girl trying to learn basic stick shift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SoCalGurl, Apr 14, 2009.
  1. Apr 14, 2009 at 7:44 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    Me too but i figured that suggestion was out of the question here haha
  2. Apr 14, 2009 at 7:49 PM
    CtryBoyInMT
    CtryBoyInMT Lifetime Member
    United States of America
    2008 4WD V6 Access Manual TRD Off-Road
    Tinted windows, Rear locker anytime, Secondary filter delete, Parking light activated Fog lights, USA▪Spec Ipod adapter, Map light mod, Relocated 7-Blade, Warn Trans4mer Brushguard & winch, Tire chains, Homelink© installed in headliner, LED lighted 4x4 Switch, Defrost w/o A/C, Heated mirrors, Bilstein 5100's (1.75") & Rear TSB, 50w Reverse lights, Pratt & Whitney PT6A-68, Will this list ever end???
    I sure hope this was a typo!!
    Un-necessarily wears the transmission synchro's if you don't use the clutch.
  3. Apr 14, 2009 at 8:28 PM
    TEX357
    TEX357 TX
    05 TACOMA
    285\70-17 BFGoodrich KM2's 17x8 Pro Comp 7089
    Welcome to TW!!!
  4. Apr 14, 2009 at 8:30 PM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    :wave:hello & welcome to TW!:wave:
  5. Apr 14, 2009 at 9:10 PM
    SoCalGurl
    SoCalGurl [OP] Member
    Irvine, CA
    08 PreRunner
    hey thanks for all the help guys. i wanted to ask you a question about your post. you say hit the gas to bring up the RPMS to about 2.5k. do i just hold my foot down so it stays at 2.5 then release the clutch slowing while applying more gas? if i try to take my foot off at 2.5k, it drops so fast. i just wanted to know if i should keep my foot on there to keep it there until i have time to change the lever to 2nd then take out the clutch. also, when i let out the clutch to complete the downshift, do i just do it very slowly? or do i have to do it slowly while applying gas? thanks!
  6. Apr 14, 2009 at 9:17 PM
    LOWLO7
    LOWLO7 Well-Known Member
    Lauren
    Bakersfield, California
    2008 lifted, white tacoma
    6" Fabtech lift, 17" Moto Metal rims, 33" Nitto tires [grille coming soon]
    hahahahahaha you guys are dumb.
    just help the poor girl out! :rolleyes:
  7. Apr 14, 2009 at 9:18 PM
    papabear050
    papabear050 Well-Known Member
    11 dc 4x4 TRD OR Auto
    You just have to blip it, hit and and let go... go to youtube and search for rev matching or downshifting.
    I wouldn't worry about any of that yet. Forget rev matching for now. Concentrate on using the correct gear at the correct time, focus on the basics and get to know your truck as well as practice your driving. Don't do too much too soon
  8. Apr 14, 2009 at 9:18 PM
    DanGer
    this would be SO much more interesting in the underground
  9. Apr 14, 2009 at 9:18 PM
    TL697
    TL697 Well-Known Member
    Jacksonville, FL
    '09 DC SB 4x4 TRD Offroad Magnetic Grey Met
    I agree... I tried to touch on the rev matching in my example...
    I can drive anything from a civic to an 18 wheeler and only have to use the clutch starting from a dead stop... If you are good at rev matching, you don't need the clutch to shift between gears... :cool:
    I don't recommend it unless you really know what you are doing...
    Tune in next week for my lesson on how to "double clutch"... ;)
  10. Apr 14, 2009 at 9:21 PM
    TL697
    Jacksonville, FL
    I'm not saying don't us the clutch... I'm saying don't push it to the floor board... Unless you want to replace throw-out bearings all the time...
  11. Apr 14, 2009 at 9:30 PM
    Swwacoma
    Swwacoma Doomsday Squad
    Estero, FL
    08 PreRunner SR5.
    You have to "see-saw" it...you want to take your foot off the clutch w/ the same force/timing as you are using to push down on the gas.
    Few things I used to get good at manual:
    *Find a church parking lot and just do laps (safely) as practice.
