Gf's focus -brake lights
Discussion in 'General Automotive' started by rab89, Apr 27, 2009.
  1. Apr 27, 2009 at 1:08 PM
    rab89
    rab89 [OP] Well-Known Member
    Ross
    Kelowna b.c canada
    2012 DCLB
    Grillcraft mx black upper and lower BHLM with Gloss black 265 70 17 bfg a/t center console light mini mag mounted in center console debadged bed lights 35W 5000k HID's
    Hey guys, so my gf has an 01 ford focus. I was driving behind her the other day and noticed her brake lights aren't lighting up. the tail lights are on, and brighter than they should be, but when she brakes they don't get any brighter.
    today we checked light bulbs, and fuses, but found nothing, my next though is a relay, but I'm not sure on how to test a relay?
    what else would you suggest? thanks!
  2. Apr 27, 2009 at 1:10 PM
    Rtrn2taco
    Rtrn2taco Nostalgia...
    Philadelphia
    08 DC PreRunner (silver)
    does the third brake light go on?
  3. Apr 27, 2009 at 1:40 PM
    OU812
    OU812 ban the term murdered out
    danusa
    Kilroy was here
    13 DblCab LB 4X4
    Nothing yet, brand new!
    If the tailamps are on and brighter than normal than the bulbs may be incorrect. Check those..
    Does the cruise work??
    If not check the brake lamp switch under the dash.
  4. Apr 27, 2009 at 2:07 PM
    JeffRock
    JeffRock Well-Known Member
    Capital region, NY
    09 Tacoma accesscab 4x4 SR5 2.7L
    Toyota all weather floor mats. Mag light that clunks around in the jack compartment. Dog hair. Dog drool on the windows.
    I'm going with the bulbs are in backwards. Seen this 1,00 times on semi trailers. there are two posts on the side of the bulbs, One is father from the base of the bulb than the other. the bulb should be inserted to the socket according to which hole is relevant to the posts on the bulb.
    not saying that is definitely it, but worth a shot to look.
  5. Apr 29, 2009 at 12:56 AM
    rab89
    Ross
    Kelowna b.c canada
    2012 DCLB
    yea, a buddy said prob the brake switch. i'll check bulbs too. thanks alot
