glueless vent visors
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rphillips, Oct 1, 2020.
  1. Oct 1, 2020 at 5:45 PM
    rphillips
    rphillips [OP] Well-Known Member
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    Years ago I had vent visors without glue. Pull the weather stripping down, put clips up in track, & push weather stripping back in. Weather stripping held the vent visors in. All I'm seeing now glue on, either on outside of door or up in the track. Anybody know of the old glueless ones available anywhere for a 2013 Taco ?
  2. Oct 1, 2020 at 6:24 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    WeatherTech In-Channel
    I’ve had mine for 13 years now.
    They’ve been on 2 different trucks.
  3. Oct 1, 2020 at 7:59 PM
    vtdog
    vtdog Well-Known Member
    NH
    One of the rear vents fell out of my truck while on a washboard road. The vents had been installed about 8 years before it came out. I was able to recover the vent as it was not broken. I re-installed it using some clear window caulking and then removed/installed the one on the other side. You can't see the glue as I put it on the inside of the channel tab and made an effort to use it sparingly in only a few spots. So far, so good. The fronts fit much "tighter" so there does not seem to be a problem there.
