Girlfriends Camry Oil Question?
Discussion in 'Off-Topic Discussion' started by TacoMan1911, May 26, 2013.
  1. May 26, 2013 at 8:53 AM
    TacoMan1911
    TacoMan1911 [OP] Well-Known Member
    LA
    2015 TSS DCSB Black DENALI EATER
    Anybody else here know about 4 cylinder camry's? My girlfriend has an 04 with a 4 cylinder and I do the oil changes. Why would her little car use a heavier weight oil like 5w 30 and my truck which I use to pull a boat and work with occasionally use 5w 20? Doesn't make sense to me. Anyway, I have like 3 qts of 5w 20 left, would that be ok in a Camry?
  2. May 26, 2013 at 8:55 AM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    :notsure: on the reason.
    I'd only use what the owners manual recommends.
  3. May 26, 2013 at 9:06 AM
    rmerchant3
    rmerchant3 Insert nonsense here
    It will be fine.
  4. May 26, 2013 at 9:43 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Tighter tolerances can require the use of thinner oil.
