Glare from Hood Scoop
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Richland, Oct 16, 2008.
  1. Oct 23, 2008 at 11:23 AM
    Richland
    Richland [OP] Member
    Massachusetts
    08 Tacoma 4 door Black
    Yakima racks for gear etc.
    No..I decided to keep the scoop!
    Sorry folks.....
    Fashon over function....won out this time.....
  2. Oct 23, 2008 at 11:26 AM
    spaghettiedy
    spaghettiedy Well-Known Member
    Pittsburgh
    09 DC LB Sport in Black 4x4
    Gray Weathertechs, LG Wet Okoles, Tacome OEM Bedmat
    My thoughts exactly
  3. Oct 23, 2008 at 1:04 PM
    2xtreme
    2xtreme Member
    Grand Forks, ND
    Blue TRD 4x4 longbed
    Flat black vinyl scoop covers coming soon. I just finish the lip cover last night. Once I get the template down I can add the TRD logo in the side or V6 VVT or what ever else you want. Let me know if your interested.
  4. Oct 23, 2008 at 1:24 PM
    gtz85350
    gtz85350 Well-Known Member
    Yuma Arizona
    08 SR5 sport
    Richland....go with the racing strip man! It sounds good! I have thought about this before as well
  5. Oct 24, 2008 at 4:45 AM
    spaghettiedy
    Pittsburgh
    Pics ?
  6. Oct 24, 2008 at 5:17 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    put a 8 inch wide strip of tint on the bottom of the windshield? Some states have different laws on this though - that's what I thought about doing.
  7. Oct 24, 2008 at 6:32 AM
    Richland
    Massachusetts
    Certainly interested!
    V6 VVT not TRD
    permanant, or removable?
    VR
    Rich
  8. Oct 24, 2008 at 10:44 AM
    gtz85350
    Yuma Arizona
    08 SR5 sport
    Yea some pics of of the cover would be nice...sounds pretty sick and custom!
  9. Oct 24, 2008 at 1:14 PM
    2xtreme
    2xtreme Member
    Grand Forks, ND
  10. Oct 24, 2008 at 2:19 PM
    hate2work
    hate2work Well-Known Member
    Washington State
    06 standard cab
    Rob ( 2xtreme ) is making me a flat black vinyl strip for the lip at the back of the hood. He sent me a picture of it and it looks good, I'm sure it will work well.
    I'll post some pics when I get it installed, if i can figure how to do that. I may have to get my teenager to help me :D
  11. Oct 24, 2008 at 3:27 PM
    2xtreme
    2xtreme Member
    Grand Forks, ND
    The best way to apply is to get a spray bottle full of water (some people say to add a drop of dish soap to the water but I’m always afraid it will prevent the glue from sticking as well) and a role of masking tape.
    First clean the hood top and bottom. Don’t use anything waxy like spray detailer. Window cleaner works well. Make sure you clean the back side and edges so you can roll the extra under.
    Find the center of the strip and the center of the hood. Use a small piece of masking tape on the hood just forward of the ridge. Mark the tape with a sharpie so you know where the center is.
    The vinyl strip will have a backing paper and a transfer paper. Mark the transfer paper at the center of the strip. Do this before you remove the backing.
    Spray the top down with water. You can even use a garden hose if you need to. The water will help to position the strip.
    Pull off the backing but only halfway. A second set of hands and a step stool helps. Line up the front edge with the center marks and the peak of the ridge. Line up the curve along the front edge and lightly tack it down.
    Remove the backing on the other side and line it up along the ridge. if there are large wrinkles or folds then you may need to reposition one side or another.
    The vinyl will stretch so be careful not to pull it to much and change the shape.
    Once you have the front edge lined up and there are no major folds slowly press the rest of the vinyl down rolling the back edge under the hood.
    Use the masking tape roll as a squeegee removing any bubbles, wrinkles or folds.
    It may take a few attempts to get it just right. The vinyl is forgiving but it has its limits so don’t pull on it to much and limit the number of times you put it down and pull it up.
    Whatever you do don’t let the sticky side touch itself.
    Finally pull the transfer paper off and inspect for any more bubbles.
    The vinyl is 5 Year vinyl so it should last for a long time but it will come off with a hair dryer and some patience.
    Good Luck!
  12. Oct 27, 2008 at 7:36 AM
    Richland
    Massachusetts
    Are you Serious...
    Tell your GF to stop calling me!
  13. Oct 27, 2008 at 7:38 AM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
  14. Oct 27, 2008 at 1:01 PM
    Gene563
    Gene563 Well-Known Member
    Eugene
    Lanoka Harbor, NJ
    08 Double Cab, LB, TRD Sport
    TRD catback exhaust, Undercover hard tonneau, Vent visors, Husky liners, customized seat covers, front license plate bracket, rear suspension TSB, Eibach springs w 5100s@0, & General Grabber AT2 (265.70.17).
    I had my first experience of driving into "heavy-duty" sunset yesterday.
    It was annoyingly distracting and I had the visor down and one hand up to block the reflection, all the while thinking of this thread.
    This is what I noticed. On the scoop, there were 2 small reflections, 1 at the curve up and 1 where it rounds over. More disturbing was the big reflection, 8 inches to the left on the flat of the hood. So unless the "flat" vinyl covered the entire hood, there would still be an issue.
    Now don't get me wrong, I think the flat vinyl cover for the scoop would look cool...reminiscent of a Mopar "Shaker hood scoop". I agree with the badging of VVT...maybe "4.0" rather than V6.
  15. Oct 27, 2008 at 1:15 PM
    #35
    2xtreme
    2xtreme Member
    Grand Forks, ND
    Im sure I could come up with a graphic for the hood that would meet both "form" and "function". Ill see what I can come up with. as for the shaker hood look that's what I was thinking. I can do 4.0 VVT easy enough. I can cut the letters out and the text would be body colored or cut a separate decal in silver, white, red or blue.
  16. Oct 27, 2008 at 7:20 PM
    #36
    hate2work
    Washington State
    06 standard cab
    Received my vinyl hood lip cover from Rob today. Looks good, will get it installed and post pics when done, prolly this weekend.
  17. Nov 26, 2008 at 4:13 PM
    #37
    2xtreme
    2xtreme Member
    Grand Forks, ND
    Did you ever get a chance to put it on?
  18. Nov 26, 2008 at 5:51 PM
    #38
    davatk
    davatk Well-Known Member
    Northwestern Virginia
    2009 DC TRD Sport Long Bed
    Tube Steps, Hood Deflector, ScanGauage, GPS
    I also have gotten the "sunset" blinding, on a couple of occasions. It's actually pretty doggone irritating. But, it does look good, when the sun is not blinding your from seeing it. ;)
  19. Nov 27, 2008 at 11:11 AM
    #39
    ETAV8R
    ETAV8R Out DERP'n
    MGM 09 AC 4WD V6 TRD-OR w/ Tradesman Shell
    Just the basics
    I like the strip at the back of the hood. I too have experienced the sun reflection off the tapered part.
    No hoodscoop here so I don't need to worry about that.
  20. Nov 27, 2008 at 11:27 AM
    #40
    Marioso
    Marioso Risueno
    San diego Ca
    2007 Toyota Fj Cruiser
    never had that problem
