GMRS antennas
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Blueberry.Taco, Feb 14, 2021.
  1. Feb 16, 2021 at 12:42 PM
    Blueberry.Taco
    Blueberry.Taco [OP] blueberry.taco (IG)
    Ryo
    Fulltime Overlanding
    Long travel house on 35s with a custom aluminum utility bed and FWC
    some welding required
    WHOA there's a lot of antenna mount/wire options.
    So now that I'm committing to PL-259 termination, still some options to figure out.
    I saw midland's bundle kit uses a FME female connection with a FME male to PL259 male adapter.
    this makes sense to help with passing the wire end through tight spaces and the firewall.
    I might try to replicate this idea, unless someone tells me to just buy the Midland one and not worry about other brand name things....
    17ft or so seems to be the average shorter length cable option. I assume similar to CBs, arbitrarily shortening this is a bad idea?
    Summarizing my current finding options: (prices are just list prices, not including shipping/etc)
    for options that terminate in FME connectors
    Option 1) Larsen NMOKHFUD: 17ft, $24.95 for either male or female FME, 0-6000MHz, Brass, RG-58 dual shield
    Option 2) Larsen NMOKHFUDFME: 17ft, $18.95, FME Female, 0-6000MHz, Brass, RG-58 dual shield
    Option 3) PCTEL Maxrad MLFML195-NC, 17ft, $26.95, FME male or female, 0-6000MHz, Brass, ProFlex Plus 195
    Option 4) Laird Technologies MABT8, 17 ft, $26.95, FME male or female, 0-1000MHz, Brass, RG58/U
    Option 5) PCTEL Maxrad BMA-NC, 17ft, $26.95, FME male or female, 0-1000MHz, Brass, RG58/U
    Option 6) Laird Technologies MABVT8, 17ft, $29.95, FME male or female, 0-1000MHz, Brass, RG58A/U
    with generic FME to PL259 adapters on Amazon around $5-$10
    so questions for you smarter/more experienced people.
    Q1) aside from literally the hole size, is there a performance difference between 3/4"NMO vs 3/8" NMO?
    Q2) cable list frequencies, do I want a smaller window around 465MHZ like 0-1000, or is wider better like 0-6000?
    Q3) Is there a preference/superiority on the cable types between RG-58, RG58/U, RG58A/U, RG-58 dual shield, Proflex Plus 195, etc?
    Thanks
    Options below I started listing, these are straight to PL-259 connector, keeping it here just because i made the list, but probably not going this direction.
    Option A) Laird MB8PI: $22.95
    Material Brass
    Frequency 0-1000 MHz
    Connector PL-259 Connector Installed
    Cable Type RG58/U
    Cable Length 17 feet
    Option B) Larsen NMOKHFUDPLI: $24.95
    Material Brass
    Frequency 0-2500 MHz
    Cable Type RG58/U
    Option C) PCTEL Maxrad NMO58UCPI: $24.95
    Material Brass
    Cable Type RG58/U
    Option D) Larsen NMOK: $22.95
    Material Brass
    Connector PL-259 (UHF Male) Connector Loose Uninstalled
    Cable Type RG58/U
  2. Feb 16, 2021 at 1:58 PM
    Doc62
    Doc62 Well-Known Member
    Dave
    SE Pennsylvania
    2025 Tacoma TRD Off Road i-FORCE Max, 2019 Sahara
    Do you really want to drill? I used trunk lip mount NMO’s and ran the cable through the firewall and then terminated the coax after it was in the cabin.
    https://www.theantennafarm.com/catalog/index.php?main_page=product_info&cPath=264_267&products_id=1171
    Any RG-58 works good with GMRS for the distance you will be running.
    Also if you have excess cable, it is better to run it around vice coiling it up.
    Yota_MGM likes this.
  3. Feb 17, 2021 at 4:48 AM
    Blueberry.Taco
    Ryo
    I'm just welding on a tab on the front bumper hoop for the antenna so drilling either a 3/8" or 3/4" hole is no problem at all.
    is terminating the coax on a PL-259 just a matter of a crimp to the outside and a solder to the core? If that's all there is and nothing special I can handle that
  4. Feb 17, 2021 at 5:09 AM
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    I’ve always just gone with a 3/4. I’m not sure there really is a performance difference.
    Different pl259s go on different ways. There are the crimp on type, and there are some screw on types that sort of just wedge against the outer braid on the coax. I like the crimp on type. You can buy those on Amazon as well as a cheap tool to do it. A quick YouTube video and your ready to go.
    I usually end up running only as much cable as I need to my radio, cutting off the excess then crimping on a pl259 and soldering the tip for continuity.
    I’ve run various cable types...lmr240, rg8x, rg58. For short runs on a mobile your cable doesn’t really need to be anything special.
  5. Feb 17, 2021 at 5:12 AM
    TRD Ted
    TRD Ted Well-Known Member
    2020 Army Green TRD Pro
  6. Feb 17, 2021 at 5:18 AM
    JdevTac
    Josh
    MD/GA
    2nd gen
    They have the Aussie look but you could have probably same if not better performance from a much cheaper traditional antenna from Laird/Pctel/Maxrad/Larsen that maintains a slim profile.
    edit: they are also too robust to mount anywhere except something like a plate bumper for which they were originally designed. Hit a tree limb with that thing and it’s going to rip your sheet metal apart.
