Go Rhino Running Boards (?)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Boricua, May 2, 2018.
  1. Dec 15, 2019 at 9:24 PM
    primodude
    primodude Well-Known Member
    Tacoma Wa
    19 Cement DCLB TRD OR
    Did you end up going with the “bed liner type” finish or the basic powdercoat? I like the look of them out of all the running boards I have seen so far. Wondering if I should go with the basic powdercoat and have them bed lined myself to help preserve them. Also did you have an issue with the hardware that came with them rusting? I have read more than one case of that happening with these boards. Thanks for the response.
  2. Dec 16, 2019 at 1:39 AM
    Jarhed86
    Jarhed86 Well-Known Member
    Brad
    Pennsylvania
    2017 Blue Tacoma TRD Off Road
    I went with the Bed liner finish. The hardware did rust, nothing crazy, it just drove me crazy along with the peeling. I’m going to clean them up in the spring and bed line them myself and then decide if I want to put them back on. One more thing I forget to mention they are pretty heavy.
  3. Dec 16, 2019 at 6:20 AM
    primodude
    Tacoma Wa
    Ok good to know, are they noticeably heavier than the oem aluminum boards? I watched a video on them and they stated they offer a 5 year warranty on the finish of them. It might not hurt to shoot them an email to see if you can recoup some of the cost back for the hassle.
  4. Dec 16, 2019 at 3:19 PM
    Jarhed86
    Brad
    Pennsylvania
    After doing some digging the weight difference between the GoRhinos and the OEM aluminum are approximately 10 lbs and the ones I have now (Toyota PT212-35055) are around 35 lb difference. I thought about the warranty but I have a friend that has a body shop that will coat them or I may do it myself haven’t decided yet, the warranty may be worth a shot though. The price difference between the GoRhinos and OEM aluminum is around $300 on Amazon. If I had it to do over I probably wouldn’t purchase the GoRhinos again, my fault though because I knew of some of the issues with the coating. Live and Learn I guess.
  5. Dec 16, 2019 at 3:26 PM
    siKjiTz
    siKjiTz Well-Known Member
    E
    Oahu, HI
    2017 DCSB TRD Sport Inferno
    TUNED 2.0 Beta 87 Eibach Pro Truck Lift Kit Stage 1 Wheelers 1.5” Progressive AAL Level 8 MK6 17x8 Falken Wildpeaks 265/70/17” Redline Tuning Hood struts Matt Gecko LED Bed lights OEM Roof racks GoRhino RB20 Running boards A/C drain Mod Kicker speaker upgrade w/kicker key amp. MESO Stage 1 Tail light upgrade OEM Bed Mat
  6. Dec 16, 2019 at 3:43 PM
    Jarhed86
    Brad
    Pennsylvania
    They do look good but in the end they didn’t work for me.
    Then again who knows maybe they’ll end up back on my truck. Good luck with them.
  7. Dec 16, 2019 at 3:53 PM
    Jarhed86
    Brad
    Pennsylvania
    I did forget one thing, they are great for avoiding door dings. I was sitting in my truck at good old WalMart, waiting for her, listening to the radio, then out of nowhere the truck moved and I heard a bang and then it happened again. Long story short some guy pulled in next to me flung his door open hit my running board got pissed and did it again. I put my window down asked him if he was finished and all he could do was put his head down and mumble about my bleeping running boards.
  8. Dec 16, 2019 at 5:04 PM
    primodude
    Tacoma Wa
    thanks for all the info.
    Jarhed86[QUOTED] likes this.
  9. Jan 2, 2020 at 10:15 PM
    Socialrafa
    Socialrafa Well-Known Member
    2020 Sport 4x4 DCLB cement
    What brand tanneau is that?
  10. Jan 3, 2020 at 5:09 PM
    SupaWHITEtaco
    SupaWHITEtaco Well-Known Member
    David
    Da Bay Area
    2017 Taco Sport DCSB 4x4 Supa White
    Bakflip MX4
  11. Feb 26, 2020 at 9:21 AM
    Oilblaze
    Oilblaze New Member
    I love the look of these and actually think I prefer the wide front. I just bought my first Tacoma, 2019 Off-Road, and have a pair of these on order in the bedliner coating.
  12. Jun 6, 2022 at 8:57 AM
    Tinma
    Tinma Well-Known Member
    bringing this thread back to life just to see how everyones RB20's are holding up after a few years. How is the finish holding up? Do you find that they are too wide (GoRhino released a slimmer version now so tore between the two)?
    TIA!
  13. Aug 13, 2022 at 6:20 PM
    Goodinfection
    Goodinfection Member
    Brian
    Kings Mountain NC
    2009 Tacoma CrewCab 4WD Standard Longbed
    SR5 4WD Longbed
    10096138-A269-490A-AB0D-CAA4478FD4B1.jpg BCE4F478-9BF7-4627-9ECF-F6594B504792.jpg B550469A-9FD6-480B-8D6A-D49114FDE205.jpg 10096138-A269-490A-AB0D-CAA4478FD4B1.jpg BCE4F478-9BF7-4627-9ECF-F6594B504792.jpg I just ordered a set of the GoRhino RB 20 slime lines and the brackets that came with them only span an 1/8” on each side. The bracket measures 3” wide and the width of the opening is 2 3/4”. They seem like the wrong bracket. Waiting for Auto Anything to reply. This doesn’t seem like the right part.
  14. Aug 13, 2022 at 6:35 PM
    Oedipus2727
    Oedipus2727 Well-Known Member
    DMV
    2022 Tacoma TRD OR MGM V6 4x4 DCLB
    I need so to keep the door dings away..
  15. Aug 14, 2022 at 4:25 PM
    #35
    Goodinfection
    Brian
    Kings Mountain NC
    SR5 4WD Longbed
    6DB1CEAB-49C6-4C9F-8192-D7BC75523DC0.jpg 3204EC78-5A49-43C6-9953-16E3D4592EDC.jpg EE0786B4-28E3-4A89-BAC0-07D09ADEF417.jpg 304557CD-F086-4B9C-8753-D440DD07B9D8.jpg
    The bracket pics I posted yesterday are the same item# on the box as on the Go Rhino website but they can’t be the correct brackets because with only an 1/8” play you can’t adjust them. Plus the gap between the bottom of the door and the top of the board is enough to get your foot through.
    So I tried the brackets from the old dealer installed running boards. Exactly what I was looking for, less bling, more grit.
  16. Aug 14, 2022 at 8:22 PM
    #36
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    take a look at the 2nd gen factory ones too
  17. Aug 15, 2022 at 8:17 AM
    #37
    big110
    big110 Well-Known Member
    have seen these and they look stout
  18. Jan 5, 2024 at 8:31 PM
    #38
    ACO23
    ACO23 New Member
    23 Toyota Tacoma Sr5
    @Jarhed86, did you get the slim or original?
  19. Jan 5, 2024 at 8:43 PM
    #39
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    A@!#$@$%#$%
    The wild west
    2016 SR5 DCSB
    he hasn't been on here in over 3 years
  20. Apr 6, 2024 at 4:39 PM
    #40
    Matt Watmetal
    Matt Watmetal Matt Warmetal
    2020 Toyota Tacoma trd sport
    Magnaflow exhaust Ted intake
    Does anyone have info on part numbers for GoRhino Dominator Xtreme D2 side steps model #D20080T need help finding brackets/hardware. Tried online searchs to no avail
