GloveBox Light Install
Discussion in '1st Gen. Tacomas (1995-2004)' started by Mxer256, Feb 25, 2014.
  1. Feb 25, 2014 at 10:46 PM
    Mxer256
    Mxer256 [OP] Well-Known Member
    Tyler
    Mississippi
    2012 Prerunner
    2012 Tacoma Trd sport, 10" bulletproof lift with traction bars and icon resi rear shocks, custom headlights and tail lights, 24x14 American force jades,37x13.50x24 Toyo mt, 1" borla wheel spacers, 30" lightbar, new build so more to come come
    So the other day i saw a post about a glove box light and got excited thinking i had one, well i checked and didnt and that made me want one. So i decided i would and id make my first write up on how to do it! Here we go:
    Supplies needed:
    Drill
    Screw Light(pictures below)
    I got them off ebay
    zip tie or t-tap
    Step 1: Empty glove box
    Step 2: Push sides of glove box in so the glove box can fold downward like this,
    Step 3: Unscrew the three screws with a 10mm socket that hold the inner glovebox in, the screws are in the back middle and top left and right corner:
    Step 4: Disconnect the wiring harness from the Panel piece:
    Step 5: Find a drill bit thats the same size as the thread of the screw on the light and drill a hole here and insert the light and tighten the nut down on the other side:
    Step 6: Wire it up! I wired the ground to a ground under the dash to a screw and for the positive i wired and tapped it into the positive of the ash trey light so as long as that light is on the glovebox light comes on. I probably should of used some t taps to tap into the wire but i didnt have any so had to improvise. I just stuck the wire into the socket part and zip tied the wires together so it wouldnt come lose and come out: IMG_4747[1].jpg
    Step 7: Put everything back together! Now for those nights you get pulled over and go to get insurance or for whatever other reason you need something in your glovebox youll have some lighting so you can see:D
  2. Feb 25, 2014 at 10:48 PM
    Mxer256
    Tyler
    Mississippi
    2012 Prerunner
    Of course id have to have an issue on my first write up:mad: anyone know how to get all the pics on?
  3. Feb 26, 2014 at 5:15 AM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Try uploading them instead of making them attachments.
  4. Feb 26, 2014 at 6:08 AM
    Mxer256
    Tyler
    Mississippi
    2012 Prerunner
    How would I do that? I don't understand what you mean
  5. Feb 26, 2014 at 6:09 AM
    PcBuilder14
    Brent
    Nor Cal
