glassworks fenders with antenna
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HAWAIICALIVEGAZ, Apr 28, 2012.
  1. Apr 28, 2012 at 4:44 PM
    HAWAIICALIVEGAZ
    HAWAIICALIVEGAZ [OP] Desert Warrior
    SHANE
    LAS VEGAS NV
    2005 TRD Pre Runner
    Dr Coilovers; Camburg UCAs; Sway bar Relocation block; Deaver J66 Leafs; ProComp extended travel rear shocks 6K HIDs & 13" antenna
    I still want to run the antenna like factory instead of tie it up under the fender. Has anyone already this and have pics? I'm sure its not to common but would still like to do it non the less... thanks
    Shane
  2. Apr 29, 2012 at 2:32 PM
    HAWAIICALIVEGAZ
    SHANE
    LAS VEGAS NV
    2005 TRD Pre Runner
  3. Apr 29, 2012 at 2:32 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    you could mount the antenna in the bed then run a wire to the radio
  4. Apr 29, 2012 at 2:34 PM
    nfs257
    nfs257 Well-Known Member
    DFW
    She gone
    Ask Imsikotic. His is the stock antennae and fiber glass front fenders...
  5. Apr 29, 2012 at 2:53 PM
    HAWAIICALIVEGAZ
    SHANE
    LAS VEGAS NV
    2005 TRD Pre Runner
    I'll pm him... thanks!
  6. Apr 29, 2012 at 2:59 PM
    SoJersey
    SoJersey South Jersey Defense
    Brandon
    08302
    '12 DC Offroad
    Pelfrey Armor Baja Designs Lights 6112/Camburg/Dakar Suspension Method Wheels / BFG KO2 ARE Z-Series More coming soon...
  7. Apr 29, 2012 at 3:52 PM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    Just get an aftermarket antenna that mounts to the very top of the windshield.
    I ran two on some other vehicles I had. Just unplug factory antenna run new wire from back of head unit to front pillar and antenna sticks top inside top of window where the dot matrix is. Not seen and radio reception is no problem.
    Only down side is they are typically FM only. Cheap and easy to install.
    http://www.amazon.com/NEEWER®-Windshield-Mount-Electronic-Antenna/dp/B005TDESB0
    http://www.amazon.com/Windshield-Mount-Electronic-Radio-Antenna/dp/B005GNWBOE
  8. Apr 29, 2012 at 4:17 PM
    HAWAIICALIVEGAZ
    SHANE
    LAS VEGAS NV
    2005 TRD Pre Runner
    I'm not trying to hide it... I want to mount it on the fender but the curves are different.
  9. Apr 29, 2012 at 5:43 PM
    lj973gm
    Ohio
    06 DCSB 4wd
    I would not want to dick with the fiberglass personally. You must make a good mount to hold it in place or else the wind and vibes will crack the fiberglass. That would be my reason
  10. Apr 29, 2012 at 5:54 PM
    SoJersey
    Brandon
    08302
    '12 DC Offroad
  11. Apr 29, 2012 at 6:05 PM
    TacoVerde
    TacoVerde Well-Known Member
    Sean
    So Cal
    09 PreRunner
    URD short shifter, OBX racing pedals and titanium/carbon fiber shift knob, Rear speaker mod, Taco bed mat, Bed extender, taco door sill protectors, Black TRD floormats, AFE stage 2 CAI, Doug Thorley Header and Catback, Glassworks Unlimited front fenders/bedsides, Engage front LT kit,2.5x8 King co's with resi's, dj straps
    Picture is kind of far away but here you go, hope it helps
  12. Apr 29, 2012 at 6:07 PM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    we just turned the mount and tucked it up underneath.
    no issues with reception at all.
  13. Apr 30, 2012 at 8:46 AM
    HAWAIICALIVEGAZ
    SHANE
    LAS VEGAS NV
    2005 TRD Pre Runner
    That actually looks pretty good TacoV... Any issues with anything at all? Cracking or anything? Is the contour about the same?
  14. May 2, 2012 at 9:50 PM
    TacoVerde
    Sean
    So Cal
    09 PreRunner
    Thank you, no cracking and i've hit some stuff pretty fast with it lol. it mounts pretty much same as stock other then its leans a little towards the passenger side and not exactly straight up and down.
  15. May 3, 2012 at 6:53 PM
    HAWAIICALIVEGAZ
    SHANE
    LAS VEGAS NV
    2005 TRD Pre Runner
    Oh really? Could it be mounted a little higher to make it stand up right?
  16. May 4, 2012 at 3:12 PM
    TacoVerde
    Sean
    So Cal
    09 PreRunner
    I think so, i bought mine used and just used the one the other guy did.
  17. May 4, 2012 at 3:21 PM
    HAWAIICALIVEGAZ
    SHANE
    LAS VEGAS NV
    2005 TRD Pre Runner
    oh gotchya... mine are new and never installed yet so hopefully I get it right the first time LOL
  18. May 4, 2012 at 3:22 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    X2
  19. May 4, 2012 at 3:25 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    X3
  20. May 4, 2012 at 3:27 PM
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    2011 Mall Crawler
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Nittos, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tint, 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, Trail Gear bumper, Crown brake lines F/R
    X4
