glove box wont open-any tips
Discussion in '2nd Gen. Tacomas (2005-2015)' started by madcatter, Aug 13, 2013.
  1. Aug 13, 2013 at 5:48 PM
    madcatter
    madcatter [OP] Well-Known Member
    western pa
    2010 tacoma
    jl audio stealthbox jl audio slash g2-500/1v2 good year dura-tracs jl audio g-class 50wattX2amp mb quart 5 1/4" rear matted mb quart 6.5 comp.set lotsa dynamat 4ga amp kit 16 gauge wire kit control knob on dash pioneer avic-x910bt in dash navigation dvd playback sirus tuner/bus interface built in blue tooth toyota environmental package leaf tsb weather tech floor liners yellow wire mod gray wire mod compartment bed lights added tie down d rings
    i had it out to do the yellow wire mod and when i went to install it i couldnt get it to stay shut,seen it was the wire i have in there for ipod and also usb so i moved it and go it to close,no slamming just a normal push...now the dam thing dont open,and advice
  2. Aug 13, 2013 at 6:10 PM
    JaxJim
    JaxJim Well-Known Member
    Jim
    Jacksonville, FL
    13 TRD Sport, DCSB, 4x4, JBL, NAV
    Exterior: Duratrac 265/70/17, SpiderTrax 1.25" wheel spacers, BAMF sliders, DiamondBack SE Tonneau Cover, Pop&Lock, Tail Gate guard, Bed Mat, Bullaculla Trailer Harness bracket, Front Side Windows tinted to match rear, Removed all chrome and dealer badges, Toyota OEM Roof Rack/Rails, SOS Concepts Front Recovery bracket Under Hood: Redline Tuning Quicklift Hood Struts, Foglight anytime mod, UniFilter for Secondary Air Pump Interior: Seat bell Chime disable (TechStream), WeatherTech floor liners, ImMrYo rearview mirror relocation bracket, 12v Always-on Power port in console Radios/Comms: AntennaX 14", Escort Passport MAX Radar Detector, Yaesu 2900 Ham Radio, Uniden 980SSB CB Radio, Relentless Fabrication hood antenna mount, BAMF tailgate antenna mount, FireStik 2m and CB antennas, FireRing coax
    I feel your pain. I had something similar with a 68 Camaro. The push button broke and the door would not open.
    I had to cut out the cardboard liner to get to the back of the button. I know that's drastic, but it was not an expensive part to replace.
    Can you get to the hinge from underneath? It's dark here and I'm lazy or I'd go out and look. If you can get to the hinge maybe you can remove the door that way and fix the latch.
  3. Aug 14, 2013 at 3:47 AM
    madcatter
    western pa
    2010 tacoma
    That's what I need-- some sunlight.I believe I can get to the hinge but I think maybe the latch may be still locked to the hinge....i wish I had a pic of the back of the box so I could plan my attack
  4. Aug 14, 2013 at 8:50 AM
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    take a little of this
    and one of these
    and bam open.
    Then start thread on how to repair glove box you can not close?
    JK
    Does it fell like the latch is working? I had mine stuck once and I realized it was just junk stuck in the way and I just had to shake and pull hard to open. After I moved the stuff around it worked just fine.
  5. Aug 14, 2013 at 12:36 PM
    madcatter
    western pa
    2010 tacoma
    Feels like the latch isn't opening it at all....I will do some minor operation after work.it can't be to bad right lmao....only plastic
  6. Sep 11, 2013 at 6:55 PM
    mojo
    mojo Active Member
    Safety Harbor, FL
    06 Prerunner long bed
    nerf steps, hard bed cover.
    I've got just the opposite. After replacing the cabin air filter, put the glove box back on and it will not latch shut, stays open. The handle works but the little wheel in the door does not catch the loop. Any ideas.
    MOJO
  7. Sep 12, 2013 at 8:54 AM
    madcatter
    western pa
    2010 tacoma
    Update,,,,I destroyed it.its broken now.ripped something off that broke and it now closes and Poe s but ya gotta pinch two plastic tabs that the broke off part operated before.
