GMF Bolt on Rear Shock Relocate for 2nd/3rd Gen, back in production
Discussion in 'Automotive Group Buys' started by Arcticelf, Oct 22, 2020.
  1. Oct 23, 2020 at 9:50 AM
    #41
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    Well if it’s possible to get 13” of travel I’d rather get a 14” shock and not have to worry about using the shock as a limit strap :notsure:
    I’d also think that maxing out your leaf pack would be preferred over maxing out the shock.
    EatSleepTacos likes this.
  2. Oct 23, 2020 at 9:59 AM
    #42
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    You don't want your leaf pack to lock out when it gets over extended on the trail, that's gonna make for a bad day. When @desertjunkie760 did my install we were able to cycle the rear with everything in place and then he was able to properly setup the shocks for my specific circumstances.
    Arcticelf[OP] and Bigdaddy4760 like this.
  3. Oct 23, 2020 at 10:08 AM
    #43
    PcBuilder14
    Brent
    Nor Cal
    Well if your locking out your leaf pack via the shackle then that’s the shackle or shackle hangers fault. Archives V1 shackles were bad about that. At that point you still don’t want the shock limiting your leaf spring travel.
    whatstcp likes this.
  4. Oct 23, 2020 at 10:12 AM
    #44
    hoarder23
    Shay
    NJ
    Scratches
    Edit: I'm tarded.
  5. Oct 23, 2020 at 10:20 AM
    #45
    Arcticelf
    Arcticelf [OP] Well-Known Member
    Gladiator
    You'd want to cycle the pack to be sure, but most OEM geometry packs struggle to make 12" of travel. You can also use limit straps to protect the shock (always a good idea)
  6. Oct 23, 2020 at 10:20 AM
    #46
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    Depends on application. Do you run limit straps on the front suspension because your shock is also the limiting factor there? You're not going to damage a Fox 2.5" Factory Race shock by using it as a limit strap on a truck that isn't bombing the desert. If you do, something is wrong with the setup. An expo rig won't have this issue.
    Hell, do you run limit straps on your current setup? The factory shock is the limiting factor in factory rear suspension Too.
    ^This
    PcBuilder14[QUOTED] likes this.
  7. Oct 23, 2020 at 10:24 AM
    #47
    PcBuilder14
    Brent
    Nor Cal
    Bumps stop don’t limit overextending your downtravel.
  8. Oct 23, 2020 at 10:26 AM
    #48
    desertjunkie760
    Shane
    Check My Sig.
    yeah, not sure where he was going with that. Haha
  9. Oct 23, 2020 at 10:27 AM
    #49
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Why does it have to be uptravel? You could just be losing out on downtravel. I've installed a couple archive/14" set ups and we didn't limit uptravel in any way. The leafs just don't take full advantage of all the droop, but it's nice to squeeze out as much as possible vs limit downtravel with straps to protect the shocks.
    All that aside, I'm happy with my 12" setup. Flexes just fine offroad.
  10. Oct 23, 2020 at 10:29 AM
    #50
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    @Arcticelf Im interested, add me to the list.
    Arcticelf[OP] likes this.
  11. Oct 23, 2020 at 10:31 AM
    #51
    hoarder23
    Shay
    NJ
    Scratches
    Yeah, I'm tarded, was confusing two different issues we encountered
    desertjunkie760 and Bigdaddy4760 like this.
  12. Oct 23, 2020 at 10:34 AM
    #52
    PcBuilder14
    Brent
    Nor Cal
    All good. Regardless this kit if set up right probably outperforms most mid travel setups anyways haha
  13. Oct 23, 2020 at 10:37 AM
    #53
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    I'd give my input on the 14" shock debate but mine is far from what AG even had envisioned. With my 63s and the shackle geometry and where I have the shock relocate set and lower shock mount set I can shove a 16" shock and cycle all of that shock and then some. My shock is my limiting factor in both droop and bump. I don't think there is an exact perfect you need to do this because once you start getting into shock relocates and such it really is to the point of match it to your set up vs go based on what others tell you. That being said companies like AG have a lot of data from a bunch of different set ups to get you close and you can look at those as a starting point.
  14. Oct 23, 2020 at 10:40 AM
    #54
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Not sure if it’s been asked... lower shocks mounts still need welding won’t they? So at that point, might as well weld everything for proper strength
    plurpimpin and whatstcp like this.
  15. Oct 23, 2020 at 10:46 AM
    #55
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Yeah they’re longer, so the lower mount just gets clocked down a little bit. Again, the bump stops haven’t had to be moved or spaced out or limited up travel in anyways on the few I’ve done. And I’ve verified they’re not bottoming out prematurely.
  16. Oct 23, 2020 at 10:48 AM
    #56
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Yes where ya'll with the go fast may ende up wanting to set them up to have over 50% bump we set them up where it's from 50/50 to 70/30 droop/bump.
  17. Oct 23, 2020 at 10:52 AM
    #57
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    The beauty of this lower shock mount is that it is fully adjustable by just clocking the lower mount higher or lower.
    I can possibly see me adjusting this if I change leaf packs and/or leaf shackles.
    Arcticelf[OP] and PcBuilder14 like this.
  18. Oct 23, 2020 at 10:55 AM
    #58
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Do they make 16" short bodies?
  19. Oct 23, 2020 at 11:01 AM
    #59
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I have a friend running billy 7100 14” short body and loves them.
    ovrlndkull and whatstcp[QUOTED] like this.
  20. Oct 23, 2020 at 11:04 AM
    #60
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    @Arcticelf , would it be possible to just order 2 axle mounts, one for each side and not the upper half? Can you PM me a price if this is possible?