  7. Feb 17, 2021 at 5:49 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    haha yup, Ive been down this rabbit hole before trying to do what you are doing on the front bar. Still using my little stubby one on an NMO lip mount on the hood for now. No issues with that other than its starting to rust which I assume is probably not great for signal.
    Anyway long story short Im following along to see what you find.
    Those look cool, but damn are they expensive
  8. Feb 17, 2021 at 6:10 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    There is nothing special about GMRS antennas no magic they all work exactly the same. They have a frequency range that is the variable most are adjustable by length, generally the whip is to long for the band so it can be cut to tune or able to cover the range it was intended for by design. They make brackets that fasten to the bolts in the fender that the hood will close over. A 1/2 wave does not need much of a ground plane. There are numerous antenna manufactures to chose from don't buy a no name more than any thing else they are cheaply made they will work on the band intended like I said no magic but won't hold up in the weather or vibration, Dimond makes a very good mobile antenna for one. GMRS is a licensed band you'll need one no test just fill in the blanks.
  9. Feb 17, 2021 at 6:28 AM
    Doc62
    Dave
    SE Pennsylvania
    You should have seen my Tarheels HF screwdriver antenna offset mounted the the front hitch on my old 3/4 Suburban. I had to mount it there due to the platform I had on the rear for all the stuff we were taking on vacation to the Outer Banks with the kids. That antenna was definitely not tree safe (in this case the antenna would take out branches).
  10. Feb 17, 2021 at 11:34 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    I still have an older Tarheel It is my camper antenna (not for mobile use!). The Tacoma has a little Tarheel (6 to 80) it is mounted to the pillar at the tailgate inside the bed that was after the 3/8 24 coupler incident, snap in half and the antenna fell in the street thankfully a friend was following me and picked it up. Note to self don't buy MFJ couplers any more cast cheap brass with shiny chrome look.
  11. Feb 17, 2021 at 3:24 PM
    Blueberry.Taco
    Ryo
    Looks like soldering is pretty straight forwards and don't need a special crimper.
    shopping list looks like this
    Laird Technologies BB4502N $34.95
    PCTEL SMC-NC $17.95
    Larsen PL259 $3.95
    with a $9.64 shipping
    to total $60.80
    doesnt seem too bad, unless someone sees any reason I shouldnt go with this selection, I might be done researching. thanks for all your help!
  12. Feb 18, 2021 at 5:06 AM
    SR-71A
    Zack
    Southern Maine
    How are you going to mount it through the bracket with that setup?
  13. Feb 18, 2021 at 5:35 AM
    Blueberry.Taco
    Ryo
    I'll drill a 3/4" hole in a 1/8" thick 1.5" wide flat stainless bar I'm welding to the front bumper hoop.
    from the datasheet here it looks like
    "NMO Style Mounts - Stainless Steel “SM” Series 3/4” hole; 1-1/8”-18 thread; installs from above; can be used for metal thickness to 0.46”"
    so .125" thick plate should be good
    Am I missing something?
  14. Feb 18, 2021 at 5:45 AM
    SR-71A
    Zack
    Southern Maine
    Oh ok so I guess the larger outside threads must screw on/off from smaller threads in the center.
  15. Feb 18, 2021 at 5:51 AM
    #35
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Yes the NMO will work on any thing metal you can bore a hole in. 1/2 wave doesn't need a ground plane but the antenna needs to be grounded the ring on the NMO is the ground so it has to be tight and clean. The base of the NMO has a "T" shaped part with small "teeth" on it the 3/4" hole is important it just fits.
    Blueberry.Taco[OP] likes this.
  16. Feb 18, 2021 at 6:41 AM
    #36
    Blueberry.Taco
    Ryo
    Yup, the clean ground is the reason I'm going with stainless so I can keep it raw metal without worrying about corrosion.
    I'll add a ground stud to the bumper to tie to a frame ground too.
  17. Feb 18, 2021 at 9:15 AM
    #37
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    You can it won't hurt a thing but the vehicles of today are pretty will grounded and at 462 megs and 50 watts it's not much of an issue. The bigger issues come in the HF bands.
  18. Feb 18, 2021 at 9:19 AM
    #38
    JdevTac
    Josh
    MD/GA
    2nd gen
    it’s not really the NMO piece itself where you have to worry about corrosion. The exposed coax and where it mates to the NMO is the issue. Most are not weatherproofed or sealed assemblies so you will have to figure out how to keep water out otherwise your coax will corrode.
  19. Feb 18, 2021 at 10:46 AM
    #39
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Quality NMO's have a plastic cover and heat shrink at the end of the coax. Most installs are in the roof and the brass nut is "O" ringed so they don't leak. NMO's (New Motorola) have been around for decades some newer one are rated to 6000 Megs. Biggest issues I have see is with dissimilar metals at the actually mounting like brass and aluminum.
  20. Feb 18, 2021 at 11:31 AM
    #40
    Blueberry.Taco
    Ryo
    good point on the coax protection. I have plenty of adhesive lined heat shrink but without having the parts in hand im not sure heat shrink alone is going to seal the whole connection.
    I'll keep it in mind when I receive the parts.
    (the stainless I was talking about was the bracket on the bumper)
