Goal zero left outside…???
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kronk21, Jul 9, 2022.
  1. Jul 9, 2022 at 2:31 PM
    Kronk21
    Kronk21 [OP] IG @uniquely_Us_adventures
    Monte1
    2021.DBLCB.LB.GRN
    King 2.5 with reservoirs, CBI sliders, RCI skids, Leer camper shell, Methods, K02, switch-pro
    Anyone have a yeti power bank and if so have you been leaving them outside when camping? I understand not direct sun and rain duh. But what a bout a cool spring night? Or a 32* night? I can’t find the limits for the goal zero anywhere.
  2. Jul 9, 2022 at 2:38 PM
    Shellshock
    Iowa
    under specs
    https://www.goalzero.com/products/goal-zero-yeti-1500x-portable-power-station
    • Operating usage temperature: 32-104 F (0-40 C)
    eurowner and Kronk21[QUOTED][OP] like this.
  3. Jul 9, 2022 at 3:11 PM
    Kronk21
    Monte1
    2021.DBLCB.LB.GRN
  4. Jul 9, 2022 at 3:44 PM
    Shellshock
    Iowa
    if its that cold, keep in mind its gonna be warmer inside a tent or truck than it is outside. if its real cold, you can stick it in a cooler or something that's insulated.
    Kronk21[QUOTED][OP] likes this.
  5. Jul 9, 2022 at 3:53 PM
    Kronk21
    Monte1
    2021.DBLCB.LB.GRN
    True true I just worry about condensation…
  6. Jul 9, 2022 at 7:59 PM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    I got one and it travels in the camper and has been subjected to 110+ degrees inside that camper for hours/days at a time. Had if for 4 years now and it still
    works well. It has survived 35 degree temps as well no issues. Have not had it out in the rain or direct sun and don't plan on it.
  7. Jul 9, 2022 at 8:10 PM
    Grindstone
    Grindstone Requires Adult Supervision
    Check the IP rating like "IP67" or "IP65". The first digit is the rating against dust, the second digit is water. Minimum of IPX1 for condensation protection. You're probably good to go.
  8. Jul 9, 2022 at 8:41 PM
    Kronk21
    Monte1
    2021.DBLCB.LB.GRN
    Cool I check it out, thanks!!!
    Grindstone[QUOTED] likes this.
  9. Jul 9, 2022 at 8:43 PM
    YotaGangYotaGang
    YotaGangYotaGang PreRunners are wannabe 4x4’s
    Covina
    95, 97, 01 Tacoma | 06 Tundra | 07 FJ Cruiser | 08 Prius
    A rtt i never use and 30 light bars
    completely offtopic but for me it gets hot inside the truck and the Jackery will stop charging off the solar, so I put my lil fan next to the exhaust of the jackery, solved it.
    Kronk21[OP] likes this.
  10. Jul 9, 2022 at 8:48 PM
    Kronk21
    Monte1
    2021.DBLCB.LB.GRN
    That’s smart it lives in the truck must of the trip I didn’t think about it heating up when charging while we drive it’s packed in pretty good…
