Getting vibration at highway speeds. Rotors?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Aerose91, May 19, 2018.
  1. May 19, 2018 at 12:50 PM
    Aerose91
    Aerose91 [OP] Well-Known Member
    Connecticut
    07 TRD Sport 4x4
    I had a nasty vibration under acceleration so i replaced all 3 u joints on the rear shaft and now all is good. However, im getting a vibration when going over 60mph or so. This one feels more in the steering wheel than floorboards.
    I recently replaced the brake pads but when i took the old ones out they were worn really unevenly. Like, a 25% difference in pad wear between inner and outer on both sides with driver's side being worse. I'm wondering if i have stuck calipers and/or warped rotors. At 130k, should i just replace the rotors or if they can be turned, should i just do that?
  2. May 19, 2018 at 1:07 PM
    Grey 2015
    Grey 2015 Well-Known Member
    Skip
    Loxahatchee Florida
    2015 Tacoma
    Tire out of balance?
    AeroCooper likes this.
  3. May 19, 2018 at 1:10 PM
    Aerose91
    Connecticut
    07 TRD Sport 4x4
    A possibility but the uneven pad wear made me leary of the rotors or stuck calipers
  4. May 19, 2018 at 1:16 PM
    Clearwater Bill
    Billy
    Largo Florida
    Calipers may be sticking and need attention, but vibration at speed is much more likely to be tire/wheel issue.
    Just rotate the tires and see if the vibration moves
  5. May 19, 2018 at 2:29 PM
    Aerose91
    Connecticut
    07 TRD Sport 4x4
    I should get an alignment done anyway. f you rebuild a caliper, is there any assurance that that will fix a stuck piston?
  6. May 19, 2018 at 3:02 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Do you have any burning brake smells? Any smoke, like at stoplights?
    inwood customs likes this.
  7. May 19, 2018 at 3:07 PM
    maxtherat
    maxtherat Well-Known Member
    Inland Northwest
    2001 Dodge Ram 2500, 1993 Jeep Wrangler
    All the usual diesel truck mods- fuel system upgrade, programmer, CAI, intake manifold, 60MM stealth turbo
    My guess is the wheel bearings. Have heard they’re only good for like 90k
  8. May 19, 2018 at 4:55 PM
    Clearwater Bill
    Billy
    Largo Florida
    If it doesn't, it wasn't done properly.
    A very low % of folks rebuild their own calipers. Most buy reman units from parts houses and bolt them on. Nothing wrong with that either.
    Check prices on rebuild kits vs a warrantied caliper. You may feel it's not worth your time to rebuild.
    But again, this will do nothing for your shaking.
  9. May 19, 2018 at 5:01 PM
    Nomad_Pilot
    Nomad_Pilot I need to pewp
    Clay
    Ft Collins
    I just tried to rebuild and friends caliper a few weeks ago. You can't even order the kits anymore, a whole new caliper was $60
    Clearwater Bill and TacoJova like this.
  10. May 19, 2018 at 5:05 PM
    Exracer2
    Exracer2 Well-Known Member
    Colchester Ontario
    2017 TRD Off-Road Alpine White ACLB
    BRO grille, KICKER speakers, Key amp, Hideaway sub
    I would never rebuild a 4 wheel vehicle caliper. They are so cheap remanufactured and you can take them back if there is an issue. I have done motorcycle calipers a number of times but they are aluminum and powder coated and never see salt. The pistons are never rusted or gouged. All the things that can be an issue with a car or truck caliper. We aren’t even talking about slide pins yet.
    Now as far as rotors. If your issue happens when on the brakes maybe rotors. If it vibrates at speed and no brakes but when you apply the brakes it doesn’t get worse it isn't the rotors.
  11. May 19, 2018 at 5:27 PM
    Nomad_Pilot
    Clay
    Ft Collins
    I dunno if it's the cv needle bearing, but when my needle bearing gave up it would start vibrate bad at about 51 and quit and about 68, I didn't even really realize it till one day all of a sudden it let loose, and I had to limp home at about 20 mph max. Got the ecgs bushing, no more vibs.
  12. May 19, 2018 at 5:48 PM
    Aerose91
    Connecticut
    07 TRD Sport 4x4
    I did once but i think that was from the fronts. No smoke and neither coming from the rears
  13. May 19, 2018 at 5:58 PM
    AeroCooper
    AeroCooper Half the strength of ten (microscopic men)
    NH
    2018 Barcelona Access Cab Off Road
    Remote start, tailgate inserts, nifty key fob case, Husky X-Act floor liners, AVS vent shades, bed mat, MX4 Tonneau cover, Tyger step rails
    Almost certainly front wheels need to be balanced. Like mentioned, rotate them to the rear and if you then feel it more in the seat than the steering wheel you'll know for sure. That's most likely the issue and also the cheapest and easiest way to find out.
    Clearwater Bill likes this.
