Give me your oppinion
Discussion in '1st Gen. Tacomas (1995-2004)' started by 02TACOMA4WD, Jan 21, 2012.
  1. Jan 21, 2012 at 12:46 PM
    02TACOMA4WD
    02TACOMA4WD [OP] Well-Known Member
    02 Tacoma TRD 4x4
    So I have been looking for a tacoma for a while now, and this is what I have found. This is going to be my first truck so im okay with some of the dents and dings. I am planing on wheeling and doing a lot of off roading. Just give me your opinion on what you would spend on it and tell me what you see wrong with it.
    S 4x4, 3.4L V-6, 5-SP Manual transmission, SR5, TRD Pkg (Rear electric locking diff), 245,000 miles, power windows and locks, tow package, BFG All-Terrains. All maintenance intervals have been followed: oil changes every 4k using Toyota or Wix filters, timing belt/waterpump/thermostat at 90k intervals, front and rear diffs,tranny and transfer case at 20k intervals w/ synthetic oil. Includes a Mountaineer insulated camper shell w/ roof rack ($1200 new)and 2 spare tires. There is body damage from off-roading, but nothing structural.
  2. Jan 21, 2012 at 12:48 PM
    99TacoDriver
    99TacoDriver Well-Known Member
    South Louisiana
    OME 885x on 5100s / LR UCA Wheelers 3 leaf progreaaive AAL 275/70/17 KO 2's on 17" fuel Hostage no rubbing
    no more then 4-5k with that many miles on it
    actually with the condition its in id say 2.5-3k at the most
  3. Jan 21, 2012 at 12:49 PM
    Rusty 06 4x4
    Rusty 06 4x4 NBHNC
    Rusty
    West Georgia
    2006 4x4 Tacoma TRD DCSB
    maybe 4-4500 but check for frame rust..
  4. Jan 21, 2012 at 12:49 PM
    VooDoo
    VooDoo More Cowbell!
    Carter Ivey
    Baton Rouge, LA/ Starkville, MS
    '06 DC LB PreRunner
    WAY too high IMHO. 245,000 miles? I wouldn't. Keep looking.
  5. Jan 21, 2012 at 12:51 PM
    02TACOMA4WD
    02 Tacoma TRD 4x4
    He is also the original owner and there is no frame rust. This truck has only been in Arizona.
  6. Jan 21, 2012 at 12:59 PM
    Tacomadude89
    Tacomadude89 Well-Known Member
    Austen
    California
    2002 Tacoma TRD SR5, 3.4, 5spd
    -Bilstein 5100 Series shocks on all 4 corners -Rancho HD lift coils -1/4" Toytec driverside top plate spacer -Toytec 1" diff drop -Wheelers 1.5" AAL's -Toytec 1" lift shackles -Revtek extended length BPV bracket -285/75/16 BFG KO T/A's -Pro Comp rims -ET Conical tyle lug nuts -Spidertrax 1.5" wheel Spacers -CV Boot slide mod -TRD skid plate -Magnaflow 14" round muffler -Shortened tailpipe hidden behind framerail -Toyota bug deflector -Weathertech floormats -Black leather seat covers -Valentine 1 Radar Detector
    It looks like it's a had a bit of hard life judging by all that body damage.
    That being said and it doesn't bother you, if it mechanically runs and drives well, the frame checks out (no rust-it would be a great idea to have it professionally inspected) and you can get it at a good price, then go for it. A truck with a decent amount of body damage already would make for a good wheeling rig.
  7. Jan 21, 2012 at 12:59 PM
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    As others have said, for that price, keep looking. I feel he is asking way too much money for it in the condition it is in.
  8. Jan 21, 2012 at 1:04 PM
    02TACOMA4WD
    02 Tacoma TRD 4x4
    Right now he is "asking" 4k, i think i will be able to get him lower on the price.
  9. Jan 21, 2012 at 1:11 PM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    First thing I'de do is KKB the truck, then deduct about $3500 for body damage, next check the miles and see if there normal for that yr truck.That shell is a old and out dated item,not worth more than $200 and thats if the rear struts, and hinges are still not wore out or broke. under the hood the wireing looks half assed.If the condition of what I see on the exterior of the trk, indicates how the owner took care of the maintance, I don't think I would believe he did a heck of alot of maintance. I think at the most I'de offer $2K. I think you would be better off looking at a different truck,less miles.
  10. Jan 21, 2012 at 1:57 PM
    Tacomadude89
    Austen
    California
    +1
  11. Jan 21, 2012 at 2:02 PM
    02TACOMA4WD
    02 Tacoma TRD 4x4
    This was his "camping/offroading" truck. The owner was saying that he didn't care much about cosmetics and was saying that he has all of the maintanance recorded. The truck is about 20 minutes away from my house so i think i might go check it out and just see whats going. If i can get it for a good enough deal, i might just buy it. My plans for the truck would be front and rear bumpers and sliders. Which would "hide" some of the cosmetics. i dont know its just a thought. Thanks for all of the input guys!
  12. Jan 21, 2012 at 3:39 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    NO, dont buy it. Look for something in better shape. I wouldnt touch that thing with a 10 ft stick. That thing is beat to hell and with that many miles in that condition you will be fixing shit all the time, which will be a hassle. If it was a camping/off roading truck with that many miles you know he drove it a lot and drove it very hard, the body condition is also usually reflective of the mechanical condition. You may say you like wrenching on your truck or you dont mind fixing it now, but down the road it is going to be a PITA. I would rather fix broken parts on my truck that break from off roading, not that break from daily driving because its got alot of miles. The extra 2500-3000 it would cost to get a truck in better shape with less miles will be worth it.
  13. Jan 21, 2012 at 3:46 PM
    03coma
    03coma Well-Known Member
    New Jersey
    2015 DCSB TRD, SR5
    Toyota TRD Pro Grille, Skid Plate, ARE Series II Lid,
    I agree with IDTrucks, that thing was driven hard keep looking.
  14. Jan 22, 2012 at 3:45 PM
    misterdmac
    misterdmac Well-Known Member
    Doostin
    In or around the truck
    '97 2.7L DLX
    I'm in the boat with these guys. These trucks go and go, but seem to age a lot more quickly after 200k. That seems obvious, but just like any car, the rate at which it wears will increase over time. For the right price, I'd buy it at 180K, especially if you wanted to do a suspension lift, which, had it been done prior to all that crawling, might have saved the body from a lot of that damage.
    Other thing is, if you're attached to a truck and need to put a new engine in it, that's one thing. If the frame, rusted or not, has had a rough life, she's heading for parts bin faster than you think.
  15. Jan 22, 2012 at 3:48 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    That thing looks like its been beaten hard :(
    There may be other issues other than the body damage.
    And 240k? It may be a tacoma, but I would keep looking.
    And look at that bent cross member where the skid bolts to. Is that welded on or bolted on w/ the 98-00's?
    That poor taco has been beat :(
