Go to 37s or stick with 35s?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Trident904, Jan 15, 2018.
  1. Jan 15, 2018 at 4:01 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Looks sweet with 35s. If the cv and front diff werent so weak I’d consider 37s lol
    la0d0g likes this.
  2. Jan 15, 2018 at 4:03 PM
    Trident904
    Trident904 [OP] Touching Drum Sets
    Brian
    Treasure Coast, Florida
    17 4Runner TRD OR
    Modded it so much it turned into a 4Runner
    Why? Please explain? Truck is almost overpowered now with the 4.88s. I can dump the clutch in 1st gear without stalling or adding any throttle.
  3. Jan 15, 2018 at 4:04 PM
    Trident904
    Brian
    17 4Runner TRD OR
    When this happens, there will be better quality CVs involved.
    Truck is getting SAS in 2 years anyways.
    outlawtacoma likes this.
  4. Jan 15, 2018 at 4:12 PM
    05tacoalltheway
    05tacoalltheway Well-Known Member
    Brian
    2010 FJC
    That marlin taco crawl box would help mitigate CV failures I’m sure
  5. Jan 15, 2018 at 4:30 PM
    la0d0g
    running for the hills
    For crawling not hauling
    Meh. Why waste money LT'n it then? Sit on 35s for two years then swap to tons.
    helix66 and outlawtacoma like this.
  6. Jan 15, 2018 at 4:34 PM
    Trident904
    Brian
    17 4Runner TRD OR
    That is being considered too.
  7. Jan 15, 2018 at 4:34 PM
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    You didn’t need to trim the fenders? Are you running bump stops to limit uptravel?
  8. Jan 15, 2018 at 4:43 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Thats always the answer to these questions.
    Either you know you *need* them for the type of wheeling you do and just do it without bothering to ask, or its more of a novelty and you just want them.
  9. Jan 15, 2018 at 4:48 PM
    mikestaco17
    mikestaco17 Well-Known Member
    MIKE
    BAD ASS UTILITY CAB
    your truck flexes beautifully , would 37s get in the way when articulating that well , like into top of fenders?
  10. Jan 15, 2018 at 4:54 PM
    Trident904
    Brian
    17 4Runner TRD OR
    That pic was full stuff on stock bumps. No fender trim needed.
  11. Jan 15, 2018 at 4:54 PM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    would you rather the weak spot be the cvs or the diff? much easier to swap cvs on the trail vs diff. and cheaper
    keep 35s till you go with a solid axle up front
  12. Jan 15, 2018 at 4:55 PM
    Trident904
    Brian
    17 4Runner TRD OR
    I will know whether I need them or not after my trip to Windrock in April. I’m planning to run Rubicon in 2019 so 37s may be necessary
  13. Jan 15, 2018 at 4:56 PM
    Trident904
    Brian
    17 4Runner TRD OR
    I had 37s on my 06 and never had an issue with CVs or the diff.
  14. Jan 15, 2018 at 5:00 PM
    11Bguy
    11Bguy Well-Known Member
    Va
    2017 DCSB TRD
    Icons/ JBA UCA's
    Do you not already have a CMC?
  15. Jan 15, 2018 at 5:27 PM
    #35
    Trident904
    Brian
    17 4Runner TRD OR
    Yes, I already have a massive CMC. You aren’t fitting 35s on a 3” lift without it.
    mcharfauros and MCDavis like this.
  16. Jan 15, 2018 at 5:31 PM
    #36
    friendlywithbears
    friendlywithbears a tree falling in the woods
    B
    The Wild
    2016 TRD OR MT
    From what I've seen you will probably want to relocate the cab mounts altogether. Why don't you just shut up and SAS it already :)
    Trident904[OP] and outlawtacoma like this.
  17. Jan 15, 2018 at 5:57 PM
    #37
    11Bguy
    Va
    2017 DCSB TRD
    Icons/ JBA UCA's
    Yeah I figured but in your first post you asked for anything besides a CMC and cutting fenders. So I didn't know if you just knew about it or already had it done.
    Truck looks great by the way!
  18. Jan 15, 2018 at 5:59 PM
    #38
    TacomaBlu
    TacomaBlu Well-Known Member
    2017 TRD Sport
    6in Procomp 35in Toyo M/T 18x9 Mamba M13
    Same here on my 06, 37s with Fabtech 6", 3in body, cmc, Race Runner coil over set at 2.5, TC UCAs, and Alcan 6.5 leaf pack. 44k miles and the only issue was caused by Super Swampers. Tore up my front wheel bearings.
    Not sure of the milege now but 12 years later and it's still running around the Jax NC area.
  19. Jan 15, 2018 at 6:04 PM
    #39
    Trident904
    Brian
    17 4Runner TRD OR
    That sounds like a goddam dare!
  20. Jan 15, 2018 at 6:04 PM
    #40
    Trident904
    Brian
    17 4Runner TRD OR
    Thanks!
