Glovebox problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Anthony999, May 17, 2009.
  1. May 17, 2009 at 3:41 PM
    Anthony999
    Anthony999 [OP] Well-Known Member
    Glendale, AZ
    05 Tacoma
    MB Seven X Wheels, Hankook Optima Tires, Billet Grille, Blacked out headlights tailights and third brake light, LEER 700 Series tonneau cover, Blacked out emblems, Wolo air horn, Sony Xplod stereo, 8" Bazooka subwoofer, painted to match bumpers, leather arm rests.
    Last night I got into my truck and opened up my glovebox to get my garage door opener out and instead of going down slowly like it should, it just dropped. I noticed one peice in the shape of a plastic tube looking thing was moving around.
    Any idea of what this is and how to fix it?
  2. May 17, 2009 at 3:44 PM
    Lentsnh
    Lentsnh Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    its the damper just pop it back into the snap
  3. May 17, 2009 at 3:44 PM
    Brunes
    Brunes abides.
    Rotorhead
    There is a piston over on the far passenger side of the glove boxe....Go in and make sure it's connected to both pins. They pop off pretty easy.
  4. May 17, 2009 at 3:45 PM
    Lentsnh
    take the top hole on the damper and snap it into the snap(?) on the dash
  5. May 17, 2009 at 3:45 PM
    Anthony999
    Glendale, AZ
    05 Tacoma
    I looked in there and I could only see one pin, but ill go take a second look. Thanks
  6. May 17, 2009 at 4:04 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Its plastic, easy to pop in. Good luck!
  7. May 17, 2009 at 5:18 PM
    TTU Ryan
    TTU Ryan Active Member
    Houston, TX
    06 Prerunner TRD, SR5, Double Cab
    Ipod Interface
    same problem here. I was able to pop it back on the pins...but since they are just plastic once I open and close the glove box a few times it just pops off again. havent found a solid fix yet.
  8. May 17, 2009 at 5:23 PM
    mws4ua
    mws4ua I'll try being nicer if you try being smarter.
    Birmingham
    Sold my truck Jan '13... Still hang around.
    I have the same problem. I've put it back on a number of times but it just won't stay. I gave up... my glovebox bangs open every time now. Oh well.
  9. May 17, 2009 at 5:24 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    hey i actually just did a write up on this with pictures. Waiting for it to get moved out of the test section
  10. May 17, 2009 at 5:26 PM
    DanGer
  11. May 17, 2009 at 6:22 PM
    steviestyles
    steviestyles The "Search" tab is your friend!!
    Colorado Springs
    07 DC 4x4 TRD Off Road
    Bone Stock
    There should be a peg on the dashboard the plunger hooks onto, and a peg on the glove box that the extending arm of the plunger connects to. If the plunger body keeps falling off the peg on the dashboard, take something like a small piece of paper or cardboard and fold it into a very small rectangular piece. Lodge it into the peg where the slit is . Chances are the peg doesn't expand enough to hold the plunger in place. It's a crappy design. Some people have used a screw in the peg, I use an eraser from a mechanical pencil. Mine doesn't fall off anymore.
    I found the easiest way to reconnect everything is to hook the bottom eyelet on the plunger body to the peg on the dash board, pull the pluger arm down, it comes out quite a bit. I then move the glove box halfway closed and connect the plenger arm to the peg on the glovebox, and voila....all good. It's hard without pictures to show all of this.
  12. May 17, 2009 at 6:35 PM
    MotoTacoma
    MotoTacoma Adrenaline Addict
    Pencilveineeya
    14 tundra crewmax trd
    tacoma sold 11/13/13 Not much on Tundra yet, just Husky Weatherbeaters front and back
    if you have any friends w/taco's, look at how the "shock/plunger/damper" is installed, i dropped my glove box to do some work, and if i didn't pay close attention to how it went in, no way would i have figured it out, it's weird.. a minor fix, just need to figure it out.. good luck
  13. May 17, 2009 at 7:00 PM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    just rip that piece of junk off. haha
  14. May 17, 2009 at 7:39 PM
    jeremiekc
    jeremiekc Well-Known Member
    Jeremie
    Vilseck, Germany
    07 Regular Cab Base Model
    Secondary Air Filter removed, Painted Brake Calipers, AFN Drop in air cleaner, OEM Chrome Bumper, OEM Chrome grilll, OEM Cruise Control, OEM Interval Wipers, Hard Wired Garmin Nuvi 670, X-Runner Rims, Devil Horns, 6000w HID's, Bling Light Fogs with Blue Halo, OEM Bilstein Rear Shocks, 12V Plug in Truck Bed pocket. Debagged, 13" Antennax, Color Matched Satoshi Grill, URD Short Shifter, WeatherTech Floor Mats, PainLess Wiring Switched Fuse Box, Black Sand Pearl X-Runner Badges
    The peg goes in the second hole on the plunger. The peg on mine was really worn out from taking the glove compartment off a million times (love those mods) so I took it to the dealer and told them to fix it since it is still under warranty. Now I have a new piece that actually matches the color better.
  15. May 17, 2009 at 9:00 PM
    Anthony999
    Glendale, AZ
    05 Tacoma
    Alright I tried to fix it but was having trouble. Im just gonna look at my dads when he gets home and go from there
  16. May 17, 2009 at 9:00 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Good Idea!!
    My plunger keeps popping off. I hate that thing!
  17. May 17, 2009 at 9:05 PM
    Anthony999
    Glendale, AZ
    05 Tacoma
    x2 I should do that
  18. May 18, 2009 at 6:17 AM
    Rocketball
    Rocketball If The World Didn't Suck, We'd All Fall Off
    Scott
    Westminster, MD
    08 Speedway Blue DC Sport 4x4
    Pioneer head unit, PAC steering wheel control modual, Hard wired Sirius radio, Hard wired radar detector, Hella Supertone horns, Blacked out badges, Smoked Tails, BHLM (color matched Speedway Blue), T-Rex Eyelids, Black Powder Coated Billet Grill, Color Matched Engine Cover, Lund in channel vent visors, FJ Cruiser wheels, Leer 100XQ shell, OEM bed mat, Piezo beeper for locking doors, Tinted front side windows, Black Westin bull bar, Aires tube steps, Mini Maglite Mod, D-Cell Maglite Mod, Weathertech Digifit Floor Mats
    This is a bad piece of engineering IMO..... Mine no longer works correctly either. :cool:
  19. May 22, 2010 at 7:06 PM
    wvtac0
    wvtac0 Well-Known Member
    Eastern Panhandle - WV
    17 TRD DC Sport
  20. May 22, 2010 at 7:09 PM
    MxRacer190
    MxRacer190 Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    It's not that heavy. Just use those thing coming out of your shoulders to let it down slowly.
