Glove box latch calibration!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Wcd7109, Apr 15, 2025.
  1. Apr 15, 2025 at 8:15 PM
    Wcd7109
    Wcd7109 [OP] Well-Known Member
    2006 Tacoma
    The latch on my 2006 glove box stopped engaging. I tried disassembling it to figure out what the problem was, and the mechanism basically fell apart. Went to Toyota to find out that a new glove box is $350! Went on eBay and got a used one for $95 including shipping. Installed it, and the latch didn't engage!! Contacted the seller and he said they tested it in the truck before they shipped it and it worked, but he would arrange a return. I happened to dig around a little more on YouTube and found a post regarding a 2013 Tacoma, that said you could calibrate the latch. You use a small screwdriver to open the latch as far as it will go, then engage the handle on the front of the glove box. Damn if it didn't work! So, the latch must have come out of "calibration" during shipping.
    The not so funny thing is that I probably could have done this to my original glove box before I tore it apart! The little tab on the bottom center of the box was broken off, but I never did knew what it did, in the box worked fine until it stopped latching!
    Oh well, glad I didn't go for a new $350 box!!
    Hay Lobos and Superdave1.0 like this.
  2. Apr 15, 2025 at 8:20 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Lots of things can cause a glove box to go out of alignment. Including you the owner, heavy stuff inside of it, removal, removal for motor work, removal for ECU access.
  3. Apr 15, 2025 at 8:21 PM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    You can get the latch separately.
    https://www.amazon.com/Toyota-55506-60020-B1-Glove-Compartment-Assembly/dp/B01EVKPAZY
    Superdave1.0 likes this.
  4. Apr 15, 2025 at 8:46 PM
    Wcd7109
    2006 Tacoma
    You left out front end collision with an 18-wheeler! I shared a solution, and you came up with five different problems. Thanks for sharing!
    Superdave1.0[QUOTED] likes this.
  5. Apr 15, 2025 at 8:49 PM
    Wcd7109
    2006 Tacoma
