upside down (so it gets cold) and a hair dryer
  3. Aug 14, 2011 at 8:35 PM
    RAT PRODUCTS
    RAT PRODUCTS Raw Strength Equipment
    Farmington, MN
    Cummins Coal Rollin SOB
    Smokin with a smarty.
    Parking in the sun and using dry ice is 10x easier. But it probably won't work for this. But if I remember right the door skin is accessible from the inside.
  4. Aug 14, 2011 at 8:36 PM
    whatatoy
    SO CAL
    I like it
    does that really work? I ran across that technique, but then immediately ran across another video saying it works about as well as a tennis ball does at unlocking your car door...
  5. Aug 15, 2011 at 8:32 AM
    malander
    max
    01 limited trd 4x4
    It does but it might not on the more stout door sheet metal. And you can open doors of H2s and H3s with tennis balls pretty easily actually
