Give me some insight on my thinking.
Discussion in 'Suspension' started by THExBUSxDRIVER, Jan 22, 2012.
  1. Jan 22, 2012 at 7:52 PM
    THExBUSxDRIVER
    THExBUSxDRIVER [OP] Victory is reserved...
    GOO5E
    Old Man Tan!
    Not enough.
    Ok, so up front I installed 5100's w/ OME 885x's. Honestly I wasn't satisfied with the height so I took them off and re adjusted them to .85", I know I know, not the best thing for the 5100's but I did it and loved the new stance. The nose is about around 1" higher than the rear which has an Icon 1.5" progressive aal and the cv's are actually at a pretty good angle.
    So back to my problem.
    The ride is now, as you guessed it, rough with the coil pre loaded like that. My idea was to put the 5100's back to 0" and install spacers up front to keep the height but soften up the ride a bit.
    I'd like some input on my thoughts and should I go with a 1/2" spacer or 3/8" spacer to keep the nose as it stands right now. Thanks in advance guys.
  2. Jan 22, 2012 at 10:56 PM
    THExBUSxDRIVER
    GOO5E
    Old Man Tan!
    Not enough.
  3. Jan 22, 2012 at 11:00 PM
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    I would sell the 5100s and order the OME 9000s. If you put the spacer on top of the 5100s I think that you will find the same issue even of you drop it back to the zero setting. but that's just my opinion. I'm sure others will add their .02 as well
  4. Jan 22, 2012 at 11:45 PM
    THExBUSxDRIVER
    GOO5E
    Old Man Tan!
    Not enough.
    At first I thought that too but all it would do is keep my down travel the same but now the coils wouldn't be so per loaded.
    Hmmm.
  5. Jan 23, 2012 at 12:04 AM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    I've been going back and fourth between this idea myself...gotta remember, anything over 3" will eliminate down travel...thats the mian thing holding me back. I have the 1/2" spacers from Toytec but haven't installed em.
    I have the 5100s and 885x's as well (billies set at 0) and i'm about right at 3"
  6. Jan 23, 2012 at 10:53 AM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    That's stacking lifts and is def not recomended. This will still pre-load the coils and cause the same issues. The .85 is preloading it that much. A 1/2" spacer will lift you 1" if I'm correct and you'll still be in the same boat but slightly more!
  7. Jan 23, 2012 at 10:59 AM
    Oat
    Oat Well-Known Member
    Florida
    2001 Prerunner
    Gibson Exhaust, Painted factory steel wheels, Chrome wheel caps, K&N Air intake, Tint, Regular Bilstein (yellow/blue) all around, Leveling spacer kit upfront, Partially de-badged, Westin Bullbar with skidplate, White, Double Cab Prerunner SR5
    The spacers will be rough also.
  8. Jan 23, 2012 at 10:59 AM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    Is your sway bar still on? If it is then take it off, that will soften the ride a bit and let the suspension do its job.
    I just lowered my 5100s back down to o.o from.85 with my 885s, cv angles weren't that great and the ride was way rough offroad. I do miss the stance but I don't miss all the pops and clanks when it was @ .85 with the 5100s.
    Be kind to your truck and drop it back down.
  9. Jan 23, 2012 at 11:02 AM
    Zac808
    Zac808 Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    I've got the 5100's @.85/Eibach setup. I'm might install .5 spacers on each side and the .25 on driver side. But this is got me thinking.
  10. Jan 23, 2012 at 11:02 AM
    Taco Dan
    Taco Dan Well-Known Member
    Dan
    Tuscaloosa, AL
    07 FJ Cruiser auto 4X4
    Snorkel, Cooper ST Maxx 255/80/17, diff breather relocate, Cobra ultra III cb radio set up Warrior Products front bumper
    go ahead and buy eibach coils and set the billies at 0, that will give you the same lift. way better too.
  11. Jan 23, 2012 at 11:23 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Eibach coils will not provide as much lift as 885 coils. They are a shorter coil.
  12. Jan 23, 2012 at 6:59 PM
    THExBUSxDRIVER
    GOO5E
    Old Man Tan!
    Not enough.
    Weird. I have the same components and when set at 0" it was spot on 2.5". Though I remember a member on here telling me that my TC ucas would bring the nose down a bit.
    Thought "stacking" meant multiple spacers...hmm. Technically a spacer is used for the taco lean and its commonly used around TW, does that count as stacking? Not being an a-hole just asking.
    But I cant wrap my head on how the spacers will pre load the coils. Its the same weight from the truck, it's just sitting higher. The only thing a spacer would do (That I can comprehend) is reduce down travel.
  13. Jan 23, 2012 at 7:18 PM
    Pugga
    Massachusetts
    There are 2 types of spacers, some sit on top of the coil top plate and lower the entire coilover assembly, which is what I think you're talking about using. The other type gets installed under the top plate and preloads the coil similar to how the 5100's do when moved higher than the 0 setting. Honestly, I can't see how a 1/2" top plate spacer would cause you to lose enough down travel to cause a problem. One of the big issues with top plate spacers is the coil can bottom out before the LCA hits the bump stops. Typically this is a concern with taller spacers and weaker stock coils/shocks. I can't really see using a 1/2" spacer on the driver's side and 1/4" spacer on the passenger side would cause damage. That being said, I don't have this set-up so take everything I said with a grain of salt.
  14. Jan 23, 2012 at 7:46 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    Your messing with the whole geometry of the design in general and what it will do is unknown. Stacking lifts is just that putting 2 diff lifts together that were designed to be used independently. A lean spacer is one thing and pretty small at that. I realize a lot of guys run the 5100s and OME coils but you have to remeber they were designed to be used with eibach prob due to there diff lengths. Now you have a longer coil and going to add diff sized spacers to it just for a certain look. Your bound to have issue down the road.
    Maybe throw some heavy shit in the bed of the truck and you'll be a little higher in the front again?
  15. Jan 25, 2012 at 4:10 PM
    THExBUSxDRIVER
    GOO5E
    Old Man Tan!
    Not enough.
    Thanks for the help guys. I'll ponder about it more. I'm leaning towards switching coils to eibach but a plate bumper is in the works so we'll see.
  16. Jan 25, 2012 at 4:36 PM
    Twistedfreedom
    Adam
    Seattle
    in progress
    modded the F*ck out
    keep in mind that the OME shock and coils are designed specifically for a plate bumper
