GMRS radio sometimes turns on at startup
Discussion in 'Audio & Video' started by AtomAnt, Apr 18, 2023.
  1. Apr 18, 2023 at 2:09 PM
    AtomAnt
    AtomAnt [OP] Well-Known Member
    Adam
    South Cackalacky
    2019 TRD Sport
    I installed a Midland GMRS radio a few months ago. Since then, I’ve had it turn on by itself when I started my truck maybe 2 or 3 times. Any guesses as to why this happens or how to correct it? Positive is wired to a Blue Sea fuse block and negative is connected at the batteries ground point on the fender.
  2. Apr 18, 2023 at 2:12 PM
    toyotahenry
    toyotahenry N/A
    Houston, Texas
    2021 TRD OFF ROAD 4X4 ARMY GREEN
    i’m thinking it turns on once it senses any power whatsoever.
  3. Apr 18, 2023 at 2:18 PM
    AtomAnt
    Adam
    South Cackalacky
    2019 TRD Sport
    Power surge maybe? I also have a Northstar AGM battery. I know the have a little higher voltage than standard batteries. Maybe that has something to do with it? It’s not a huge deal as long as it’s not going to damage something.
    Taco 422 likes this.
  4. Apr 18, 2023 at 2:19 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    How do you turn it on normally?
  5. Apr 18, 2023 at 2:22 PM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Which radio? Mine has a knob you have to turn for it to come on, so that would freak me out. I'm guessing yours has the controls in the handset. Could be a sticky button or something, bad connector between the handset and base, or just a faulty unit.
  6. Apr 18, 2023 at 2:53 PM
    AtomAnt
    Adam
    South Cackalacky
    2019 TRD Sport
    Mine has all controls on the handset. Midland MXT575. Power button is on the top. I did check the connections and all seem fine(clicks into place solidly)
  7. Apr 18, 2023 at 2:58 PM
    AtomAnt
    Adam
    South Cackalacky
    2019 TRD Sport
    With the power button. I don’t think you get what I’m saying. With the radio powered off, it sometimes will turn on when I start my truck.
  8. Apr 18, 2023 at 3:19 PM
    0xDEADBEEF
    No I understand. I suspect that power button just sends a low voltage signal to a microcontroller to signal that it is time boot up the radio. That same process might be kicked off by some noise from the electrical system and causing your issue. It’s probably not harmful, but you might just be sure your grounds are good and maybe throw a ferrite on the power wires if you’re feeling saucy.
  9. May 2, 2023 at 5:59 PM
    Taco 422
    Taco 422 Well-Known Member
    USA
    Gen 2 AC v6 TRD SR5 Prerunner
    A kenwood of mine did that in the Jeep. I think it was a power spike and filtering issue. I'd put a magnet filter on the power cord at one point and it started, kept going when I took the filter off. Didn't do a loop however.
