God Awful Belt Squeeling!!!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by cole47, Nov 27, 2009.
  1. Nov 27, 2009 at 8:24 PM
    cole47
    cole47 [OP] Well-Known Member
    Cole
    Hickory NC
    Ray of Sunshine
    lift, wheels, tires
    On cold starts my belt squeels for 45 seconds or so...what the hell is this??? im getting tired of hearing my trucks a piece.....belts replaced last year about this time.:confused:
  2. Nov 27, 2009 at 8:42 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    could be something on the belt, or your tensioner is going out. Check both out.
    hope you find the problem!:)
  3. Nov 27, 2009 at 8:46 PM
    cole47
    Cole
    Hickory NC
    Ray of Sunshine
    lift, wheels, tires
    thanks dude
  4. Nov 27, 2009 at 8:53 PM
    ETaco23
    Evan
    PNW
    AnyTime!:)
  5. Nov 28, 2009 at 12:25 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Belts are probably coming loose.
    If you have the 3.4L - there are three belts and each belt has a separate tensioner which usually is the 'accessory' that the belt is driving.
  6. Nov 28, 2009 at 12:40 PM
    mixaro
    mixaro Well-Known Member
    maine
    02 tacoma ext cab, 2011 trail edition 4 runner, 2013 tx baja dcsb
    02 ext cab cat-back exhaust, k&n replacement filter, 5100 billy's, hellcreek 1.5" rear spring packs, 882 OME coils, Toytec 2" AAl, stainless brake lines, Light Racing UCA, 1" diff drop, BPV bracket, 4" deck plate mod, 886 fog light backup light mod, tom woods one piece drive shaft, spider trax 1.25 spacer.
    yeah sounds like either your belts are loose or that one of the belts or pullys is going bad. try spraying something like pb blaster on your pullys one at a time (making sure not to get it on the belts of course) and see it that fixes it, and then you can figure out which one it may be.
  7. Nov 28, 2009 at 8:29 PM
    cole47
    Cole
    Hickory NC
    Ray of Sunshine
    lift, wheels, tires
    thanks guys....didnt do it this morning...all the belts feel tight to the touch but hell what do i know...thinking about taking it to get it looked at this week
