Glock owners united MEGA THREAD
Discussion in 'Guns & Hunting' started by gixxerphil, Mar 6, 2017.
  1. Dec 1, 2018 at 4:30 PM
    #1301
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    Running a silencerco threaded on my 19
  2. Dec 1, 2018 at 5:35 PM
    #1302
    LMarshall73
    LMarshall73 Well-Known Member
    Lee
    Cocoa, FL
    2012 DCSB TRD Sport
    Same. Silencerco threaded with a Suarez International compensator
    hillbillytoyo[QUOTED] likes this.
  3. Dec 1, 2018 at 6:30 PM
    #1303
    LMarshall73
    Lee
    Cocoa, FL
    2012 DCSB TRD Sport
  4. Dec 2, 2018 at 5:47 PM
    #1304
    Old Marine Cal
    Old Marine Cal Well-Known Member
    2015 MGM DBLCAB
    So have a gunsmith question.
    Bought a used Glock17, gen 5 used, cause no badge.
    I have put about 350 rounds through it when it starts double firing.
    Pull trigger, doesn't reset. Send two or three rounds down range.
    Has some upgrades from the glock store in san Diego, trigger being one of them.
    I am guessing something is loose or assembled wrong.
    Places to start?
  5. Dec 2, 2018 at 5:51 PM
    #1305
    BulletToothTony
    Drop a factory trigger in and see if you can duplicate the problem, if you cant then you know its the aftermarket trigger. Then see about contacting the trigger manufacturer for an exchange if you cant adjust it yourself. Any other internal upgrades in the slide?
    TomTwo likes this.
  6. Dec 2, 2018 at 5:52 PM
    #1306
    IPNPULZ
    IPNPULZ Well-Known Member
    Deeper in the South…….
    2023 TRD Off Road Premium 4R
    going to be fun!
    Check the trigger I put a ZEV fulcrum trigger in mine and made a slight adjustment and it was a little much as it went full auto
  7. Dec 2, 2018 at 5:59 PM
    #1307
    Hstone556
    Hstone556 Ain’ters gonna ain’t
    Hunter
    Austin
    2019 Ram 2500 Laramie
    Raceline 17" Gauge's 37x12.50 Toyo's RT, Carli King 2.5s
    I’ve ran zev/silencerco and I’m currently running a Lantac in my new 19. They all do the same job.
    TomTwo likes this.
  8. Dec 3, 2018 at 6:21 AM
    #1308
    LMarshall73
    Lee
    Cocoa, FL
    2012 DCSB TRD Sport
    Check the firing pin. The base could be worn or damaged which can prevent it from fully engaging the trigger bar. Unless it's an unintentional bumpfire (which I have done with my G19), the firing pin is the first thing I'd check, followed by the trigger.
  9. Dec 4, 2018 at 6:29 PM
    #1309
    Hstone556
    Hunter
    Austin
    Threw the RMR on the new girl
  10. Dec 7, 2018 at 2:04 PM
    #1310
    assaultthesalt
    assaultthesalt Well-Known Member
    2014 4x4 Tacoma Longbed
    I wore out a factory striker at 25k in my Gen3 19......went full auto aswell.
    Scribbles likes this.
  11. Dec 16, 2018 at 9:28 PM
    #1311
    hillbillytoyo
    hillbillytoyo Well-Known Member
    Daniel
    WV
    17 Tundra Crewmax SR5 TRD Off Road.
    G2 bed cover
    I got a killer deal on a gen 4 19 this week. Its was brand new but classified as "blemished". It had 2 scratches on the right side of the slide but other than that it was perfect. Ended up trading a Ruger LCR 357 mag that I've carried on and off for about 3 yrs. and $50. I was asking $400 cash but then asked about trading.
  12. Dec 18, 2018 at 5:10 PM
    #1312
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    How big of a job is it to replace all the frame pins in a gen 4? I've never done it but the gf wants OD green pins
  13. Dec 18, 2018 at 5:19 PM
    #1313
    Hstone556
    Hunter
    Austin
    Best video showing the process
    https://youtu.be/QNbcP-4uqCw
    JimBeam[QUOTED] likes this.
  14. Dec 18, 2018 at 5:21 PM
    #1314
    John31s
    John31s Well-Known Member
    Wuawatosa WI
    '16 DCSB
    Easy. Done in under five minutes.
  15. Dec 18, 2018 at 5:28 PM
    #1315
    JimBeam
    JB
    2015 Tundra
    I figured as such but wanted to make sure before I go popping pins out
    TomTwo likes this.
  16. Dec 18, 2018 at 6:23 PM
    #1316
    hillbillytoyo
    Daniel
    WV
    G2 bed cover
    20181217_165821.jpg My 1st gen 4.
  17. Dec 22, 2018 at 6:12 PM
    #1317
    TomTwo
    TomTwo I love God but I cuss a little
    Bill
    I-85 Southbound
    2013 TRD Double Cab Sport
    Anybody have a Overwatch precision TAC Trigger in there Glock. ??
  18. Dec 22, 2018 at 6:13 PM
    #1318
    BulletToothTony
    I’ve got the TAC and the DAT
  19. Dec 22, 2018 at 6:13 PM
    #1319
    TomTwo
    Bill
    I-85 Southbound
    The only pin that is tricky is the large trigger pin but if you wiggle the slide release while putting pressure on the pin it will pop right out.
    Enigma8246 likes this.
  20. Dec 22, 2018 at 6:15 PM
    #1320
    TomTwo
    Bill
    I-85 Southbound
    @BulletToothTony I really want to put a TAC in my G43. I think it will improve my groups. Where did you get yours from ?
