getting tsb rear done ?? about lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by coop1212, Aug 10, 2011.
  1. Aug 10, 2011 at 7:09 AM
    coop1212
    coop1212 [OP] Well-Known Member
    ms
    2010 TRD 4x4 double cab offroad
    none yet!
    stock 34 in in front and 35 1/2 rear now. tsb will add 1in to 1 3/4 . so what so i need to add in front as far as lift to make look right?
  2. Aug 10, 2011 at 7:13 AM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    i did the TSB about 1 year ago. at that time i also changed out all my shocks to Bilstein 5100's. The front shocks can be adjusted i set them to 0.85" of lift and it looks good. it still sits higer in back, after a few months the rear TSB springs settled down to just under 1" of lift.
  3. Aug 10, 2011 at 7:20 AM
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    09 Access Cab V6 4X4
    Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Goodyear Wrangler Duratracs, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings,... oh and the hot wife mod.
    With the TSB, Billies need to be set a 1.75" to be close to level. .85" will still leave her ass high.
    Without TSB .85 is level.
  4. Aug 10, 2011 at 7:22 AM
    CVYota
    CVYota Damaged Goods
    Andy
    Crescenta Valley
    '11 4X4 DCLB SR5 2.5 gen
    Been wondering the same thing. I am going with either eibach coils and 5100 set to '0' for 1.6 in lift or OME 885 coils and shocks for 1.75 lift. when the TSB settles more I will do an AAL in the back with new shocks. the 5100 route seems to be a little cheaper. Now if I could just afford new tires......:(
  5. Aug 10, 2011 at 7:31 AM
    iRepLONGBEACH
    iRepLONGBEACH SoCal Reppin
    SoCal
    10 MgM dcsb TRD Sport
    adjust billies depending on your rear leaf pack to level out
    w/ rear tsb= 1.75
    no rear tsb= .85
  6. Aug 10, 2011 at 7:38 AM
    Bolt79
    Bolt79 Well-Known Member
    White Springs, FL
    2011 Tacoma Sport 4X4
    265-70-17 Goodyear Duratracs. Pro Comp 17x8 8089's. Bilstein 5100's front and rear (front set to 1.75). 1/4 inch spacer--driver side. TSB rear leaf springs. WeatherTech floor liners. EGR in-channel vent visors. RDS tool box.
    Getting rear TSB done right now! Will be ordering billies later today and plan to set the fronts at 1.75. Also, having 17x8 Pro Comp 8089's with Duratrac 265-70-17's installed tomorrow!
  7. Aug 10, 2011 at 7:41 AM
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    I had the TSB done last week, and didn't get any lift out of them, well maybe a 1/4". The rear measured 36.5 to the bottom of the fender over the center of the wheel before.
    I'm putting the 5100's set at zero and the eibachs on this weekend.
  8. Aug 10, 2011 at 7:46 AM
    Fightnfire
    Marysville, WA
    Did you count the leafs and actually make sure you have 4 now instead of 3? I've heard of them doing this TSB and not actually swapping out the leafs. Going from an old 3 to a new 4 ... it shouldn't be possible to not lift the truck at least 3/4"
  9. Aug 10, 2011 at 7:57 AM
    SMKYTXN
    Nathan
    Houston
    DCFB
    Yup, it's the 4 leaf pack with much thicker leafs.
  10. Aug 10, 2011 at 8:00 AM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    FWIW , the TSB pack is 4 shitty leafs instead of 3 shitty leafs .
    It will get you 3/4" of lift after settling .
  11. Aug 10, 2011 at 8:30 AM
    coop1212
    ms
    none yet!
    so i need to wait and let rear settle after tsb gets done.then look into lift at later date. it will give me some time to save up anyway!
  12. Aug 10, 2011 at 8:42 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    As far as making it 'look right' you don't need to do anything. A lot of people have the TSB done and keep everything stock. It adds a little bit of rake but I didn't think it was too much personally. I was stock in the front with a TSB rear for almost 3 years and recently went with Eibachs and an AAL.
  13. Aug 10, 2011 at 8:47 AM
    TacoDawgs
    TacoDawgs Well-Known Member
    2008 Radiant Red DCSB TRD OR 4x4
    Front 5100s at 1.75. Rear TSB. LoRider tonneau cover. OEM bed mat. OEM bug deflector. Illuminated 4x4 switch. In cab AC outlets. 400W anytime. EGR in channel window visors. Black badges. Rear weathertech liners.
    I don't understand why my back end sits so much higher than everyone else. I'm getting the TSB done today, and before it measures 34'' in front and 36.5'' in back. I'll measure this afternoon to see what the TSB does to it. What could make me sit so much higher without the extra leaf pack? I don't think I have blocks in the rear but where would they be and how do I check that?
  14. Aug 10, 2011 at 8:57 AM
    Pugga
    Massachusetts
    F-150 Mod
    If you had blocks they'd be between the leaf pack and the axle.
  15. Aug 10, 2011 at 9:10 AM
    Bolt79
    White Springs, FL
    TSB properly completed. Definitely lifted the rear-end. Saw the invoice and it stated $1695.00 for parts, labor, and alignment. Wow! Can't beat that for free!
  16. Aug 10, 2011 at 9:46 AM
    upnadam
    upnadam Well-Known Member
    Adam
    Wilmington, NC
    11 PreRunner TRD Sport LB
    5100's up front, TSB, tinted windows, tail gate theft deterrent mod, fog lights anytime, de-badged, 7 pin relocate, AFE dry, Magnaflow
    It's TSB Day evidently. Mech on break right now it seems. Having them put 5100's I provided (thanks DownSouth) set at 1.75 also.
  17. Aug 10, 2011 at 10:47 AM
    Bolt79
    White Springs, FL
    Man, I wish I'd already had the 5100's...now I'll be paying extra for another alignment.
  18. Aug 10, 2011 at 12:09 PM
    TacoDawgs
    Thanks. I don't have blocks so does anyone have an idea of why I sit so high? I'm eventually gonna add 5100s and I was going to set them at 1.75 to level me out, but I may have to go 2.5 since my rear already sits so high.
  19. Aug 10, 2011 at 12:21 PM
    OZ-T
    Peter North
    British Columbia
    The truck has never had any weight in the back or been used to tow anything ?
    Measure centre of hub to underside of fender front and back , what you get ?
  20. Aug 10, 2011 at 12:37 PM
    TacoDawgs
    I haven't towed anything yet with it but I don't know about a previous owner. I bought it used a couple months ago. 2008 DC TRD OR 4x4 w/33k miles. I let you know the measurement when I get home from work. I measured before from the ground to the fender through the center of each hub and that's when I got the 34 front, 36.5 rear.
