Glass break sensor wiring?
Discussion in '1st Gen. Tacomas (1995-2004)' started by slickyd, Oct 16, 2009.
  1. Oct 16, 2009 at 7:44 AM
    slickyd
    slickyd [OP] Well-Known Member
    David
    Talladega, AL
    03 PreRunner SR5
    has anyone installed one in their truck. I want to put mine in but i don't know which set of wires goes to witch set on the sensor. I don't want to mess it up by hooking up the wrong wire up. I know there are two sets that are plugged in together under the dash and you have to undo them and cut the ends off of them. I know im all over the place on this post and i just hope it makes sense and someone can help me.
  2. Oct 16, 2009 at 8:09 AM
    slickyd
    David
    Talladega, AL
    03 PreRunner SR5
    ok well im doing it right now and the wire up under the dash isn't connected to anything like i had thought it just four wires going into a plug. No im just going to take a guess and see if i can wire it up right the first time.
  3. Oct 16, 2009 at 8:26 AM
    NraFan
    NraFan Join the NRA! Protect your freedom!
    JT
    SoCal
    2011 Sienna LE, rockin the mini van!
    Power sliding doors baby! WooHoo!
    Good luck!
  4. Oct 16, 2009 at 11:13 AM
    slickyd
    David
    Talladega, AL
    03 PreRunner SR5
    i got it. It was real easy the hardest part was getting those wire connectors on those small wires. And the GB does work I broke a drinking glass while testing it by accident.
