Glove compartment help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rucas, May 22, 2010.
  1. May 22, 2010 at 12:55 PM
    Rucas
    Rucas [OP] 1st gen > 2nd gen
    Lucas
    Northern Colorado
    1st gen. 4x4 MANual
    sparkles, fairys, and happy things.
    on the 2nd gen tacomas the glove compartments have that lil ole device that eases down the glove compartment when you open that. somehow mine came unattached and now the compartment just slams down whenever i open it.
    How do i reattach this?
  2. May 22, 2010 at 1:00 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    it just slips on the tab, take the glovebox out by pulling up while its open, and then you can see where it is supposed to attach
  3. May 22, 2010 at 1:04 PM
    Rucas
    Lucas
    Northern Colorado
    1st gen. 4x4 MANual
    ahh thanks!
  4. May 22, 2010 at 4:44 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    Pics for you in case you don't know which hole goes on which tab. Post #6 has the pics with everything labeled. And if it fell off once, it'll likely do it again. You'll want to put a screw in between the tabs on the dash mounting tabs to keep them spread apart with the damper on. That way it won't ever fall off again when you unhook it from the glove box end.
    http://www.toyotanation.com/forum/showthread.php?t=283727
  5. May 22, 2010 at 5:11 PM
    redezman
    redezman Well-Known Member
    Charles
    Raleigh N.C
    2012 4Runner SR5 4x4
    All Factory for now, LOVE it that way
    mine keeps coming off, so i left it off
