Go Pro Dashcam Question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dxironman, Dec 11, 2021.
  1. Dec 11, 2021 at 9:31 AM
    Dxironman
    Dxironman [OP] Well-Known Member
    Central Florida
    21 TRD Sport
    I just got my windshield replaced and the new one has a Go Pro mount. I’d been thinking of getting a dashcam anyway, is there a particular model Go Pro I should get? When it’s installed does it just turn on and record whenever I drive or do I have to manually press record every time? Does it save straight to a SD card and just overwrite the oldest footage when it runs out of space?
  2. Dec 11, 2021 at 9:35 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    My dash cam (non-go pro) does everything you mentioned automatically.
  3. Dec 11, 2021 at 9:48 AM
    K9TXS
    K9TXS Well-Known Member
    Clarksville, TN
    I tried a GoPro for a short time, but like many other cameras, it will heat up and stop working. Right now, I have my eye on a Garmin Dash Cam Mini 2. You can see a YouTube video on it.
  4. Dec 11, 2021 at 9:49 AM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    I have this cheap dash cam. So far has worked great for 3 years and does everything you wanted.
    https://www.amazon.com/DP-Audio-Video-DVR140-DashCam/dp/B018MB6SV8
    I do make sure to remove it on really hot days as it gets flakey after baking in the cab on 100 plus degree days.
    Got it to fit in the GoPro mount by getting a Grab Bag of connectors.
    https://www.amazon.com/GoPro-Grab-Bag-Official-Mount/dp/B01GCKO9IK
    There are better dash cams available. I bought it with the intention of moving to a higher end brand but never felt the need.
  5. Dec 11, 2021 at 9:54 AM
    K9TXS
    Clarksville, TN
    Do you take the card out occasionally and spot check it to see that it is still recording and hasn't stopped?
  6. Dec 11, 2021 at 9:57 AM
    eggs
    eggs Well-Known Member
    Beersconsin
    2017 TRD O/R
    Second vote for Garmin Mini. Just records an endless loop on the SD card, continually deleting the older stuff. Starts recording when you start the car. I guess it has motion sensor also for parking lots but I don’t use that. You can watch it on your phone (WiFi connection) or take the card out and download to your computer.
  7. Dec 11, 2021 at 9:36 PM
    TA2016
    Oregon
    Yes, I check periodically that is sill recording. Being a cheap dash cam the date gets out of sync, so I just reset to the correct date when I check recordings.
