Getting TSB and 5100's
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SR54x4, Aug 20, 2010.
  1. Aug 20, 2010 at 2:34 PM
    SR54x4
    SR54x4 [OP] Well-Known Member
    Mark
    Hudson Valley
    2008 4x4 TRD SR5 Tundra
    Magnaflow 12588, TSC lo-pro extra deep toolbox, step bars and bull bar
    Ordered my 5100's from DSM last night and got approved for the rear spring TSB this morning. Everything should be here next week. Can't wait. Also going to order 265/75/16 duratracs this weekend. Planning on putting the 5100's at 1.75" for a nice leveled/slightly lifted look. This will all be on my 2010 SWB 4cyl 4x4 access cab. Pics will be posted as progress is made.
  2. Aug 20, 2010 at 4:03 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    This is the TSB and billys @.85
    I think the trucks look slightly nose high at 1.75.
    The 256/75R16 can fit without any lift,
    but look better and have extra clarence with the TSB / Billys
    going up to a 285 usually create's rubbing issues
  3. Aug 20, 2010 at 4:15 PM
    skistoy
    Western New York
    truck looks good
    Get the billys up front to level it out
    I suggest at.85 of coarse - haha
    how do you like the Duratracs?
    Love mine
  4. Aug 20, 2010 at 4:35 PM
    EricT
    EricT Well-Known Member
    Arizona
    '09 4x4 shortbed TRD Sport
    Im doing the same at some point, keeping the 265s so I dont need other suspension mods to get a decent alignment, and my gearing stays the same for mileage/speedo function.
  5. Aug 20, 2010 at 4:47 PM
    Larry
    Larry CARL
    CARL
    This is a great...simple...basic setup that gives the Tacoma the look it deserves.
    It's the setup I'm looking to go with.
    And the stance Toyota should offer stock. At least in the 4x4 platform.
  6. Aug 20, 2010 at 5:19 PM
    skistoy
    Western New York
    totally agree
    just enough lift
    the tires were the bigest improvement
    lets see some pic's after yours is done Larry
  7. Aug 20, 2010 at 5:27 PM
    Dark_Taco
    Dark_Taco ΜΟΛΩΝ ΛΑΒΕ
    08' TRD Rugged Trail Edition
    yer truck sits nice....I plan on doing the billys @.85 once I wear out my stock setup. Mine should look similar.
  8. Aug 20, 2010 at 6:12 PM
    Larry
    Larry CARL
    CARL
    Will do...man :thumbsup:
    I agre on the .85...and this has been widely discussed here.
    I think the rear TSB settles after a little use and then the 1.75 gives the truck that Obama, nose in the air, arrogance look. :p
    I'm a simple and humble man, so I'll probably go with the .85.
    Larry (clinging to his guns and religion) :D
  9. Aug 20, 2010 at 6:15 PM
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    Tip for you. When you put the 5100s on you are going to need an alignment. You are going to get a free alignment with your tsb, so put your 5100's on then roll that suck in the dealer for a free alignment. I also suggest 1.75, your rear is going to be pretty high after the tsb.
  10. Aug 20, 2010 at 7:50 PM
    EricT
    Arizona
    You mind linking me to the TSB you used? I ran through the sites TSB list and the only one for the rear suspension (in the list I saw) was 05-08, and the dummies at my local dealership won't even look at it without something including my year (09). Since you have a '10, I figured it was worth asking.
    You can PM me if you'd rather. Nice job getting that approved.
  11. Aug 21, 2010 at 4:37 AM
    KodiakVA
    KodiakVA Well-Known Member
    Richmond Virginia
    09 4x4 XCab Sport BarcelRed
  12. Aug 21, 2010 at 8:48 AM
    Chester
    Chester Well-Known Member
    Nor Cal
    07 Access Cab TRD-OR M-V6 4x4
    Rear Spring TSB,Locker Mod,In bed cargo lights,Fully de-badged,TRD Seat Covers,Trailer Harness Relocation,Painted wheels,Extra tie-downs,5100's,Biceman lighting,09 stereo with sirius & isimple ipod interface,Rear diff breather mod,K&N Air Filter
    Thats the set up I went with.
  13. Aug 21, 2010 at 9:00 AM
    EricT
    Arizona
    Thanks. I did search but I was only finding old (up to 08) docs, not that current once. Much appreciated. Hope to have someone looking at this next week, will be doing the same setup as well.
  14. Aug 21, 2010 at 9:21 AM
    SR54x4
    Mark
    Hudson Valley
    Yea I know they fit but they are stuffed in there. I want just a little bit of lift and not have to do any major trimming. The next size up would be 285's and they rub without trimming. Also the truck is a 4cyl so I don't want to choke the mpgs/power too much.
  15. Aug 21, 2010 at 9:27 AM
    SR54x4
    Mark
    Hudson Valley
    Yup Im going to do the 5100's first. The 2010's they only change the springs in the rear now. No new shocks, and the front is not touched. So normally they just do a rear alignment but I know someone who works in the service department and they said to just throw the 5100's on first then bring it in and she will have them do a 4 wheel alignment under the TSB :D
  16. Sep 20, 2010 at 3:57 PM
    klee07taco
    klee07taco Well-Known Member
    calfornia
    07 tacoma
    stock 07 tacoma db 4x4
    hi it looking nice truck lift front and back same level and what is your mersure front and back and billys front 5100 and .85 with stock oem spring ? how is ride ?
  17. Sep 20, 2010 at 4:14 PM
    lynyrd3
    lynyrd3 Strength ,Determination ,Merciless,Forever
    Bill
    Upstate New York ,Columbia County
    2008 SR5 AC SUPER WHITE V6 4x4
    Bilstein 6112s at top setting ,1/4" top plate spacer driver side,Total Chaos UCAs ,SS extended brake lines ,Rear 4 leaf Suspension TSB,Wheelers 2" AAL, Bilstein 5125s , SS extended brake lines rear , Toytec dif drop , Hayden high performance transmission fluid cooler,aFe pro dry filter , ,Powerstop drilled and slotted rotors.N-Fab light bar with 4 Hella OR lights , Devil horns by Andres ,Weathertecs floor protector, American Racing wheels Baja 17x8,4.5 BS , 285/70 Falken Wildpeaks AT/3W .Body Armor rear bumper . Extra D rings in bed ,Blue sea fuse block and 100amp breaker ,G-Tek Fab door sill protectors ,blacked out grille , painted pinch weld.Shorty antenna ,HVAC knob mod ,LED dome and map lights , Tri Fold bed cover ,UltraGauge ,Morimoto XB LED fog lights ,
    Just ordered my billys tonite.I have the sus.TSB done. Then its new rubber,Yokohama Geolander AT-S ,265/70/16 .And paint the stock rims black. Cant wait to get it done !
  18. Sep 20, 2010 at 4:44 PM
    skistoy
    Western New York
    Not sure of the exact measurements front and back
    I just wanted it to be level.
    billys up front at .85, rear TSB springs, everything else stock
    The ride got slightly firmer with the new TSB rear springs
    But the ride is nice, alot better when hitting pot holes, or dips in the road
    truck feels more solid, not squishy like before
