Getting wiring through rubber grommet on the firewall?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Derrick2972, Jan 4, 2020.
  1. Jan 5, 2020 at 4:45 PM
    Derrick2972
    Derrick2972 [OP] Well-Known Member
    2016 Toyota Tacoma SR5 4x4
    I dont think the 2016 SR5 has that grommet.
  2. Jan 5, 2020 at 5:29 PM
    fatboyfirebass
    fatboyfirebass Well-Known Member
    2018 Blk TRD OR DCSB MT6 Prem/Tech Pkgs
    OV Tuned, S&B Intake, MBRP Dual black Cat-back, accumulator delete, URD SS, 2LM, SSO Hybrid bumper/Warn 10kSynthetic, Custom Car Grille, MESO Ultimate Turn Signal in KTJO Power Folding Mirrors, Genesis Dual Battery, BHLM with LED upgrade, Fog delete, Geko Bed & Underhood lighting, Rear camera anytime, Nav Block Override, 400W anytime w/ interior outlets, USB charging stations, DE-badged, TVD blackout kit, HiLux interior door handles, Hybrid SS/Delrin Shift Knob, Cali-Raised bed Stiffeners, Ultimate Tailgate Seal, "El Dorado" Dual-quad horns, Diamondback HD cover, Mobtown engine/trans skid plates, RCI control arm skids, JLT oil catch can, Meso overhead Hex rack.
    I'm not 100% positive you have it. I know it is on some models that have the brake booster. I learned about it from an installation video. It is just easier to see and get to on my OR since there is no booster. Here is the video.
    https://www.youtube.com/watch?v=RUiKfNhCyuA
    BOMBS likes this.
  3. Dec 31, 2020 at 10:58 AM
    nparent2147
    nparent2147 Well-Known Member
    Noah
    2016 Tacoma SR5 DCSB
    MLO Sliders TRD Pro Grill
    I can confirm that the 2016 SR5 has the small grommet , but it's almost impossible to access. The only access point through the firewall on the driver side is through the main wiring harness rubber "thingy". I just pulled the edge of the rubber over enough to feed my wire through. I will most likely cut a small slit in the edge to clean it up later.
  4. Dec 31, 2020 at 11:06 AM
    ajb7074
    ajb7074 Well-Known Member
    Austin
    Northeast, OH
    2021 Tacoma TRD OR DCSB Army Green (Incoming)
    Don’t cut any holes. Feed through the same hole that the hood latch goes through. I used a little bit of water on the wire and it slid right through.
  5. Dec 31, 2020 at 11:07 AM
    nparent2147
    Noah
    I had looked into doing that but my wires seemed too large and I didn't want to force it.
    ajb7074[QUOTED] likes this.
  6. Dec 31, 2020 at 11:24 AM
    The Bob
    The Bob Well-Known Member
    Bob
    Frontrange CO
    2015 AC SR5 4x4 6 speed, 2009 Lexus GX 470
    I just did this also. I ran the fish tape (or wire hanger) from the inside and pulled the three wires with terminals (for a switch) taped to the fisher, ONE AT A TIME. I could not get all three of them together. It's tight for sure.
