Glock owners united MEGA THREAD
Discussion in 'Guns & Hunting' started by gixxerphil, Mar 6, 2017.
  1. Aug 29, 2023 at 11:09 AM
    #3841
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    Why'd you sell your mags to move back to Oregon?!?! All the mag capacity limit crap is on hold at least until the court hearing at the end of September and anything in current possession will be grandfathered in IF it does take effect.
    You should stock up on some standard capacity mags while you can!
    IPNPULZ, TomTwo, Sprig and 1 other person like this.
  2. Aug 29, 2023 at 9:08 PM
    #3842
    WestCoastBestCoast
    WestCoastBestCoast Well-Known Member
    Wyn
    Portland, OR
    2005 SWB TRD 6MT 4x4
    I have plenty of standard mags, around 20 or so. I moved back to Oregon and sold my 10rd mags (I had to live in a mag ban state for work for a little while) and because I was short sighted (wasn’t paying attention to their upcoming legislation at the time) I didn’t think about traveling in Washington and being compliant up there.
    Edit: probably still going to buy more standard cap mags for all my firearms though.
  3. Aug 30, 2023 at 1:14 PM
    #3843
    plurpimpin
    PDX
    Ah that makes way more sense! I misunderstood that you sold all your standard caps to move to Oregon and only had 10 rounders now.
    Welcome back!
  4. Aug 31, 2023 at 12:02 AM
    #3844
    WestCoastBestCoast
    Wyn
    Portland, OR
    No worries! Glad to be back!
  5. Sep 23, 2023 at 6:17 AM
    #3845
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    I am looking to some Minus connectors for a couple of my pistols.
    Are the aftermarket ones as good as the Glock ones? Or should I stay with Glock parts?
  6. Sep 23, 2023 at 7:21 PM
    #3846
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    As in a trigger connector? I’ve only ever used parts from glockstore or lone wolf personally
    willee51 likes this.
  7. Sep 23, 2023 at 7:32 PM
    #3847
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    ^^^^^^This^^^^^^
    AR15xAR10[QUOTED] likes this.
  8. Sep 23, 2023 at 7:46 PM
    #3848
    AR15xAR10
    This is the one I use and can highly recommend:
  9. Sep 24, 2023 at 1:08 AM
    #3849
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    Ghost Evo Elite.
  10. Nov 9, 2023 at 5:59 PM
    #3850
    bonifacio
    bonifacio Well-Known Member
    Central PA
    2019 Cement Gray Tacoma OR 4x4
    I prefer OEM Glock ones. Just a preference thing.
    I sent my trigger out for work. Installed a slave pin and a travel stop.
    Smoothed everything out. Removed pre and post travel. Crisp wall.
    Was also paired with cleaned up facory connectors and safety plunger so I can adjust the pull weight.
  11. Dec 7, 2023 at 6:09 AM
    #3851
    MAG GRY TACO15
    MAG GRY TACO15 Well-Known Member
    Alan
    GA
    '15 TRD Off-Road
    Same crap everyone else got
    Simple little set up.
    glk19g5, TomTwo, -Rorschach- and 3 others like this.
  12. Dec 7, 2023 at 6:18 AM
    #3852
    Scott B.
    Scott
    Georgia
    Stock guts?
    I've upgraded a couple of parts on mine, and need to polish things.
    Unfortunately, the Trijicon suppressor height sights do not clear the Leupold Delta Point... :( I need to either change the red dot or get a milled slide and not use the adapter.
  13. Dec 7, 2023 at 6:25 AM
    #3853
    MAG GRY TACO15
    Alan
    GA
    '15 TRD Off-Road
    stock guts. I'll probably get a overwatch precision trigger for it like all my other glocks. You should look into Galloway precisions for their rear DDP rear sight insert. Also ameriglo makes 5xl height sights that may fit the bill. Or run what you have and spend $90 and have the slide milled.
    I'm not a fan of plates so I always get them milled or find a red dot that works directly on the mos cut away without a plate.
  14. Dec 7, 2023 at 6:43 AM
    #3854
    Scott B.
    Scott
    Georgia
    The plates seem to be a good idea from the manufacture's point of view, but any height of the sight that can be reduced is a good thing.
  15. Dec 7, 2023 at 6:48 AM
    #3855
    MAG GRY TACO15
    Alan
    GA
    '15 TRD Off-Road
    Sell the plate and mill the slide. The hopefully you can keep you sights you have now.
    Wager Machine works does my slides and has a huge following on Reddit. NEVER seen a negative review.
  16. Dec 7, 2023 at 6:52 AM
    #3856
    Scott B.
    Scott
    Georgia
    There's a market for plates?
  17. Dec 7, 2023 at 7:01 AM
    #3857
    MAG GRY TACO15
    Alan
    GA
    '15 TRD Off-Road
    Is it just the MOS plate or is it one from say CHPWS? If it's not the MOS plate then yes, people will buy it.
  18. Dec 7, 2023 at 7:11 AM
    #3858
    Scott B.
    Scott
    Georgia
    It's the stock Glock plate. I've looked at upgrading it, but haven't yet.
  19. Dec 7, 2023 at 7:28 AM
    #3859
    MAG GRY TACO15
    Alan
    GA
    '15 TRD Off-Road
    Since it's the mos slide not sure you can remill it to a ddp foot print so you're only option would be to buy a new slide that's milled or have it milled. Or somehow find a much much thinner plate which probably will still be too thick.
    So back to square one, and maybe just finding taller sights or using the ddp rear sight insert.
  20. Dec 7, 2023 at 7:33 AM
    #3860
    Scott B.
    Scott
    Georgia
    This is a back burner project, even though I have shot the gun in several matches. Guess I need to move it up the priority list...