    *Never have the radio on when learning. Hearing your engine and being able to match the sound w/ the RPM helps a great deal. The more you hear it the more you get used to the best time to shift...plus I think its kinda dangerous to spend the entire time driving looking down at your gauges.
  12. Apr 14, 2009 at 9:35 PM
    TL697
    Jacksonville, FL
    good advice... no radio... listen to your truck... practice...
  13. Apr 15, 2009 at 5:56 PM
    grantfire319
    grantfire319 Well-Known Member
    KENTUCKY
    05 DOUBLE CAB TRD SPORT 4.OL
    Secondary Air Filter removal. More to come hopefully.
    :rofl::rofl:
  14. Apr 15, 2009 at 6:03 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    If you have troubles getting it in gear sometimes, ease off the clutch a little bit, or double clutch even, you'll find it easier.
    Either way, most of the main points have been covered, you'll be fine, just work on that feel for where the clutch engages, and not to add too much gas. Too much gas and you'll burn your clutch, too little and you stall, but I'm sure you've figured that out already. Your RPM needle should be a smooth transition when you shift, if its jerking, you're too rough with it. Sound good? Theres my tip for the day.. lol
  15. Apr 15, 2009 at 6:16 PM
    #35
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    while in 3rd gear at 2000K:
    1. let off gas
    2. step on clutch
    3. shift to 2nd
    4. tap gas until rpms reach 2500 and remove foot from gas
    5. as soon as rpms hit 2500, let off clutch in a normal fashion (if you let off too slow, then rpms will drop, and you will put wear on your clutch you engage it)
    Most important thing is practicing and getting used to what RPMs to rev to at different situations. For now, the most important thing to concentrate on is not stalling and not burning your clutch.
    One situation that you find yourself in is slowing down from 45mph for that left turn. What you might want to do is let off the gas, step on the clutch, shift to the gear that you will use after turning (2nd gear most likely), and brake to slow down, with the clutch still being stepped on. As you reach the speed you will be turning at, release the clutch semi-slowly as not to make the truck jump.
    If the truck slows down too much or makes too much noise as you let off the clutch, then step back on the clutch and shift to 3rd gear and try that.
  16. May 18, 2009 at 5:48 PM
    #36
    gearhead69
    gearhead69 Member
    05 Tacoma Pre
    Are you cute, and you drive a stick, sweeet. When stopped and it won't go into first, put it in second really quick then up into first. Start shifting down early, as long as your not reving it really hard your good. You'll save some break wear.
    cu
  17. May 18, 2009 at 8:25 PM
    #37
    06dak
    06dak Well-Known Member
    Central Ohio
    05 PreRunner SR5 4cyl
    Undercover hard tonneau, Husky front liners
    Don't worry about the rev matching yet...
    One thing you can do, as you coast down to stop lights, keep the truck in gear and shift backwards as you come to a stop. Play around with it until you get the feel for what seems smooth - just go from fourth, to third, to second, etc. You'll get it with practice. Don't worry about breaking anything. Unless your head is snapping back and forth or you're hearing some SERIOUS grinding and groaning you'll be just fine.
    Oh, and don't worry if you're as smooth as some other cars you've ridden in. You're in a truck - it won't be as easy as a Civic to shift.
  18. Sep 23, 2009 at 4:31 PM
    #38
    unskinator
    unskinator Active Member
    Unski
    Delaware
    05 4x4 V6 accesscab 6 on the stick sports
    Driving a stick takes time to get it right. Once u master it u will enjoy it more than automatic. Always stay on gear but when u stopped. As time goes u learn to listen to your engine as to how it sounds and to use it as a guide to shift. On new 05 and after 6 speed tacomas 2nd gear is known to be not the easiest one of the six. Some times to get it real smooth u need to doublecluctch. Common when sticks had no synchromess. Also the drive by wire accelerator on these tacomas has got a delay that takes time to get used to. Dont worry as time goes by u will master it. Girls who drive a stick in my opinion are always cool. I myself have driven about a million miles with the stick and it surely beats automatic anytime.
