GM Alternator Upgrade Problem
Discussion in '1st Gen. Tacomas (1995-2004)' started by Southern01Taco, Feb 12, 2014.
  1. Feb 12, 2014 at 12:32 PM
    Southern01Taco
    Southern01Taco [OP] Well-Known Member
    Sean
    Holden, La
    01 V6 4x4 Xtra Cab SR5
    For those of you that have upgraded your alt. to the gm144, have yall had the top bolt break? I have broke two recently and it backs out and cut my supercharger belt. It shredded a belt on my way to work this morning only to find out that the bolt broke and backed out. I just put a brand new bolt in about a month ago because the original broke. Both of them broke in the exact same spot, right where the threads start. It actually breaks slightly in the alternator bolt hole which leads me to believe that its not shearing off from the weight of the bigger alt. I thought I might have over torqued the first one so the second one, I just barely snugged it up. I'm kind of at a loss. My next thing to try is to figure out what threads the bolt is and put a grade 8 bolt in there. If that doesn't work then I'm going to drill out the threads in the back and put a bigger bolt with a nut on the back. Does anyone know off hand what size bolt it is?
  2. Feb 12, 2014 at 1:20 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    ive had no issues at all.
    Do you have the lower mount setup right?
  3. Feb 12, 2014 at 2:15 PM
    Southern01Taco
    Sean
    Holden, La
    Yea I'm pretty sure I do. I'm going to check to make sure all of the bolts are tight on the brackets when I get home from work. I had it installed for a while before the first bolt broke but it only took a few weeks to break the second one.
  4. Feb 12, 2014 at 3:00 PM
    offrdmania
    offrdmania Taco Wagon
    Templeton, Ca
    96 Tacoma LX 4 banger
    Are you using at least a grade 8 bolt?
  5. Feb 12, 2014 at 3:15 PM
    Southern01Taco
    Sean
    Holden, La
    I'm using whatever the factory bolt is. The first bolt was the original that came with the truck and I got the second one from the dealership so it was a toyota replacement.
  6. Feb 12, 2014 at 4:29 PM
    Dutchman
    Dutchman Active Member
    Up North
    02 2.7 5sp SC 4X4
    "If that doesn't work then I'm going to drill out the threads in the back and put a bigger bolt with a nut on the back."
    That is the best way to solve this problem.
  7. Feb 14, 2014 at 3:12 PM
    Southern01Taco
    Sean
    Holden, La
    Just for future reference for anyone that has this problem and finds this thread, I looked for a high strength bolt that would bolt back in like factory but couldn't find anything. The original bolt is a M10 x 1.25 x 97mm. I went ahead and drilled out the sleeve, alt., and threads to a 7/16 hole and put in a grade 8, 7/16 x 4-1/2" bolt with locking nut. I had to pull out the cast iron bracket and the alt. in order to drill them but that was easy. The bracket is held in by 3 bolts. I also did away with the little sheet metal cover on the back of the alt. bracket.
