GFCI outlet tripping
Discussion in 'Garage / Workshop' started by wtjl240, May 21, 2021.
  1. May 27, 2021 at 2:57 PM
    #41
    PhenixFord
    PhenixFord Well-Known Member
    Randy
    Arkansas
    2019 MGM SR5 4WD DCSB
    Use caution here. Was the GFCI slaving the rest of the branch circuit?
  2. May 27, 2021 at 4:56 PM
    #42
    wtjl240
    wtjl240 [OP] Well-Known Member
    Jeff
    Spring Hill, TN
    The AC is on the next to last outlet of the circuit. The GFCI was the first outlet
    The 30 amp goes to my camper
    TXpro4X4[QUOTED] likes this.
  3. May 27, 2021 at 4:57 PM
    #43
    wtjl240
    Jeff
    Spring Hill, TN
    Yes it was the first outlet
  4. May 27, 2021 at 4:59 PM
    #44
    PhenixFord
    Randy
    Arkansas
    "IF" the rest of the circuit was being protected by the GFCI, you may have created another problem. Depends on where the other outlets are?
    This sounds reasonable.
  5. May 27, 2021 at 5:02 PM
    #45
    wtjl240
    Jeff
    Spring Hill, TN
    There are 7 total outlets on the circuit. The garage is a 4 car garage with a wall in the middle. On the photo with the breaker panel it's #7 with the M sticker
  6. May 27, 2021 at 5:04 PM
    #46
    PhenixFord
    Randy
    Arkansas
    So, the other 7 outlets are in the garage?
    Garage outlets "should" be GFCI protected. This is a "Life Safety" issue.
  7. May 27, 2021 at 5:09 PM
    #47
    wtjl240
    Jeff
    Spring Hill, TN
    So add the GFCI back and get an appliance extension cord? The next closest outlet on another circuit is about 20' away.
    There is a separate 20 amp, 240 volt outlet right next to where the AC is plugged in but I can't convert it down* right?
    *Shouldn't even consider/attempt
    Or run a new dedicated circuit?
  8. May 27, 2021 at 5:15 PM
    #48
    PhenixFord
    Randy
    Arkansas
    I would definitely say to restore the GFCI circuit back to original design.
    If the 240v circuit only feeds one single outlet, then this would be your best resolution. Depends on how you feel about rearranging the circuit inside the load center. #2 choice would be to use an appliance extension cord. #3 choice would be to void the warranty and remove the GFCI from the cord set.
    soundman98 and wtjl240[OP] like this.
  9. May 27, 2021 at 9:52 PM
    #49
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    As it is supposed to be.
    As stated above put the GFI back if you want.
    It's your world. Garage circuit is supposed to be protected. Shit happens in garage like a kitchen.
    The ac runs fine on an unprotected circuit?
  10. May 27, 2021 at 11:14 PM
    #50
    PhenixFord
    Randy
    Arkansas
    Post #28 /\ /\ /\
  11. May 28, 2021 at 4:18 AM
    #51
    wtjl240
    Jeff
    Spring Hill, TN
    It does run fine on the unprotected circuit but I'll reinstall the GFCI this evening. I'd rather have it than not.
  12. May 28, 2021 at 4:22 AM
    #52
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    This. Technically, any large load inrush/major appliance should not be plugged into a GFCI. Some local code writers are total idiots.
  13. May 28, 2021 at 4:25 PM
    #53
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    So get this, a newish code here is dishwasher is to be plugged into a gfi. Garbage disposal not...at least not yet
  14. May 28, 2021 at 4:26 PM
    #54
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    10-4
  15. May 28, 2021 at 4:58 PM
    #55
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    First thing I would try is removing that Chinese receptacle/USB combo outlet and see if it still trips the GFCI.
    Next thing would be to read up on using a GFCI in combination with that AFCI plug on the AC, especially the part about the neutral wiring.
    Scroll down to this link to the post “Theres More Going In Here Than You Think”:
    https://diy.stackexchange.com/quest...i-and-afci-breakers-combined-or-used-together
