Giant Motorsports rear leaf
Discussion in 'Suspension' started by Specalt, Oct 12, 2011.
  1. Oct 12, 2011 at 7:48 AM
    Specalt
    Specalt [OP] Well-Known Member
    Phoenix
    2001 TRD 4x4
  2. Oct 12, 2011 at 7:54 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
  3. Oct 12, 2011 at 8:01 AM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    there are 2-3 people here running this kit
    MJP2
    rondog
    vitang (used to have it)
  4. Oct 12, 2011 at 8:03 AM
    Specalt
    Phoenix
    2001 TRD 4x4
    Thanks for the links.
  5. Oct 12, 2011 at 8:08 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    It's extremely stout but I'm having some minor rubbing issues with the kit. Granted, that only happened in a racing situation so your mileage may vary.
    I'm going to try swapping out the bushings for ones made from stiffer material and see how that works. I considered swapping to the DMZ solution but the time/effort/cost makes it impractical for me at the moment.
    They didn't offer the bolt-on option when I purchased the kit. That would have made the installation a whole lot easier.
    If you haven't made up your mind about a rear yet, consider Defined Engineering's solution as well as the DMZ kit. Mike from Defined is an active member here on TW and will answer any questions you have.
    http://www.tacomaworld.com/forum/members/defined.html
