GL5 in transfer case ok?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Josh-L, Oct 1, 2023.
  1. Oct 1, 2023 at 6:43 PM
    stuttgart1
    stuttgart1 Well-Known Member
    2019 TRDOR
    When I said GL5 wasn’t supposed to be run in our Tacoma transfer cases I assumed everyone was referring to 3rd gens, since this is the 3rd gen forum. Yes the spec for 2nd gen Tacoma transfer cases is GL5. Different transfer case, different fluid spec.
  2. Oct 1, 2023 at 6:54 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    What you said, quoted below, was GL5 shouldn't be used in our transfer cases because GL5 supposedly attacks brass components. That is wrong. 1st gen and 2nd gen transfer cases also have the same brass components. The cases VF2BM and VF2CM are mechanically very similar. However, the electronic actuator (and 4WD ECU control logic) is different.
  3. Oct 1, 2023 at 7:00 PM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    The winters here get down to the 30's a few nights a year while the summer temperatures are always in the 1 teens and often in the 120's.
  4. Oct 1, 2023 at 7:10 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    CaptainBart45 likes this.
  5. Oct 1, 2023 at 7:19 PM
    CaptainBart45
    Bart
    Work in progress...
    Actually mine seems to be shifting better with the 75-90 in it. Thinking about the limited slip additives, I am not sure I actually put this stuff in my transfer case. I am going to go out and read my service records. At least I keep a record of what the hell I did...2020 about this time of year. Sure as shit I better change this stuff out. As I remember, some of it had additives and some of it didn't? Is that even possible?
    3JOH22A[QUOTED] likes this.
  6. Oct 1, 2023 at 7:27 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    There is a document floating around the forum somewhere from Toyota, translated from Japanese that specifically states the 75W was for fuel economy. The transfer case is very similar to the VF2BM from the 2nd gen Tacoma; and many other Toyota vehicles switched to the 75W on random model years where nothing changed - such as the 2010 FJ. Don’t read that to mean I think the 75W is bad, but I think it’s far from “necessary/required.”
    I don’t necessarily believe that the shifting complaints with 75W-90 are entirely accurate, either. Shifting can be funky even with the spec’ed fluid, and could at times be operator error. For shifting into 4Hi from 2Hi, you often need to be maneuvering the steering a bit for the ADD to finally slide the collar over. If the splines aren’t lined up, often some differential between the front wheels is needed for it to finally lock in. As such, it might not even be related to the transfer case at all.
    For what it’s worth, 80W-90 GL4 conventional manual trans oil shifts the transfer case more smoothly in mine than the Toyota 75W stuff ever did. Occasionally I’d get a nasty clunk at speed with the 75W (but not most of the time).
    the main difference between 2nd gen and 3rd gen is the actuators. 2nd gen cases called for 75W-90 GL4/GL5.
    G8R_Taco and CaptainBart45 like this.
  7. Oct 1, 2023 at 7:29 PM
    10thMTNgrunt
    10thMTNgrunt This is the way, step inside.
    2013 TRD Sport
    Maybe I’m missing something here, but isn’t MT-LV for manual transmissions only?
  8. Oct 1, 2023 at 8:40 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    ^Late to the party huh? We're talking about transfer case fluid.
  9. Oct 1, 2023 at 9:59 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    I camp in extremely cold weather. I’ve had the transfer case stuck in 2WD in freezing temperatures with 75/90 synthetic in there. I went back to the Toyota LF (low friction) 75W fluid and no further problems. I almost got stranded in the snow with my truck stuck in 2WD, so no more screwing around trying to save a buck by buying generic 75W90 for this compadre.
    Summer campers…….likely not a problem.
  10. Oct 1, 2023 at 10:20 PM
    Brikan
    Brikan Well-Known Member
    2018 Inferno Tacoma TRD Offroad
    B&M shifter Hood gas strut Injen Intake OSC catch can
    If you can't get or afford the LT 75W, GL-4 75W85/90 works.
    Do not use GL-5, if you did use GL-5 drain and fill with LT 75W or GL-4 75W85/90 sooner rather then later.
    GL-5 has friction modifier additives for LSD differentials that eats soft metals, like brass synchro rings, which your transfer case does have to aid in engaging 4wd/HiLo.
    Also engage 4wd Lo at the least once a month, or better yet, a couple of times a month, keeps the system more so well lubricated and freed up for use when you need it, which I'm sure is the problem with the post above. Electronic mechanical transfer cases like to freeze up from disuse.
  11. Oct 2, 2023 at 4:31 AM
    BLtheP
    Plano, TX
    How exactly did it not shift? Were you moving around at all and it still wouldn’t shift at all?
  12. Oct 2, 2023 at 8:19 AM
    CaptainBart45
    Bart
    Work in progress...
    OK, ordered the Ravenol MTF-3 75W from BlauParts, 15 bucks shipping ouch. Anyways, should I run some plain wrap 80W-90 for a week or so, before putting the Ravenol in, to flush out the transfer case?
  13. Oct 2, 2023 at 9:26 AM
    Stocklocker
    17TRDORDCSBAT
    Correct. I was driving around with the 4WD indicator blinking, and doing all the things, steering, going back and forth, all the stuff. I had to wait for the exhaust to warm up the transfer case, at which point it did shift.
    I’ve been back in the same situation multiple times since I went back to the Toyota Low Friction fluid and no problems.
    3JOH22A and RustyGreen like this.
  14. Oct 2, 2023 at 10:15 AM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Pulling the drain plug and letting it sit overnight would probably be fine.
    CaptainBart45[QUOTED] likes this.
  15. Oct 5, 2023 at 12:31 PM
    #35
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    Where are you so I know to never go there?
