Girlfriends car is having problems..
Discussion in 'General Automotive' started by Forster46, Mar 2, 2013.
  1. Mar 2, 2013 at 11:28 PM
    Forster46
    Forster46 [OP] Very nice how much?
    Nick
    Mount Vernon, WA
    The doritos locos taco
    6000k HID's, AUX Reverse Lights, 3" Rough Country Suspension Lift, Pioneer AVH-P4200 Double Din, Underglow and footwell Lights, Camo Seat Covers, Duralast Tool Box, Blacked Out Badges, Grill, Front Emblem, Midland CB Radio, Amber Strobes, POWER REAR WINDOW, cup holder LED's, Firestik 3' in bed, console divider, Ultragauge.
    So my gf has a honda passport, dunno what year. Early 2000s probably. It has been having problems starting and it has died on her when driving about ten times now. SHe has taken it to get looked at like three times now. Had the alternator replaced once and it still shuts off on her and won't start. I haven't looked at it yet but it happened again tonight, and her and her friend had to push it down the road to her house. First time the battery cable wasn't on all the way, then she got the alternator replaced. Now I'm gonna go look at it tomorrow and see what is wrong. She doesn't have any money to put into it and can't afford to trade it in for something different. Some advice before I go and fuck with it would be great. If you have any questions Ill ask her.
  2. Mar 2, 2013 at 11:31 PM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    def sounds electrical. possibly ignition circuit? check the battery... what engine does that have in it?
  3. Mar 2, 2013 at 11:32 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Do a battery load test with a carbon pile.
  4. Mar 2, 2013 at 11:33 PM
    Forster46
    Nick
    Mount Vernon, WA
    She doesnt even know what year it is lol. All I know is it is a v6. She says the lights wont come on when she turns the key. My buddy works at ford and I may have him come look at it with me. She cant afford to put anymore money into it at all so I'm hoping it isn't too bad.
  5. Mar 2, 2013 at 11:35 PM
    Forster46
    Nick
    Mount Vernon, WA
    She thinks the battery is dead right now, so that might be why the lights won't turn on. I would know a lot more if I looked at it myself but this is just info I'm getting from her. Her and cars should just stay away from eachother lol
  6. Mar 2, 2013 at 11:35 PM
    650H1
    Michael
    VA
    i believe its going to be the 3 liter v6. i will put money on it being the ignition or battery.
  7. Mar 2, 2013 at 11:37 PM
    Forster46
    Nick
    Mount Vernon, WA
    That sounds right. I don't know enough about cars to know what would be wrong with it other then the alternator, starter, or battery. She can't even afford to have people look at it anymore. She has replaced the alternator battery and rear bumper all in the last month or so
  8. Mar 2, 2013 at 11:39 PM
    650H1
    Michael
    VA
    wouldnt be the starter if its dying while she is driving it/it cranks over when charged...
  9. Mar 2, 2013 at 11:41 PM
    Forster46
    Nick
    Mount Vernon, WA
    Yeah thats why I didn't think it was the starter. The alternator just got replaced (with a used one) so I didn't think it would keep doing this. I'm pretty sure the battery is brand new but I don't see how it would be dying while she is driving, unless the connections aren't on right again. That's about the most knowledge I have on what it could be.
  10. Mar 2, 2013 at 11:42 PM
    rickmeseke
    rickmeseke subaru of america
    Ricky
    Brunswick, GA
    a white truck
    iac sensor?? started and dying
  11. Mar 2, 2013 at 11:54 PM
    Forster46
    Nick
    Mount Vernon, WA
    Okay so the car is a 98. I have been googling common issues and these are a few I found
    Check ignition coil for cracks
    replace ecm
    loose wire connections in engine bay or under dash
    I don't think the ignition coil being cracked would cause it to die when already running... so that's out. I read a couple about the ecu board being cracked. I'm not sure where it is located but I guess if you tap it, you will know if it is cracked if your car is running? Ill check the wiring and fuses. Also going to first check the battery, and make sure the alternator is secured correctly. My mom got hers replaced and they forgot a couple bolts, causing it to do the same thing and not start half the time.
  12. Mar 3, 2013 at 1:45 AM
    Junya808
    Junya808 Well-Known Member
    Maui, Hawaii
    2012 Tacoma OR 4X4
    Suspension Fronts: Icon Coil Overs Total Chaos UCA Rear: Icon shocks with resivior Icon aal. Interior: Wet okole seat covers Led map and dome lights Lighting: Slimcubby hid 6000k Slimcubby hid fogs 3000k Led parking lights Led license plate lights Led Switchbacks Misc. Mods Rear diff. Breather Mod
    It sounds like you have a parasetic draw, try checking your wires connecting to the ecm.
  13. Mar 3, 2013 at 1:48 AM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    battery voltage
    alt voltage
    voltage drop starting circuit
    voltage drop charging circuit
    start there
  14. Mar 3, 2013 at 2:57 AM
    Spoonman
    Jamie
    Alberta
    You and your voltage drops. :rolleyes:
  15. Mar 3, 2013 at 3:13 AM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Tells you a lot lol and it's fundamental to the rest of the electrical system.
  16. Mar 3, 2013 at 3:51 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    I had bought my ex wife a 01 Honda Passport V6 4x4 auto when we were still married. It had all sorts of BS problems, and electrical was one of them. The MAP sensor would get fouled up bad, make the thing run like crap, and die on her. Also the intake manifold leaked, the flex joint on the exhaust rusted away, the rear trailing arm mounts rusted away, had to have transmission rebuilt, never figured out what the deal with the wipers were, but they didn't have enough power to wipe all the way. The window and door switches quit working and the sunroof broke. But I tell ya, the paint stayed shiny. Those Passports/Rodeos, were horrible vehicles, that's why Honda dropped them from their line up. I would suggest to check all the ground connections to make sure that they are all in good condition, pull the MAP sensor and clean it with MAF cleaner(It's on top of the manifold, back toward the fire wall, on the driver side), if there is an aftermarket radio, make sure that the wires for it are in good order, shore up any other problems it has, then sell the POS. Trust me, sell it. Good luck, and also check the recall info for those rear trailing arm mounts, that may be a good way to get rid of it too.
  17. Mar 3, 2013 at 4:35 AM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Dunno, but sounds like the computer is going south. Buddys car did this, crap out while running, computer would shut down fuel delivery now and again. Was a bitch to figure that one out.
  18. Mar 3, 2013 at 6:54 AM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Clean the battery terminals and make sure they are tight. Might be shorting out somewhere when going over a bump or something.
  19. Mar 3, 2013 at 10:16 AM
    Vstrom30
    Vstrom30 Well-Known Member
    Midwest
    Tacoma Access Cab 4x4
    Some Hondas were having problems with the ignition switch. Jiggle the key in the ignition while running kind if rough and see if it shuts off. If that doesn't work, grab the wires on the back side of the ignition cylinder and give them a jiggle.
  20. Mar 3, 2013 at 11:05 AM
    Spoonman
    Jamie
    Alberta
    I agree :thumbsup: I get a kick out of how you always suggest it haha
