Glock owners united MEGA THREAD
Discussion in 'Guns & Hunting' started by gixxerphil, Mar 6, 2017.
  1. Sep 13, 2020 at 7:31 AM
    #2521
    sabasarge
    sabasarge Well-Known Member
    central Columbia Gorge
    2020 Sport AC MT cement
    Working on that
    Put those Pmags through a thorough testing. I have gotten rid of all Pmags for my Glocks and am sticking with OEM mags only. That’s a decision based on numerous courses taken, and the continued unreliability of Pmags for the Glocks. Great for my long guns.....Glocks not so much.
    As always, YMMV.
    BulletToothTony likes this.
  2. Sep 13, 2020 at 8:03 AM
    #2522
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    what kind of failures? I prefer OEM but my magpuls are the only aftermarket mags that haven’t had issues
    TomTwo and jeff b like this.
  3. Sep 13, 2020 at 8:34 AM
    #2523
    T4RFTMFW
    T4RFTMFW Well-Known Member
    They’re all getting numbered and tested, would prefer OEMs but read they need to be modified for the Magpul well. Will see when it’s all in hand.
  4. Sep 13, 2020 at 8:54 AM
    #2524
    sabasarge
    Working on that
    Feeding issues. It is sporadic, but to the point that I won’t trust my life or the life of my loved ones to “sporadic” reliability. As I intimated, I have dozens of Pmags that have been extremely reliable with my long guns, but for whatever reason, not so much in my Glocks.
    jeff b and JimBeam[QUOTED] like this.
  5. Sep 13, 2020 at 9:00 AM
    #2525
    JimBeam
    JB
    2015 Tundra
    Yeah obviously the rifle mags are top notch...I haven’t heard of any failures with their Glock mags so I was interested in actually hearing about them
    TomTwo likes this.
  6. Sep 13, 2020 at 9:13 AM
    #2526
    db6598
    db6598 Well-Known Member
    NC
    I have 12-15 magpul Glock mags. They are great for range use but I'm with you for other purposes. They tend to need some lube to feed reliably once they get well used. This is compounded if you use steel case ammo since it's just not as slick as a brass casing. When I carry it's only with OEM mags.
    jeff b likes this.
  7. Sep 13, 2020 at 9:59 AM
    #2527
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    My Glock pmags that are older have no issues its been the ones in the last 10-12 months I have had some feeding issues with....
    jeff b[QUOTED] likes this.
  8. Sep 13, 2020 at 11:27 AM
    #2528
    Enigma8246
    Enigma8246 Well-Known Member
    Lee
    Central Arkansas
    2007 4Runner Limited 4WD V8
    We had similar issues with our shop's rental Silencerco Maxim 9 which used a pmag. Every 6 months or so we'd have to replace the pmag because the mag lips would warp and cause feed issues. Keep in mind the Maxim 9 was one of our most popular rental guns and I'm sure the suppressor caused higher heat in the chamber with sustained shooting. The pmags were being borderline abused the way they were being used but we still didn't recommend them for carry/duty. Good range mags though.
  9. Sep 25, 2020 at 1:40 PM
    #2529
    iK0NiK
    iK0NiK Insert custom title here.
    West
    Columbus, GA
    2015 DCSB V6 TRDOR 4WD
    Bil 6112/5160's etc.
    Hey question for my fellow Glock buddies. I've carried a G23 for years and the week decided to start running a G22 mag in it for the extra couple of rounds. Do you guys know if anyone makes some sort of sleeve or aftermarket mag baseplate that fills in that gap between the bottom of the grip and the bottom of the mag? It's not an aesthetic problem but the raised lip of the bottom of the mag kind of digs into my back when I'm driving.
  10. Sep 25, 2020 at 1:48 PM
    #2530
    MAG GRY TACO15
    MAG GRY TACO15 Well-Known Member
    Alan
    GA
    '15 TRD Off-Road
    Same crap everyone else got
    Like this?
    Fernando and iK0NiK[QUOTED] like this.
  11. Sep 25, 2020 at 1:49 PM
    #2531
    db6598
    NC
  12. Sep 25, 2020 at 1:58 PM
    #2532
    iK0NiK
    West
    Columbus, GA
    Boom! Thanks to both of you guys! I didn't know what to call it, so wasn't sure what to search for. That's exactly what I needed. Thanks again!
    MAG GRY TACO15 likes this.
  13. Sep 25, 2020 at 2:47 PM
    #2533
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    Got my Gray Ghost frame stuck on my Gen 3 slide today. It’s real smooth and tight fitting. I will upgrade the slide and barrel after I get moved. AFABA7CA-0BD3-4910-AF2F-4A330D413FE5.jpg
  14. Oct 1, 2020 at 12:32 PM
    #2534
    db6598
    NC
    You looking for suggestions? I haven't tried these exact holsters but have tried similar models. Had a T1C Axis Slim. I've since moved on to a TXC X1 with a light. I realized I don't really care for the extra bulk needed for the mag.
  15. Oct 1, 2020 at 12:40 PM
    #2535
    MAG GRY TACO15
    Alan
    GA
    '15 TRD Off-Road
    You need that Point Break holster goodness!
  16. Oct 1, 2020 at 1:14 PM
    #2536
    db6598
    NC
    If the holster is open ended it should fit either. I think the rails changed ever so slightly for gen 5 so the fit may be a little different if the 19/17 holster is a different gen.
    Edit: I just went back and read the message on this from TXC. They said the fit across gen 4/5 is the same unless you have a light. Recommend gen dedicated holsters if you're running a light.
  17. Oct 1, 2020 at 1:27 PM
    #2537
    db6598
    NC
    I'd buy with confidence regardless of gen to be honest. The comments I posted above may be specific to how TXC makes their holsters. I have several T-Rex Ragnaroks and have had no issues with them. You should be good to go. I'll post a pic of the end of my holster with 19 and X300 so you can see. T-Rex may cut the kydex a little different on the end but concept is the same.
  18. Oct 1, 2020 at 1:29 PM
    #2538
    db6598
    NC
    jeff b likes this.
  19. Oct 1, 2020 at 1:30 PM
    #2539
    lopezjongiii
    lopezjongiii New Member
    jong
  20. Oct 1, 2020 at 8:09 PM
    #2540
    gixxerphil
    gixxerphil [OP] @concretelander
    Phillip
    Auburn, Alabama
    2013 DCLB
    Stopped by Academy on my way to work and this followed me out. This will take the place of the 43 as the main carry.
    Tamytacoma, Ely010606, ETBA and 3 others like this.
