glove compartment door stopper
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Karo, Jun 6, 2010.
  1. Jun 6, 2010 at 3:08 AM
    Karo
    Karo [OP] Well-Known Member
    Karo
    La Crescenta, CA
    06 PreRunner TRD Sport
    Grill
    does this stopper really help lower your glove comp. slowly? mine comes crashing down every time i open it.
  2. Jun 6, 2010 at 4:01 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Yes....it does work when its connected.
    Yours probably came off . Just re-connect it.
    It's notorious for coming off especially if you've removed it enough times to change the cabin filter. The damn thing never stays on. I put a screw in mine to prevent it from disconnecting.
  3. Jun 6, 2010 at 12:11 PM
    005Tacoma
    005Tacoma Well-Known Member
    Thomasville, Georgia
    2005 Toyota Tacoma
    Mine was never connected. Soo I tossed it out.... the window lol jk but I did throw it away.
  4. Jun 6, 2010 at 12:19 PM
    Rucas
    Rucas 1st gen > 2nd gen
    Lucas
    Northern Colorado
    1st gen. 4x4 MANual
    sparkles, fairys, and happy things.
    Where did you put the screw into? mine keeps comming off so this is a good idea. Pics?
  5. Jun 6, 2010 at 12:27 PM
    m0nster986
    m0nster986 ♥ Emergency Medicine
    SoCal
    Same problem.
  6. Jun 6, 2010 at 6:51 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Scroll down to the pictures in post #6 in the link below. Install the damper on the dash (insert hole B in damper over tab B on the dash...see pics). Then find a wide, but short, screw and install it between the two spreadable ends of the tab (B). It will hold that damper on until you remove the screw. Mine's been this way for over 5 years. Another option is to place some 3M double-sided tape in between the tabs once the damper is on.
    http://www.toyotanation.com/forum/showthread.php?t=283727&highlight=damper
  7. Jun 7, 2010 at 4:09 AM
    Janster
    Jandy
    Lancaster, PA
    X2
    I can take a picture of the screw if anyone needs me to (might be a day before I can do that). It's not pretty....
    Just this week I removed the shock absorber by disconnecting it at the glove box side so I didn't have to pull the screw out. I'm sure that side (black prongs) will need repaired eventually also. :rolleyes: Plastic...:rolleyes:
  8. Jun 7, 2010 at 9:51 PM
    Karo
    Karo
    La Crescenta, CA
    Grill
    So is this stopper suppose to help lower the glove box really slowly? Or just a little slower than just free fall? Because mine opens up a bit slower than free fall, no dramatic difference between it being on or off. Is it broken?
  9. Jun 8, 2010 at 4:03 AM
    KINGY2
    KINGY2 Member
    I threw that piece of shit in the garbage .
  10. Jun 8, 2010 at 4:17 AM
    Janster
    Jandy
    Lancaster, PA
    Yes
    If your glovebox isn't free falling - then the damper is connecting and working.
    Go ahead and disconnect it and you'll see the difference.
  11. Jun 8, 2010 at 5:52 AM
    rb11701
    rb11701 Oh yeah!
    Rob
    '09 Silver Streak TRD Off-Road
    Rear Suspension TSB, DTRL Mod, aFe Pro-Dry S,USA Spec PA15-TOY iPod Adapter, Dynolock Tailgate Lock, UltraGauge OBDII Scanner, CoverKing Neoprene Seat Covers
    I used a piece of cardboard folded up a few times. I stuffed it betweenthe forks of the tab that holds the damper on. I was going to use a screw, but I wanted something easy access. If you don't use the damper and that thing falls, its a loud bang and can't be good.
  12. Jun 8, 2010 at 9:31 AM
    Silver06Taco
    Silver06Taco Well-Known Member
    WA state
    Silver 06 DC TRD Sport
    I recently put mine back on as it wasn't on when I bought the truck used a year ago. I think it makes a big difference, almost to where I thought it wasn't going to open.
  13. Jun 10, 2010 at 1:24 AM
    Karo
    Karo
    La Crescenta, CA
    Grill
    uhh can you please post a pic of this cardboard/screw invention?
  14. Jun 10, 2010 at 6:12 AM
    Dr. Pepper
    Dr. Pepper Well-Known Member
    Tampa, Florida
    08 PreRunner SR5
    All this time, I thought that was a coin holder for quarters, no bullshit...lol.
    Gee, now I know...thanks guys!
  15. Jun 10, 2010 at 6:16 AM
    rb11701
    rb11701 Oh yeah!
    Rob
    I'll try later today. Basically, on the truck there is a tab. On this tab there are to arrow-looking tabs. On the damper there is an eyelet. The arrows go through the eye on the damper. When brand new, the tabs will stay apart to keep the tension tight. After a few times removing it or pulling on the glovebox it can lose some of that tension and fall off. I stuck that folded piece of cardboard between the arrow looking tabs. That kept the tension tight. IIRC, I put the top on first (where the cardboard is) and then extended the damper and attached it to the glovebox. Hope that helps.
  16. Jan 2, 2013 at 7:25 PM
    canucktacoma
    canucktacoma Active Member
    mike
    gta area, ontario canada
    sr5
    good post was wondering what it was,stopped at dealer to find out,mine's not on ,will try to reattach,
  17. Mar 14, 2014 at 4:03 PM
    poggyg
    poggyg Member
    British Columbia
    Tacoma 2010 4x2
    thanks lots----confusing setup!!
